Xpylut
Well today I did the first work on my V2K that wasn't a simple "bolt on" mod. What i ended up with seriously disturbed me. Really has me wondering what Kawasaki was thinking.
In the headlight bucket we have 2 "4 pin" flat connectors, described as accessory connections. I metered out the one with red wires, all 4 wires were hot. Well I hate vampire splices, so I snipped one with the expectation that I would crimp a Trail Tech connector on it. This would then power my Cobra lightbar. Well - wrongo Kawasaki breath - this connector with 4 wires has only one true hot wire, the other 3 fed internally by the connector. So no big deal...... Here's the gotcha - this connector is part of the tail light and brake light circuit. ALL FOUR WIRES ARE REQUIRED TO BE INTACT TO FEED THE TAIL LIGHTS. I would expect my tail lights and brake lights to be on a dedicated, isolated circuit, not incorporating some ACCESSORY feed in the headlight bucket. So as it stands now, if my lightbar causes a fuse to blow, I have no rear lights at all. Now the real pi$$er to me is that to get at a fuse, I need to - 1) pull the right side cover 2) release the back seat (cable pull) 3) remove the front seat (2 bolts) 4) remove the left side cover screw 5) NOW access a fuse Not very good engineering on their part. Well I see my project list starting for the winter. That lightbar comes off that circuit. I'm going to look at the mx manual again this evening to see where I missed that. Be VERY careful with your wiring. They are doing some strange things with it.
06 V2K Classic LT 06 VTX 1300R |
Beast Master
well, actually its not really that bad, where else are they going to put it? at least the fuse panel and relays are covered and not in the open, remmber there is not a lot of places to hide things on a bike.
09 Concours Black ABS Accessories, Risers, Grip Puppies & Peg Lowering Kit. |
#4 (permalink) |
Xpylut
fuses are typically hidden under side covers that are removeable.... this is not normal, having to remove both side covers and both seats to gain access. the whole thing about sharing an accessory with my brake lights has me shaking my head in disbelief. typically the brake and tail light circuit is dedicated and isolated.
#5 (permalink) |
RIP Brother Deron
Tough break man, I bought the std. Bug-Eye headlight version...............which seems to come with an aircraft landing light for a headlight. No driving lights for me.
Hope you get it sorted out.
2005 V2K Ltd "I'll ride the wave where it takes me, I'll hold the pain release me" |
#6 (permalink) |
*** V2K Rocks!!! ***
![]() Join Date: Jul 2006
I installed an accessory fuse block where the OEM tool kit used to go:
http://www.kawasakimotorcycle.org/fo...tml#post632626 |
#7 (permalink) |
Rebel Rider
Gonzo is right, light bar should be on it's own circuit. Read up on doing the circuit on Gadget's site.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
#8 (permalink) | |
Xpylut
why did K put an "accessory" plug in the headlight bucket if it taps into the ESSENTIAL brake and tail light circuit? There is a 15 amp accessory fuse in the box - duh. I wouldn't think of wiring my airplane like that. Not even close to being right. I'm going to "FIX" this - it's going to rain here all week.
#9 (permalink) | |
Xpylut
#10 (permalink) |
I ride, therefore I am.
![]() Join Date: Jul 2004
FYI, you don't have to do all that. Just pop the left cover at the front and swivel it out. Try it, it works fine.
A day without a ride is like a day without sunshine.That's usually the reason, so it all works out. |
#11 (permalink) |
![]() Join Date: May 2006
On my 900 ...the accessary leads in the headlight bucket are on their own dedicated, fused circuit.
Are you sure you got the correct wires for accessaries? Never heard of the accessary leads being tied into the rear lights.
2008 VULCAN 1600 NOMAD |
#12 (permalink) | |
the main power would come from the battery with relay and fuse inline |
| Kawasaki can make you sick. | Uncle Bob | Off Topic | 20 | 08-12-2008 10:47 PM |
| Sat on a V2K today... | PainlessWolf | Kawasaki Cruisers | 73 | 08-05-2007 12:20 AM |
| King Kong vs Godzilla | LordGT | Kawasaki Cruisers | 59 | 08-22-2006 12:36 PM |
| Kawasaki customer Mid-Ohio track day $99 | extremelean | Main Lobby | 0 | 07-27-2006 09:24 PM |
