Uncle Bob's Love Child
Hi Mummz,
I had a rear misfire on mine, I swapped the plugs (front to rear, rear to front) as a test. When moved to the front cylinder, offending plug still would not fire. Changed both plugs and no problem since. |
#4 (permalink) |
Scooter Trash!
Which bike? Most metric twins have one coil per plug, sounds like you have an 800 or 900 if it is single plug.
Go one heat range hotter on the rear plug. If you have an 800, that would be a CR6E instead of the stock CR7E. Not sure what the 900 takes plug-wise, haven't messed with one. If it still fouls out and stumbles/misfires, get a mechanic to check it out. -Scruffy
Eagle Scout. Veteran. Patriot Guard Rider. 1950s style Savage barhopper 1950s style VN800B bagger |
#5 (permalink) |
Banned
Probably should have mentioned '02 Vulcan Classic 800. My concern is that it misfires badly at idle but drops off when cruising, unless at bottom end of gear. I don't think it has anything to do with mixture, but upon inspection of carb noticed had been rejetted, 162.5 for main and 48 for pilot, sounds right, but needle clip placement is on the second setting from top with two washers on top of clip ... wondering if that all adds up.
#10 (permalink) |
Banned
Yes I am getting spark to the rear plug, I found a loose connection in the spark plug wire so I put new wires on both. Also found another piece to the puzzle, at about 1/3 to 1/2 throttle (acceleration) the carb spits back into the air cleaner, after all I have done and all the things that I have checked I still find raw fuel in the air cleaner. I think it might be leaning towards a valve adjustment, and maybe some more tuning to the carb thanks for the link.
#11 (permalink) |
yellow doesn't corner wel
do you not have a shop close by? some problems need hands on bike in front of you to properly diagnose.
getting pushy don't help either.
Darrell Ignorance is a disease my friend. You should rid yourself of it. |
#12 (permalink) | |
| Heavy Cruisers & Brakes | LordGT | Kawasaki Cruisers | 57 | 08-02-2008 02:14 AM |
| VN2000 rear noise gone--for now | snw1953 | Kawasaki Cruisers | 2 | 04-02-2007 05:52 PM |
| Shifting/braking | StangGT | Kawasaki Streetbikes/Sportbikes | 33 | 10-01-2006 11:20 PM |
| 750 Vulcan rear end tear down & Motorcycle Lift | 2WheelFun | Kawasaki Cruisers | 4 | 09-26-2005 10:04 AM |
| WTB: rear seat and rear pegs for '03 zx6r | import monkey | Accessory Swap Meet | 0 | 08-12-2005 02:15 PM |
