#81 (permalink) |
Sit speling cheker
Just did the swap. I was pleasently surprised that the whole zerk fitting was missing. I was sweating bullets that I would have to extract the broken grease fitting. I just ran a 6mm x 1.0 tap in the hole to clean up the threads, flushed it out with brakekleen, greased all three points then installed bolts in the two low locations. I did use never seize on the bolt threads since I am concerned about the aluminum to steel reaction. Took less than 20 minutes including two trips to the fridge for "Kool-Aid"
#82 (permalink) |
Third Gear And Gaining
First off what would you do with a third nipple eneyway? And to answer the question yes mine broke off within the first 1000 miles,I replaced it with a new one and last time I was changing the oil I saw that it was gone agian. I to think that it was a bad design.
#83 (permalink) | |
Highlander
The stock one are cheap cheap material, but being straight thread they are easy to remove where broke off. One member replaced the fitting with a flush plug.
Silver Wolf |
#84 (permalink) |
Don't call me a
I'm gonna revive this thread because yesterday I went over a speed bump at a hardware store (think they made it tall & narrow on purpose?) and bottomed out. Pulled around to check it out and discovered the middle grease zerk missing - ripped completely out, left a little thread damage. Looks just like Hardwire's on p.1 and Belrix's on p.2.
So who's supposed to put grease in there? Looking up the hole with a flashlight and small mirror it's clean and shinny. I removed the rear zerk - same thing. I've got it plugged with a bit of duct tape now to keep road junk out. I'm gonna grease them up and do the Belrix fix on p.3. The hole is threaded beyond what the zerk will reach (and damage) and I'd like to use it. Thanks to Hardwire and Belrix for making this thread all that needs to be said and shown on this common problem. Now go check your udder.
'07 VN900 Classic '99 Rebel 250 '73 XL175 |
#85 (permalink) |
Yup... real common issue, and it's a really stupid design.
They should have cross-drilled the arm to connect all 3 chambers and mounted a single nipple in a protected area. But at least you have one. On the 1500/1600, we have to remove the swingarm and grease the needle bearings by hand... but honestly, once the rear tire is off, 75% of the job is done, and we need to inspect the u-joint and lube the driveshaft splines anyways, and the easiest way to do those is to remove the swingarm.
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
#87 (permalink) | |
Hail the DOD
Mike 09 VN 900 Classic LT |
#88 (permalink) |
Late starter...
Checked my 07 today and all was good ( 3 fittings and full of grease). I didn't want to push my luck so I did the hex head bolt swap on the lower 2........
07 900 Classic Titanium Metallic 06 Yamaha Majesty 400 Candy Red |
#89 (permalink) |
Can't find time to ride
Gonna check this today after work. Can anyone tell me if the 3 nipples on the rocker arm are the only grease fittings on the bike, or are there more that i need to maintain?
Chris 07 900 Custom, Candy Plasma Blue |
#90 (permalink) |
I think that's it, maybe two on the swingarm pivot. If there aren't, then the swingarm should be pulled every 15k or so and the needle bearings greased (I do mine every rear tire change since 75% of the work is done when the tire is off).
#91 (permalink) |
Politicians' Nightmare
Since periodic maintenance includes repacking the steering stem bearings Kawi should have installed appropriate zerk fittings on the steering head.
Jim '07 Vulcan 900 Classic LT Jesus is Lord |
#92 (permalink) |
Bridal Boutique Manager
Everybody seems to be quite concerned about the aluminum to steel reaction.
What do you think the zerk fittings are made from? (Hint:I bet it's not aluminum.)
2008 VN900 Classic |
#93 (permalink) |
Rockabilly biker
Yup mines was missin also and I replaced it but I couldn't get as much grease in as I would like. I pumped some in but it didn't squirt out anywhere. I will have to take it out and make sure it isn't plugged or somethin.
"My yard is my flag" Hank Hill |
#94 (permalink) | |
Enjoying midlife Crisis!
Mine's coming apart this winter when the insurance expires for the season. It'll be a couple of thousand km overdue, but thats ok.
'07 900 Classic LT Ebony/Silver |
#95 (permalink) | |
#96 (permalink) |
I noted the same problem as others have with their VN900s - the points to be greased were dry when I got the bike from the dealer. I've since pumped quite a lot of grease into the fittings. So far none has broken off, but I'm going to do what has been suggested - replace the fittings with short bolts until servicing time.
#97 (permalink) |
Ed Scott - Old-Time Biker
Yup I broke mine right after lowering the bike 3" and then went over a bad slant into a parking lot. I try to hit quick rises like that at an angle now.
Has it ever occurred to you how long our nation would last if NOBODY supported our troops? My Photos |
| A video of AweSix's arm breaking | AweSix | What I learned today | 18 | 12-04-2006 02:14 AM |
| grease nipples | Pooker | The Mechanics Corner | 5 | 07-02-2006 08:28 AM |
| swing arm "?" | cdn.zx.Glen | Kawasaki Streetbikes/Sportbikes | 3 | 06-26-2006 09:41 AM |
| swing arm grease | stew | Kawasaki Cruisers | 17 | 04-24-2005 01:12 AM |
| Grease under bike!! | ZX6RRNewbie | The Mechanics Corner | 5 | 10-01-2004 12:32 AM |
