#41 (permalink) |
VN900 Classic 2008
Cheers Belrix
Have read the Wiki link and am up to speed Just going dark here so will take a shot tomorrow and post it Thanks for you replay Needles
'I have slipped the surly bonds of earth, put out my hand and touched the face of God.' |
#42 (permalink) |
Trusted SW Pulley Adviser
When I replaced my center Zerk the new ones fit tighter than the stock nipples. Because of that, I was able to get the new one to screw in firmly.
How do I know how much grease to inject into each fitting? Can you see the old grease being squeezed out somewhere? I need to grease mine as one of the last things to do on my winter list. |
#43 (permalink) | |
'08 VN900 Classic
For the rocker arm it has grease nipples [A] on the rockerI used to force in enough until you see a color change, fresh grease coming out where the older grease is usually darker. EDIT: Disclaimer: this was on my old truck, not my Kaw. Last edited by Belrix : 03-31-2009 at 02:39 PM. |
#44 (permalink) | |
Kimberly Dawn 1966 - 2009
+1 on the article.. Still think from the damage I am seeing on a few of the pictures, I would grease up the swing arm and pull the zerk "nipple" out and replace with a SS bolt with a hex head. |
#45 (permalink) |
'08 VN900 Classic
I finished the fix tonight.
I sprayed out the hole with WD-40 - lots and lots of it - trying to flush out any dirt that might be in there. I then put in a new zerk from the local auto-supply. "Metric" seems to be enough to get one although, if you have a choice, it's 6mm. The replacements seem to have more thread than the original so it's deep enough to catch threads deeper than the damaged area. I filled it with grease and capped it. I then "topped off" all the other fittings, and there seemed to be plenty of air in each one, and then pulled the rear two zerks and put two stainless bolts in. The front one seems high enough to not catch on anything in the future so I left it alone. |
#47 (permalink) | |
![]() Join Date: Jan 2009
6mm ? Do you know if there is more than one thread pitch in this size? How long are the SS bolts that you used? Looks like a great fix. With your help, I think I'll try it. -Dwain |
#48 (permalink) |
Enjoying midlife Crisis!
Yes, if you can specify the exact ss bolts used, that'd be much appreciated. I'll need to pick some up to do this mod.
Regards, Ersterhernd
'07 900 Classic LT Ebony/Silver |
#49 (permalink) |
Cruising In Fourth Gear
Ya know... even before this thread I noticed those grease zerks while I was under my 900LT changing the oil I saw them things poking down like nipples on a sow and wondered "WTF" are those zerks doing there???
I'm thinking some Kawasaki engineer(s) needs to get kicked in the 'nads for placing the two lower zerks where they did. I'll be replacing those two lower zerks as soon as I get them greased up and I learn what the thread pitch it on those 6mm bolts.
'08 Vulcan 900 Classic LT White/Titanium Anyone else in Sioux Falls? |
#50 (permalink) |
Stealth Custom
![]() Join Date: Jul 2007
so how much does a grease gun cost? and can i get it at any auto parts store?
MeanCyclesGallery |
#51 (permalink) |
Carbon Based Life Form
A cheap gun will cost 15-20 bucks with 1 or 2 tubes of grease.
I will keep my Freedom , Money and Guns; you can keep the "Hope & Change". |
#52 (permalink) |
'08 VN900 Classic
It's a 6mm x 1 bolt - about 1 cm long. At 1 cm it's a bit long but seems to seat OK. I used a split ring washer to discourage backing-out and to absorb a bit of the length. I used the split ring since I was pretty sure lock-tite was useless in a place as greasy as this.
The gold colored zerk is from the auto-parts store, the steel-colored one is the stock one. As you can see, the replacement is slightly longer than the stock one. EDIT: Recommend rubber gloves for putting in the grease. It gets everywhere and it stinks. Last edited by Belrix : 04-01-2009 at 12:24 AM. |
#54 (permalink) |
I was at D.O.D #1!
Belrix! and others who are about to attempt this....
I hope you realize that WD40 is effectively a DEGREASER...and spraying it up into there will cause the grease to rapidly break down. Use it sparingly at best, and it might be a good idea to change that grease in the near future.
1998 Vulcan 800 classic "Grit, spit, and a whole lot of duct tape!" My motorcycle pics! |
#55 (permalink) | |
Bridal Boutique Manager
Ken 2007 Vulcan Classic 900LT |
#56 (permalink) |
'08 VN900 Classic
I knew that WD40 is a degreaser but I couldn't think if a way to get that dirt out otherwise. Water, IMO, would be a bigger mistake and leaving the dirt in there also one.
It's a good idea to get more grease in there later, though. |
#57 (permalink) |
or just keep pumping it full of grease, it wont break down the grease that much at least not enough quick enough to cause problems I wouldnt think. I'd just keep pumping it full this summer ever few hundred miles and be done with it.
Many dont realize the negative effects of WD40. It is good stuff for the right jobs. I cringe every time I hear someone using it as a gun lube, too.
#58 (permalink) |
'08 VN900 Classic
Well - maybe I did well accidentally. I didn't use really WD-40, I used what I thought was a cheapie equivalent, something called Jig-a-Loo. I couldn't remember the name last night and didn't want to go out the garage to check. I figured calling it WD-40 would be close enough.
Looks like it's non-solvent, says the website. The carrier for it seemed strange - very cold leaving the can - some sort of rapidly-evaporating, freon-like stuff. Maybe I don't have to worry about the grease breaking down. Website |
| A video of AweSix's arm breaking | AweSix | What I learned today | 18 | 12-04-2006 02:14 AM |
| grease nipples | Pooker | The Mechanics Corner | 5 | 07-02-2006 08:28 AM |
| swing arm "?" | cdn.zx.Glen | Kawasaki Streetbikes/Sportbikes | 3 | 06-26-2006 09:41 AM |
| swing arm grease | stew | Kawasaki Cruisers | 17 | 04-24-2005 01:12 AM |
| Grease under bike!! | ZX6RRNewbie | The Mechanics Corner | 5 | 10-01-2004 12:32 AM |
