LinkBack | Thread Tools |
Over the weekend I tried to install my new Kury Large Magnum Plus Convex mirrors on my 06 Nomad and ran into a problem. I got the throttle side mirror on and adjusted no problem. When I tried to put the left side one, nothing but trouble. I tightened the stem onto the bolt that goes into the handlebars, then tried to tighten the screw with an allen wrench that keeps the stem from coming loose. I ended up stripping this screw and the stem still came loose. I then tried to take the stem back off and start over, but I ended up breaking the bolt inside the stem. Not a good thing. Long story short, I have to new buy a replacement stem and bolt to install my mirrors. Back to the stocks for now.
What frustrated me is the screw inside the stem meant to tighten against the bolt to keep it from unloosening. There is nothing stating what size it is. I tried what I think was the right allen wrench, but ended up stripping it. I was thinking about when I try the install again, I forgo trying to tighten this screw, and maybe using Loctite instead. Does anyone have any experience using Loctite? If so, which one should I use? I know several people who have installed aftermarket mirrors, and they are forever having to re-tighten them because they come loose and start spinning around while they are cruising. Has anyone else installed these same mirrors? If so, how has your experience been with them in regards to them staying put, vibration etc. Thanks |
#4 (permalink) |
Non Omnis Moriar
Well, that sucks. I have no idea why you had that problem. I haven't changed the mirrors on my Nomad, but I've done it with other bikes with ease. Maybe it was just one of those days, huh?
#6 (permalink) |
see ya Thursday
I've used loctite on msny things works graet for me I used it on my hypercharger and nothing ever came lose a little hard to break lose but not that bad don't know if it was the right kind but i use the blue bottle on evreything. sorry that things are going wrong but when you get it done at least you'll have a story to tell
| Test ride on Nomad today! | x-wing | Kawasaki Cruisers | 22 | 10-03-2007 08:11 PM |
| Nomad oil leaks? | webby | Main Lobby | 23 | 03-28-2007 10:08 AM |
| New member, new Nomad!! | gnomad | Kawasaki Cruisers | 27 | 03-26-2007 11:04 PM |
| 1600 Nomad Replacement Windshield | Plato | Kawasaki Cruisers | 12 | 03-11-2007 10:22 PM |
| idle/carb problems | babee_huey | Main Lobby | 3 | 08-12-2004 12:34 AM |
