#41 (permalink) | |
the "fun old" guy
Here's some info about it. SeaFoam |
#42 (permalink) | |
Giant Biker
RP kills most oils on the timken test. I think the only oil ot there that is really comparable to RP is Amsoil. I used to run RP in my vehicles, but I got a hook up for free Mobil 1 a couple years ago and got about 6 cases for free. So I stuck with the M1 in my truck since then. Wish I still had that resource!!
Shawn Lattimer '06 Silver V2K Classic VROC #22980 ROG #464 http://www.shawnlattimer.com |
#43 (permalink) |
Made It To Second Gear
I use Royal Purple with a K & N filter.
I just change from the 10w40 to 20w50 for the summer.
Ricone R/B 900LT Corbin DT Seat Cobra Highway and Light Bar Royal Purple Synthetic |
#45 (permalink) | |
Transplanted Newfie!
Royal purple has a number of bike specific types...which one did you go with, Max Cycle?
Living life one day at a time! 02 Nomad |
#47 (permalink) | |
Wants better weather!
Rich, it'll be very interesting to see how the GTX analysis comes out. I've used Castrol GTX in my cars and bikes since back in the early 70's and never had a problem with it. If it works as well as the synthetics at 1/3 the price why would I want to spend the money for Mobil and Amsoil, etc. Change it at 3k and save money.
Art 1998 Honda Valkyrie Black/Chrome/Fast (Still a Nomad lover) |
#48 (permalink) | |
![]() Join Date: May 2004
I seem to change the oil about 3 times a year mostly due to the change of season temps here in East TX. As a daily cummuter I often start the bike in temps below freezing in the winter, then for 2/3 of the year I'm subject to temps above 100F. So I'm changing bike oil mostly becuase I want to change the viscosity grade to match the season -a bit anal I know, but one start with 20W-50 at a temp of 28F will convince you to get it out of there and replace it with a lower viscosity
05 Nomad/V&H Baggers/PCIII/Caddman Risers/Lights/Lowers/Chaps www.home.earthlink.net/~mthompson61 |
#49 (permalink) | |
the "fun old" guy
#50 (permalink) | |
#51 (permalink) | |
Ahhh Crap
In June I'll be taking the bike on a 3,000 mile trip out west so I've been reading a little on oil but so far nothing has made me want to switch away from Rotella. I really liked AMSOIL but it and the other MC specific oils are just too expensive.
Steve 2003 1500 Classic VROC 11660 RB 139 |
#52 (permalink) |
Scooter Trash!
Savage: GTX 20W50 year round. Emgo filter. Switching to 15W40.
Vulcan: Rotella 15W40 year round. Walmart filter. Intruder: Syntech 10W40 year round. Emgo filter. Soon to be Rotella and Walmart like the Vulcan. I tried a couple mc spec syns in the Vulcan. Made it leak oil. Full synthetic flat out vanished from the Savage. No leaks, no visible smoke, but no oil less than 24 hours post-change. I'll stick with what works for me. Cheap, readily available in North America, functional. -Scruffy
Eagle Scout. Veteran. Patriot Guard Rider. 1950s style Savage barhopper 1950s style VN800B bagger |
#55 (permalink) |
V2KTN
"Zero" Mobile1 0-40, It's supposed to be the best for getting the oil circulating when you first crank up and still the viscosity is 40 when its hot.
2006 Kawasaki Vulcan 2000 Classic LT, Black |
#57 (permalink) |
Amsoil is great. I buy it by the case. Mobil 1, Royal Purple, Rotella are excellent as well. I've used GTX with no problems in the past too. I stick to Amsoil now though.
From the thousands of posts I've read on this, it seems (for most) that as long as you stay away from the "energy conserving", & change out at the proper intervals, then you'll be fine. I'm no mechanic, & there are always the few exceptions though, so YMMV.
'06 Black Nomad |
#58 (permalink) | |
The last time I heard of someone using a 0w was when a guy in Canada could not get Rotella 5w40 and got 0w40 instead... he had serious clutch slippage, and a quick call to Shell confirmed that they knew it was not suitable for a wet clutch. My only concern with a 0w (beyond clutch slippage issues) is the shear stability. Synthetics are generally far superior to conventional, as they do not require as many (much?) viscosity improvers in the blend, but the fact remains that a 20w50, at 2.5:1 will hold it's viscosity better than a 15w50 at 3.3:1, or a 10w40 at 4:1. 5w40 goes to 8:1, but synthetics are stable enough to perform comparably to a 15w40 at 2.7:1, but I wouldn't run any 0wt without very careful used oil analysis monitoring under different temperature conditions. Short story, Kawi recommends 10w40 unless ambient is going to be above 100 degrees, then 20w50. 20w50 is good DOWN to around 30 degrees. Quality synthetic takes care of cold-flow issues without having to resort to 0w blends that could bring warranty issues. Given my temperatures in CA, I would never experiment with any 0w oil. If I lived in Canada or the northern US, I would give it a shot and run some samples through Blackstone!
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
#59 (permalink) | |
It's strange... it's hard to pin down. Seemed to give me some moderate slip in 1st and 5th last weekend, but this morning I couldn't make it slip. Later in the afternoon, I tried again and got mixed results.... nothing consistent, and nowhere near as badly as I experienced it last weekend. I'm going by a 5th gear roll on from 70mph. Last weekend the engine would quickly rev through 4k on it's way to 5k. This weekend... hotter weather and a fully warmed engine... it would barely rev over what it would be when not accelerating. I was going to dump the oil this weekend and flush it with GTX again, but given it's performance today, I might leave it in and see what happens. Keep in mind, I am monitoring this with a tach... the kind of slippage that I'm getting on the M1 may not be noticeable without actually looking for it with a tach. By comparison, the Motul was so bad that the first time it slipped on me I thought the bike next to me was revving his engine and I could absolutely feel the lag on a 5th gear roll-on (immediate rev to 5k).
#60 (permalink) |
VN 1500 classic
I do have another question.. I hadn`t had a chance to do an oil change(outta town)
quite yet. My friend is trying to convince me that Motul is the best oil for my ride. It would sure be for my wallet but I`m not that certain about my bike. He`s a motor mehanic driving a Honda hornet900 and he didn`t get any clutch slippage as he is using it for couple of years. I am just slightly concerned because I read at least 2 posts that did strongly object using Motul on Vulcans/severe clutch slippage aftr1000mls or so.. Now..is there any truth in that? |
