#61 (permalink) |
BTK rookie in training
Rotella dino, ck this outhttp://www.shellusserver.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=3081&page=1#Pos t3081
05 1600 Nomad blue/silver Kuryakyn grips throttle boss pegs Vista cruise gutted pipe 2001 XR650R |
#62 (permalink) | |
Let's Ride!
![]() Join Date: Oct 2004
"Formula 4-StrokeŽ Power Sports 0W-40 Synthetic Motor Oil (AFF) AMSOIL Formula 4-StrokeŽ Power Sports Synthetic Motor Oil (AFF) is specially formulated for four-stroke recreational motors, ATVs and snowmobiles. Reduces wear. Wet clutch compatible. Contains no friction modifiers. Broad viscosity range makes it excellent for use in both hot and cold weather conditions." |
#63 (permalink) | |
the "fun old" guy
#64 (permalink) | |
Let's Ride!
Rich? One question. You mention your clutch slipping with your last batch of oil. How many miles on your bike? Original clutch? Upgraded clutch springs (from the meanie)? (OK maybe more than one question |
#66 (permalink) | |
Let's Ride!
http://www.kawasakimotorcycle.org/fo...t=oil+analysis |
#67 (permalink) | |
![]() Join Date: May 2004
05 Nomad/V&H Baggers/PCIII/Caddman Risers/Lights/Lowers/Chaps www.home.earthlink.net/~mthompson61 |
#68 (permalink) | |
#69 (permalink) | |
When the Motul started slipping, I THOUGHT it was the clutch, as I had just done a couple of parades with the PGR. I replaced the clutch with a new Barnette... according to everyone I've talked to, the last clutch I will ever have to buy. The Barnette was installed 12/7/06 at 5500 miles (stock clutch looked fine). The Motul slipped almost immediately, and was removed and replaced with Castrol GTX at 6,000 miles. This last oil change was at 8k. I had NO slipping on the GTX the day I changed it out (went for a 75 mile ride in the twisties to warm up the bike prior to the change.) Noticed slippage immediately Sunday morning.
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
#70 (permalink) | |
Good stuff... I would not have a problem strongly recommending it to anyone riding in warmer climates. Likewise with Mobil-1 V-Twin 20w50. Both oils have very different additive makeup, but both held their viscosity extremely well, remaining in grade well enough to still be "confused" with a brand new oil after 2,000 miles in the California summer. I strongly suspect that both would be more than adequate for the full MOM-recommended 6,000 miles. I run Amsoil in my Duramax to 12,000. As a matter of fact, the analysis sheets I have posted are my SECOND set from Blackstone, as they actually did get confused and misapplied the "expected" numbers on the bottom row to the wrong report (I send in a virgin and used sample at the same time).
#71 (permalink) | |
10w40 is out for me for the season, but I might consider it!
#72 (permalink) |
CMA - Ride for the Son!
I would only go with Amsoil. I'm going to have mine tested. It has 5000 miles on it. I just ordered more from the corporate store. If you get the preferred customer deal, $10 for 6 months, it will reduce your bill by 25%. They also sell the filters that will accomodate the oil. I'm also going to put this in my truck. With their filter, you are supposed to get 25,000 miles between oil changes.
Buzz |
#73 (permalink) | |
the "fun old" guy
#74 (permalink) | |
the "fun old" guy
#75 (permalink) |
Yes, I use Amsoil 20w-50 because of the heat down here. I use 10w-40 in my wife's Vn500. Also to ask a question about Supertech oil, is it designed for motorcycles?
Buzz |
#76 (permalink) | |
Most claims of 25k+ intervals are augmenting with bypass filtration. I know guys that are analysing well with 60k intervals on their Duramax engines with bypass filtration and 10k change intervals on the spin-on. But that's not in a wet-clutch sytem with gears squeezing the snot out of the oil. I'd love to see your 5k report.
#77 (permalink) | |
Let's Ride!
#78 (permalink) | |
Wants better weather!
Why not use a less expensive filter, eg. Walmart 1773? and change the filter at 3K and top off the oil with the Amsoil? If the oil will hold up for the extended mileage then a new filter and top-off should work well.
Art 1998 Honda Valkyrie Black/Chrome/Fast (Still a Nomad lover) |
#79 (permalink) | |
Let's Ride!
I have Amsoil 20W50 in the BMW using a BMW filter but I will just stick with the 10,000km drain interval recommended by BMW. I'll send a sample off once I get the 10,000km on the oil. I'm OK with the recommended drain interval for the BMW because it's air cooled, I figure the oil will be working harder than in the liquid cooled meanstreak. |
