LinkBack | Thread Tools |
Turtle Wax Taster
Does anyone here know if the rear cast wheel on the 900 Custom interchangeable with 900 Classic without any modification? I like spoke wheel style but also more favor the cast wheel since it goes with tubeless tire, less dangerous on flat tire, easy to wash and maintain, etc. But the front wheel cast of the Custom does not impress me. I feel more confident with my current Classic front. Not sure any after market wheel has cast style for the front classic.
'06 Vulcan 900 Classic Red |
IBA#34418
I think I read the back tires are the same, but the customs front tire is different.
You can get custom rims now for the 900 but I hope you have a lot of money to spend!! I wish I could get some. I don't like spoked wheels.
If you like your freedom thank a Vet! U.S. Navy Vet 2006 VN900LT |
#4 (permalink) | |
Banned
This comes from the service manual
#5 (permalink) | |
Turtle Wax Taster
#6 (permalink) |
PGR - BFC
![]() Join Date: Jul 2006
Just because the tire type is tubeless doesn't mean you cannot run tubes in them. Most of the tires I look at now for the 900 will accomodate both ways. I know that in mine, both are tubed.
That sounds dumb. Dumb is out. 08 Rogue LT 06 900LT - Met a Lincoln - RIP 94 Screamin' VN-750 |
#7 (permalink) |
![]() Join Date: May 2006
My tires have tubes in them. Been there since day one I owned it.
Even saw them take out the tube and reuse when I had the rear tire replaced.
2008 VULCAN 1600 NOMAD |
#8 (permalink) |
Yup... any spoked rim except for perhaps very expensive aftermarket/custom, or a self-modified rim is going to require a tube.
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
#9 (permalink) |
Rebel Rider
Spoked wheels require tubes because the air will leak out where the spokes are in the wheel. They have an rubber inner band around the inside with the tube. You can run tubeless tires with tubes, doesn't hurt a thing, in fact most tires now are tubeless. Cast wheels have tubeless tires with no tubes. You can have spoked wheels sealed to run tubeless tires and no tubes, but it must be done correctly or could cause problems and constant leaks.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
#10 (permalink) |
Organ Donor
AZ Rider is correct. The point is that the tires are tubeless. They do not require tubes (the tires, forget about the rims for a second). It can't be much more clear. You can put the OEM tires on a non-spoked rim and run them without tubes. On the stock spoked rims you need a tube, nobody is disputing this. That does not mean that that the tires require tubes in all situations. AZ Rider's quote is from the 900 service manual and is accurate. It is a description of the tires themselves, not this application of the tires.
2007 Ebony Vulcan 1600 Classic VROC #21369 VNOG #78 |
#11 (permalink) | ||
#12 (permalink) | ||
Banned
When the service manual states "tubeless" that means the bike has no tube. I still cant figure out what gives. Quote:
One thing,something doesnt jive. |
#13 (permalink) |
Can't find time to ride
Yes the VN900 Classic uses Tubeless Tires with a Tube because of the spoked rims.
You may be able to mount the rear tire from the Classic onto the Custom, however the front tire is completely different on the custom. |
#14 (permalink) |
Rebel Rider
[There are spoked wheels on the market that are tubeless. I thought maybe Kawi had used them on our bikes.
One thing,something doesnt jive.[/quote] Yes, but they have been sealed. No spoke wheel can run without tubes unless it's been sealed, and they are not as reliable as a spoked wheel with tubes.
#16 (permalink) | |
Tru-Spoke cage rims didn't require adjustments, and they just had the valley filled with RTV. The conversion for a bike does the same thing, and there are no provisions to allow for spoke adjustment. Once it's done, if you ever need to adjust your spokes, you will have to dig out ALL of the RTV and reseal the whole thing... IE: Do this only on a well broken in rim and spoke set, and bring all spokes up to proper torque prior to beginning It's a major PITA. The RTV tries to follow gravity... as thick as it appears, it really wants to run downhill, and if the layer is not perfectly even it can really screw up your balance. If you still want to try it: http://www.gadgetjq.com/tww.htm
#17 (permalink) |
Banned
Is that how its done for the wheels you can buy aftermarket?
Im starting to think that originally they were going to use a cast wheel on the classic, and changed there minds at the last minute. It would explain a few things. |
#18 (permalink) | |
They PROBABLY use a double-rim design with a strap welded around the inside covering the nipples, but I really don't know... you wouldn't be able to replace one if you cross threaded a spoke during a relace.
| New member interested in Vulcan 900 Classic or Custom | Kawa 900 | Kawasaki Cruisers | 30 | 03-30-2009 01:04 AM |
| Vulcan 900 Custom | bad andy | Kawasaki Cruisers | 1 | 01-04-2007 11:30 PM |
| trading off 900 classic maybe? | 900vulcan | Kawasaki Cruisers | 12 | 12-30-2006 11:51 PM |
| Vulcan 800 Classic Black or Wait for 900? | WalterRC | Kawasaki Cruisers | 29 | 10-28-2005 04:11 PM |
| Chrome wheel covers for a Vulcan Classic 1500 | Kenny | Kawasaki Cruisers | 9 | 12-24-2004 05:38 PM |
