Old 05-01-2007   #1 (permalink)
Woody61
What can I spend my $$ on
Woody61's Avatar
Default Easy Brackets question
Tried putting on my easy brackets tonight and they went on easy enough but they rattle like hell. Any tricks to snug them up? I called easy brackets and left a messege earlier today, hopefully they call back tomorrow. If the bracket was 1/32 thicker or the slot in the docking post a little narrower it would be perfect. Also got my mustang seat.....SWEET!
06 900 Classic Ocean Metallic Blue
VNOG # 95
VROC# 24725
Woody61 is offline   Reply With Quote
Old 05-01-2007   #2 (permalink)
trikebubble
RIP Brother Deron
trikebubble's Avatar
I don't know about the EasyBrackets, but my GhostBrackets have a little play where the key latch tab slides under the post. Look at where the key latch tab locks the bags in place and see if their is play there.
I was able to gently bend the tab up a bit, to minimize the play. Too much and they will not lock however.
2005 V2K Ltd
"I'll ride the wave where it takes me, I'll hold the pain release me"
trikebubble is offline   Reply With Quote
Old 05-01-2007   #3 (permalink)
CootoronScooter
One of Four
CootoronScooter's Avatar
I had the same problem. The bags I used have a tie down tab on the bottom. I ran a small bungee from the bottom of the bags to the braces under the fender. It helped keep the bags from rattling around. That's all I could come up with.
CootoronScooter is offline   Reply With Quote
Old 05-01-2007   #4 (permalink)
dickwol
Wants better weather!
dickwol's Avatar
You should not have any play in the Easybracket. At least not where you would hear any rattle. Mine were too tight making them a bit of a hassle getting on and off but there was never any noise. Apparently there is a screw where you can adjust the locking latch upwards or downwards depending on where you need it to go but the bracket has to come off the bag to get to it.
1999 Vulcan Classic 1500
V&H Longshots w/quiet baffles
Stage 1 jet and K&N
Progressive springs
F&S Lightbar and Memphis shades Slim
Rigid bags w/Easy Bracket mounting system
dickwol is offline   Reply With Quote
Are you happy with the Mods you've done?? OldStreak Kawasaki Cruisers 37 05-21-2008 12:24 PM
Homemade easy brackets? S.D.Willie Kawasaki Cruisers 14 11-20-2006 01:28 AM
Ghost Brackets sheulett Kawasaki Cruisers 16 07-10-2006 01:39 AM
One easy question about upper fairing winger The Mechanics Corner 0 05-16-2005 02:28 AM
another easy question nemethjames1 Kawasaki Streetbikes/Sportbikes 4 02-21-2005 11:29 AM
