LinkBack | Thread Tools |
Cruising In Fourth Gear
I know this has probably been covered before, but searching didn't really show anything.
Can anyone make and recommendations on lowering the rear of a VN800. I know Cobra and probably Scoot Works have kits to do it, but who's actually had success? I don't want to order something from the US that doesn't actually work, or doesn't fit like it should. |
Yet another 800 Bobber...
Hi!
The Cobra and Highway Hawk kits are almost identical and both are crap. You have to compress and modify the shock itself, which is a bloody hell unless you have the tools. And it is an expensive kit considering what it consists of and the result it gives. The bike will only get 2cm lower, hardly seen at all. The advertisments sometimes says 4 cm but that is bullsh*t. The Scootworks kit costs more but it is the only kit that actually gives a result as far as I know, haven't tried it myself though. You could get the same result by extending the stock links on your own, which involves cutting and welding (instructions). There is another method that I came up with myself while mounting the Highway Hawk kit. The result is exactly the same but you need no new parts, no drilling, cutting or welding. A similar method is described at the bottom of the site I linked to above, but I have attached a sketch showing an even better way of doing it. It's all about letting the locking nut and the U-shaped bracket swith place with eachother, giving a shorter shock. It will also increase the preload on the spring a bit, so you might want to compensate for that with the 7-step preload ring on the shock.
VN800A -95 Bobber Project, work in progress |
Looking at the site you included, I don't like the idea of redrilling the shock clevis with the new hole overlapping the old, surely this would create some kind of play in the suspension?
I like your idea of swapping the lock nut and U-shaped bracket though, I can't see why that's not he best idea of the lot. Did you end up doing that Thullan and what was the result? Could perhaps even use a thinner lock nut? |
#4 (permalink) |
I should have tried this method above if I had came up with the idea before I bought the Higway Hawk kit. I don't think a thinner locking nut will make any difference. There is one thing to pay attention to though, and that is to leave atleast 1 mm of space where indicated by the red arrow in the attached drawing, or the rocker arm wount be able to pivot (se updated drawing). Please note that I haven't tried this method myself, so there may be some problems that I have overlooked!
I was first also thinking about drilling new fixing holes in the frame where the upper part of the shock attaches (just below the seat), maybe 1-2 cm above the original holes. I never tried this either, but this should be a cheap fix if it works. Would need a bit of courage to try though
#5 (permalink) | |
Poachers Place!
![]() Join Date: Sep 2006
VindianaJones: |
#6 (permalink) | |
#8 (permalink) | |
btob
![]() Join Date: Jan 2007
Get ahold of 'texas metrics'. He's accomplished this on V2K's and 900's. He's a member of our forum, his name is Ed Macri. |
#9 (permalink) |
Poachers Place!
I never had any problems with my 800 bottoming out at 1.5" lowered, even with a passenger but my 900 will bottom out with a passenger at 2" so i have to be very carefull going off curbs and turning right. Its fine with just me on it though.
VindianaJones: |
#10 (permalink) | |
Reason I was asking is because everytime I go thru railroad tracks or speedbumps I have to lift myself up a bit so it wont hit hard. She is dropped 2 3/4" in the rear. I have the preload on the spring at the stiffest setting. Oh well, it looks good though. LOL
82 kz1000p |
#11 (permalink) |
There are preload kits available at Scootworks that will prevent the bottoming out issue. It makes the shock stiffer. Almost the same is also included in the Highway Hawk lowering kit.
#13 (permalink) | |
#14 (permalink) | ||
82 kz1000p |
#15 (permalink) |
I know what you mean about parts, I've been researching what I need for months and am still yet to nail down everything. At least I have a few packages on the way from the US at the moment so I can make a start.
| ZX-6R Front End Lowering | J The Engineer | Kawasaki Streetbikes/Sportbikes | 14 | 10-29-2007 06:52 PM |
| Lowering an 800a | boudro | Kawasaki Cruisers | 10 | 12-31-2006 09:56 PM |
| lowering the zzr1200 | olscoolkawi | Kawasaki Touring and Sport Touring | 0 | 08-31-2006 01:00 AM |
| Lowering Links 05 ZX-6R? | 03SSgt-1 | The Mechanics Corner | 0 | 02-19-2005 05:23 PM |
| VN800 and belt drives | mstute | The Mechanics Corner | 0 | 10-16-2004 09:34 PM |
