#64 (permalink) |
I was at D.O.D #1!
there are 2 pitches available in metric sizes: 1.0 (course thread) and 1.5 (fine thread) What you need is the 1.0 course thread.
1998 Vulcan 800 classic "Grit, spit, and a whole lot of duct tape!" My motorcycle pics! |
#66 (permalink) |
Highlander
I'm looking at the 49001-0001 grease fitting I bought from the dealer and the threads look straight. Course thread as mention. I thought regular grease fittings were fine thread tapered.
I pulled in a parking lot from the street and ran in a large deep pot hole and the bottom of my bike scraped badly. I'm going to have to paint my frame and motor black again. Also smashed the center grease fitting. it's probably the closest part to the ground except for the tires.
Silver Wolf |
#67 (permalink) |
Baaaaaa means Noooooo
greasenipples can come in either the straight or tapered variety, i'm wondering whether someone can confirm for sure that it is a coarse bolt thread and not a pipe thread.
EDIT Sorry I must have missed the part where you said you got it from the dealer, i suppose you would know! Just To be 100% tho does it say NPT anywhere on the packaging? Thx Last edited by Astrocreep : 04-02-2009 at 09:52 PM. |
#68 (permalink) | |
Highlander
Next time I go to home depot, they have SAE & metric nuts that you can screw your in item your not sure of and find the matching thread. Someone said 6mm coarse. I'm going to check that out and go to NAPA to check them out. Dealer charges way to much for grease fittings. Cheap ones at that. Does any body remember what 900 seat bracket you can order to fit a 2006 classic? I thought a KZ1000 bracket was the one.
Silver Wolf |
#70 (permalink) |
Hail the DOD
I started getting ready to fabricate a skid plate for my rocker arm from the left over aluminum used on my hand made lowers.... went to the hardware store for flat head screws and found these set screws, 6mm, fits just right. Put some blue locktight on and screwed flush with bottom... ready to go..
Mike 09 VN 900 Classic LT |
#71 (permalink) |
'08 VN900 Classic
Whoa! Very good idea. I might go back for those...
...on the other hand, the hex head of the bolt I used might protect the machined face in the event of a strike. So - the choice is, hang a bit lower but armormed or be as smooth as possible but not as protected. |
#72 (permalink) | |
Highlander
Right now I'm repainting the bottom of the frame with a paint brush to cover the deep scratches/groves where it had bottomed out in the pot hole. No one can see the under the bike unless they get on their hands and knees.
Silver Wolf |
#73 (permalink) | |
Hail the DOD
Mike 09 VN 900 Classic LT Last edited by Hardwire : 04-03-2009 at 08:40 PM. |
#74 (permalink) |
Highlander
It only scraped the gusicks " can't spell it" on the motor.
The right side frame and food board. When pulling off the road the bike goes up and big big hole was on the down side in the drive way. Normal riding I would have not scraped the bottom so bad.
Silver Wolf |
#75 (permalink) | |
Hail the DOD
#76 (permalink) |
Trusted SW Pulley Adviser
The set screws are a good idea but I wonder if rust and corrosion would be a problem since these are not SS? If they lock up in there it would be more difficult to get them out than a bolt with a hex head. I think I am going to use the SS bolts on mine.
#77 (permalink) | |
Hail the DOD
#78 (permalink) |
You guys think too much, just dab a bit of grease on the hex head and youre good to go. I would not use SS screws at all, SS threads are notorious for galling and when you go to take the screws out later they just may take the threads in the cast steel with it.
#80 (permalink) |
Sorry I just assumed the rocker arm was cast iron or steel. Correct me if im wrong but is there not a galvanic reaction aswell between SS and aluminum? I'm fairly certain there is, and since its aluminum that means brass is out too. This is getting complicated. Aluminum may be the only choice here.
| A video of AweSix's arm breaking | AweSix | What I learned today | 18 | 12-04-2006 02:14 AM |
| grease nipples | Pooker | The Mechanics Corner | 5 | 07-02-2006 08:28 AM |
| swing arm "?" | cdn.zx.Glen | Kawasaki Streetbikes/Sportbikes | 3 | 06-26-2006 09:41 AM |
| swing arm grease | stew | Kawasaki Cruisers | 17 | 04-24-2005 01:12 AM |
| Grease under bike!! | ZX6RRNewbie | The Mechanics Corner | 5 | 10-01-2004 12:32 AM |
