What is everyone using to replace the non-usable headlight (lowbeam) on the 900? I ride with High beam on and only go low beam to avoid blinding someone. I've tried adjusting it but then the high beam lights up the sky!
Yourkillinme |
What can I spend my $$ on
![]() Join Date: Apr 2007
I go back and forth depending on conditions. Replaced the factory bulb with a silverstar as it is a little brighter. Also, do a search as there was another thread not to long ago on the same subject.
06 900 Classic Ocean Metallic Blue VNOG # 95 VROC# 24725 |
Can't find time to ride
its not the bulb, its the reflector in the head light. its designed to shine that way. I'm on my 3rd bulb, makes no diffence. I will be replacing the headlight with aftermarket headlight to rid this problem.
others say that adding a lightbar helps alot |
#5 (permalink) | |
Wants better weather!
It's a bright white light and you'll have no problems on low beam w/ one of these. I replaced my headlamp w/ one of these and also the stop-tail bulb w/ Sylvania 2357 LL $2.79. The taillight is the same brightness, but the stop is brighter. Good safety upgrade for little $$$.
Former '06 900 Classic owner |
#6 (permalink) |
Uncle Bob's Love Child
Or check out XenonLink.com HID Conversion Kit. and get a HID light for less than $100.
2003 Vulcan Nomad, V&H Baggers, Harley Trunk, Xenon HID Headlight, Ultra Classic Fairing |
#7 (permalink) |
![]() Join Date: May 2006
Go with a BP1210 Wagner Bulb.
You can get them from NAPA. It's 80w on low beam and 100w on high beam. I've had one in for over a year now....no problem. It is very bright compared to the stock bulb.
2008 VULCAN 1600 NOMAD |
#8 (permalink) | |
Stealth Custom
![]() Join Date: Jul 2007
MeanCyclesGallery |
#9 (permalink) |
Yes I do.......there is another thread about this here, http://www.kawasakimotorcycle.org/fo...piaa-bulb.html
#10 (permalink) |
Old Dude
+1
http://s28.photobucket.com/albums/c202/barrynfla/ Black '07 Nomad Blue '06 900 Classic |
#11 (permalink) | |
Stealth Custom
and how is the install, plug and play? Sorry for all the questions.......
MeanCyclesGallery |
#12 (permalink) |
I got the 8000k (blue white), no installations issues everything is "plug-n-play", and the look is great IMHO. Brighter than halogen, runs cooler, and the color attracts attention.
#13 (permalink) |
There are a lot of misconceptions and myths out there concerning enhancing the useable light output of a vehicle. These misconceptions and myths apply to any vehicle cycle, car or truck.
Here is some information that might be helpful if you’re thinking about upgrading your headlight. Misconception #1 - Over wattage bulbs gives more light. Fact: To a point this is true. However, useable light output is a combination of bulb output, headlight reflector and lens. If you have a poorly designed lens, putting a high output bulb will create more glare than useable output. Fact: Most factory headlight wiring harnesses are not designed to handle high output bulbs safely and provide full voltage. They really don’t handle stock bulbs all that well. Fact: Over wattage bulbs are illegal Fact: Over wattage bulbs tend to have a very short lifespan Fact: In some cases, over wattage bulbs can melt your headlight lens and socket. Misconception # 2 - My factory wiring harness can safely run over wattage bulbs because the factory fuse will handle the load. Fact: The factory wires are very thin. I have seen 18-20 Ga wire feeding headlights. Putting a higher load through thin wire causes resistance. Resistance causes heat (dangerous), more resistance and voltage drop. Lower voltage reduces the light output of any bulb. At cruising RPM’s, my Vulcan 900 puts out 11.2 volts at the high beam. Most vehicle charging systems put out 13.2 – 13.4 volts. The net effect on light output (lumens) drop exponentially with the drop in voltage. Here are some numbers; 10.5V : 510 lumens 11.0V : 597 lumens 11.5V : 695 lumens 12.0V : 803 lumens 12.5V : 923 lumens 12.8V : 1000 lumens 13.0V : 1054 lumens In my case, 30% - 40% of my bulbs output has been “lost” because of thin wire. Misconception #3 - Blue bulbs give better light. Fact: There are thousands of pages of documents having to do with light output and color. It is true that higher temperature bulbs (4300 K HID systems) produce a bluish color. A number of companies such as PIAA, Osram and Philips and others sell “blue” bulbs. They get the blue color by coating the bulbs, not by temperature. It is the 4300 K temperature of an HID system that produces the bright like. Not the blue color. I have read a number of independent lab reports testing “blue” bulbs. They all come back with the same result, junk. They all actually produce less useable light than good quality standard bulbs. Misconception #4 – Retrofitting to HID is a great option. Fact: Retrofitting to a HID system is illegal. Fact: The beam output of a HID system is completely different than a conventional bulb. So the headlamp lens on your vehicle was not designed to properly focus the light in a proper, legal pattern. The lens of your headlight is similar to eyeglasses. Imagine wearing glasses designed for someone else’s eyes. To produce the highest legal output on my bike, I am doing a couple of things. I am adding a light bar and upgrading the bulbs to 35W. I have also built a prototype wiring harness for my light bar and headlight. This kit has marine grade 16Ga wire, Bosch (now Tyco) relays and separate fused circuits for the light bar, low beam and high beam. I am also reviewing a number of high quality legal bulbs available by my supplier. I hope this information is helpful. |
#14 (permalink) |
Stealth Custom
^^So what do you think of these kits?
MeanCyclesGallery |
#15 (permalink) | |
Living the Dream!
In addition I have the Signalminder Turn signal cancelling unit installed which converts my rear directionals to always on running lights. Any extra visibility is a plus in my book. As an added bonus the signalminder has 4-way flasher functionality and parade mode (alternating left-right directionals) built in. Works for me, Mark
Mark '06 Vulcan 900 LT Red/Black When you come to a fork in the road, take it! |
#16 (permalink) | |
Stealth Custom
what part of LI are you located?
MeanCyclesGallery |
#18 (permalink) |
Stealth Custom
Thats a long ways from me......
Im in Valley Stream.....
MeanCyclesGallery |
#19 (permalink) |
Rebel Rider
The Wagner 80/100 H4 is much brighter than the stock. It is legal. I had one in my 800 for 2 years without a problem with the harness, lens or socket.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
| Brighter Headlight Bulb | REFUGIO | Kawasaki Cruisers | 143 | 06-30-2009 05:21 PM |
| Headlight Bulb | Trashman900C | Kawasaki Cruisers | 2 | 07-27-2007 01:08 AM |
| 900 custom headlight | fidgit | Kawasaki Cruisers | 9 | 05-11-2007 11:23 AM |
| 800 headlight replacement | RWJC | Kawasaki Cruisers | 8 | 11-21-2006 07:18 PM |
| Headlight bulb 800A | bluestringer | Kawasaki Cruisers | 30 | 10-05-2005 12:07 PM |
