Old 04-02-2007   #1 (permalink)
snw1953
Foil Inspector
snw1953's Avatar
Default VN2000 rear noise gone--for now
Well, this weekend I dug in and went all the way to get rid of the squealing noise in the rear of my '05 Vn2000. First I had the rear bearings replaced, had grease seeping out after a ride to Miami. At the same time had a new rear tire added, 18,100 miles and 4th tire. Then I pulled the rear pulley, took it to my work and bonded the rear plate on with a Weld-on product that we use, I did this to prevent any movement that may be occurring causing it to squeak. Then I went into the front pulley and covered the outside of the pulley where it is swedged together with disc break squeal preventative. Lastly, I cleaned the belt with soap and water, something that a guy at the dealer said he had to do to his snowmobile belt when he lived in snow country when it started to squeal. Well the noise is gone and I feel safe to ride to Cherokee, NC later in the month. What was the fix? Probably the soap and water, it was the cheapest, with my luck, but wasn't going to spend all of that time in the rear and not cover every thing that I could think of. So, if you’re trying to get rid of your squeak, start with the least expensive and work your way up.
snw1953 is offline   Reply With Quote
Old 04-02-2007   #2 (permalink)
2WheelFun
2WheelFun's Avatar
That sounds like alot of work. I would have been frustrated if I did all that only to still hear the squeak.
Keep us posted if it returns?
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 04-02-2007   #3 (permalink)
Arkainzeye
DR#001
from what i understand the belt noise is a alinment issue.
chris
Arkainzeye is offline   Reply With Quote
Wind Noise - A Serious Discussion SixFiveOh Main Lobby 47 03-21-2007 12:17 AM
Noise cancelling vs Noise isolating earphones taro Riding Gear 7 09-02-2006 04:34 PM
Yet Another Engine Noise Question khollister Kawasaki Cruisers 3 11-07-2005 01:28 PM
Weird noise from rear of mean streak Rocsmeanie Kawasaki Cruisers 4 06-21-2005 10:32 PM
Bad squeek in rear of vn2000 Vulcan drace Main Lobby 4 10-28-2004 11:05 AM
