#21 (permalink) |
'08 VN900 Classic
What do you know - the problem seems to be epidemic...
(the purple feet are my little girl's) Looks like it doesn't snap off, it must just vibrate out - there's no collar of remaining fitting up there - just dirt. |
#22 (permalink) |
Stealth Custom
![]() Join Date: Jul 2007
yeah, yeah.......we know those are your hardcore biker pj's........
MeanCyclesGallery |
#23 (permalink) |
'08 VN900 Classic
So - I'm off to the store this week for replacement grease zerks. Should I just put some in, replace the grease & walk away or remove them afterward and put some bolts in there?
Snapping one off seems very possible considering the location. |
#24 (permalink) |
Kimberly Dawn 1966 - 2009
If you can get matching SS bolts, I would put them in and grease up then replace with the bolts until the next maintenace. Just remember to add a little blue locktight and maybe a lock washer.
#25 (permalink) |
looking at the picture again, I might just take the rocker arm off and give it a good cleaning..
You don't know how long the zerk has been missing and how much mud and grit has been pushed up there. Adding new grease will just make it grind down faster. ![]() |
#27 (permalink) |
'08 VN900 Classic
You've exceeded my wrenching skills with that one, I think. I was going to try to brush the visible grit out with a little wire spark plug brush and just force enough grease in there 'til it comes out clean.
#28 (permalink) |
It should not be that hard if you have a Clymor or the Service Manual. Should be same as changing the shock, just a few more bolts.
You will however, have to have the rear tire off the ground. That can be done with a standard garage floor jack and some wood blocks. |
#29 (permalink) |
Hail the DOD
I was going to replace my middle nipple with a bolt, until I measured the rocker arm which extends down below the frame and the nipple.... Assuming that I really did knock it off originally...
I bough extra nipples, incase I'm wrong...
Mike 09 VN 900 Classic LT |
#30 (permalink) |
I don't think it is as much as hitting something sticking up that counts, but more of bottoming out the suspension on the bike, say going over a speed bump that will rip it off.
It would be harder to break off the head of a bolt verses the zerk fitting. Just my 2 cents. |
#31 (permalink) | |
Wants better weather!
Tony 1998 VN800B |
#32 (permalink) |
Biking Old Timer
I've had to replace the center one like so many of you. I have noticed that speed bumps and drain depressions in front of driveways are potential problems. I've set the shock as stiff as it can get, not sure I like the way the bike handles that way. My dealer was super nice and replaced the first one for me. I did find that I snapped one of them putting up on the bike lift in the garage. I changed the lifts ramp angle and cured that. That isn't an option with speed bumps and the like. I think I have to agree withe the design flaw possibility. These could have been positioned with two facing forward and more horizontally oriented. The rear one could have been positioned horizontal and aimed to the rear. Just a thought, I might have to see if this could be removed and have the original positions heliarced closed and rebore and tap new positions for the zerks.
Peter The Highwayman |
#33 (permalink) | |
Hail the DOD
#34 (permalink) |
Stealth Custom
just dont do what this guy did.........
Grease-gun injury to the *****
MeanCyclesGallery |
#36 (permalink) |
Stealth Custom
LOL......i did a search on grease guns to get an idea of cost and this came up.....
MeanCyclesGallery |
#37 (permalink) |
'08 VN900 Classic
Well - here's something interesting. If you look at this picture, you can see what looks like dirt on the flat-machined part of the hole...
...it's not dirt - it's where that face has been broken off - it's a divot in the metal. I removed one of the other zerks to get the size and test fitted it into the center hole. It seems very loose but I didn't try snugging it down at all. I'm wondering if the threads are damaged. (The parts diagrams shows all three using the same size nipple - which was my first thought.) I'm stopping through NAPA on the way home to get a couple nipples and will clean those threads and try to get a new one to fit in there. I'm hoping this doesn't have to be tapped for a new one if these threads are damaged. For what it's worth, by the way, the shop manual says "nipple", not "zerk". |
#38 (permalink) |
VN900 Classic 2008
Well here's some good news - not only has the middle nipple snapped off it's taken part of the mold with it:
Silly question but what are the grease nipples for and do you grease the nipples or remove them and grease inside??? Any advice guys Needles
'I have slipped the surly bonds of earth, put out my hand and touched the face of God.' Last edited by needles : 03-31-2009 at 01:38 PM. |
#39 (permalink) | |
'08 VN900 Classic
If it's too far gone to hold a shallow nipple, it may be deep enough for a longer bolt (to seal the hole) and you could drill and tap a new nipple into it. EDIT: And grease nipples are used to inject new grease into non-sealed systems. If you've got sealed bearings, then the grease just lives in there - if they're not sealed then the nipple is used as an injection point to put new grease in and force old, dirty grease out. Last edited by Belrix : 03-31-2009 at 01:52 PM. |
| A video of AweSix's arm breaking | AweSix | What I learned today | 18 | 12-04-2006 02:14 AM |
| grease nipples | Pooker | The Mechanics Corner | 5 | 07-02-2006 08:28 AM |
| swing arm "?" | cdn.zx.Glen | Kawasaki Streetbikes/Sportbikes | 3 | 06-26-2006 09:41 AM |
| swing arm grease | stew | Kawasaki Cruisers | 17 | 04-24-2005 01:12 AM |
| Grease under bike!! | ZX6RRNewbie | The Mechanics Corner | 5 | 10-01-2004 12:32 AM |
