Old 10-01-2007   #1 (permalink)
PopJack
PopJack's Avatar
Default Gasp!! A Newbie Noise Question!
OK first Hello. I am a re-entry rider who bought an '02 1500 Nomad FI. It was well used with 25k on it, but runs wonderfully. The bike is more fun than I remember and I'm really enjoying it.
I have also enjoyed this forum and tried to lurk a little. That said I'd like to ask about engine noise (gasp.... an newbie asking about engine noise!). I hope this question is different enough to warrant a thread.
I have what sounds like valve ticking. I used a stick and it's definitely coming from the rocker cover area. I changed the oil to Kawa 10-40 and added a little Sea Foam to loosen up any stuck valves (probably "cage thinking"). The ticking seems louder.
Question 1: Can I be damaging the bike by riding it with a tick? The performance is wonderful and there are no other issues.
Question 2: Any oil suggestions for replacement? Will Thicker oil help? Synthetic?
Question 3: Can a mechanically talented old fart who knows car engines pretty well work on one of these with a shop manual, or are they the domain of factory trained and equipped techie-types?
Thanks for your replies.
PopJack the Newbie.
PopJack is offline   Reply With Quote
Old 10-01-2007   #2 (permalink)
Got2Go
What Curve....
Got2Go's Avatar
Have a look at this stickied thread:
http://www.kawasakimotorcycle.org/fo...ne-noises.html
But, its most likely the normal ticking noise they all make.
I Have Not Seen Yayo...
07 ZX-6R
07 Mean Streak Special Edition
Las Vegas Riders Meetup
Got2Go is offline   Reply With Quote
Old 10-01-2007   #3 (permalink)
c_law23
Missy Peregrym's #1 fan!
c_law23's Avatar
Send a message via AIM to c_law23 Send a message via Yahoo to c_law23 Send a message via Skype™ to c_law23
my 900 has a ticking noise that drives me insane but it always has and it only has 3000 miles on it
Chris
VROC #24810
Black 2007 900 Custom (sold)
c_law23 is offline   Reply With Quote
Old 10-01-2007   #4 (permalink)
kingofwings
R.I.P. Deron Harden
kingofwings's Avatar
PopJack the Newbie.
Welcome to the forum Jack,
1. Probably not. Mine (and countless others) have ticked since day one. Dealers say "they do that sometimes". I've got 35,000 miles on my "04 1600.
2. "Ask of oil and they will come". RichLockyer has done a lot of oil studies, check out this thread. Searching "oil" will make your head spin with so many hits.
3. For the most part, sure. Of course there are always funky tools and your digital FI might give you a migrane, but for the most part, keep your fluids changed and you are good to go.
Ride safe!
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
kingofwings is offline   Reply With Quote
Old 10-02-2007   #5 (permalink)
Aifwikir
Patriot Guard Rider
Aifwikir's Avatar
Send a message via Yahoo to Aifwikir
I own a VN 900 and from day one it's been ,,, shall we say NOISEY!! With my last service I had the dealer add 20w50 Kawi oil (changed from 10w30 I think) and the engine had such a dramatic loss of noise I thought something was wrong with it. The thicker oil definately quieted down the engine. It still has noise and "ticking" but that's normal and is the nature of the beast. I live in Arkansas and the temps have been really high all summer long.
I would think that your engine would be the same. Ride it and have fun!
Aif
Retired US Army & Proud Marine Corps Dad!
'08 Red/White VN 1500 Classic
http://www.patriotguard.org
Aifwikir is offline   Reply With Quote
Old 10-02-2007   #6 (permalink)
RichLockyer
RichLockyer's Avatar
Hydraulic lifters, so it's not valve adjustment.
Does the ticking go away, or quiet down under acceleration and cruise, but return under deceleration? If so, that's the Idle Control Solenoids.
They are louder when cold, and tend to quiet down when warm, but they are still audible on a warm engine.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 10-02-2007   #7 (permalink)
PopJack
PopJack's Avatar
Default Just checked
I had not paid much attention to when the clicking was loudest, so I went for a ride and listened. The tapping is loudest at idle, but present though acceleration. It seems to be quietest during engine braking. It does dimenish somewhat as the engine warms up.
Old 10-02-2007   #8 (permalink)
RichLockyer
Probably the ICS.
The only other thing to be concerned about if you have 20k or more is the timing chain tensioners. They seem to run out of travel anywhere from 20-50k, which allows the chain to "flop" a bit, causing it to rub on the spark plug tubes. Eventually, they will wear through, evidenced by oil in the tubes under the plug boots.
You can remove the tensioners and install specially made shims to take up the slack, and I haven't heard of anyone needing a second "fix".
- Rich
Patriot Guard Rider
Old 10-05-2007   #9 (permalink)
PopJack
PopJack's Avatar
OK- Here's what I really did. I put 10W-30 oil in the bike, along with Sea Foam to kind of wash out the crud (if there was any). I ran this about 500 miles, then drained it and replaced it with 15W-50 Mobil one.
Result: Some noise reduction, but still "cllicky." Seems better to me, and I'm happy.
Old 10-05-2007   #10 (permalink)
Classic
Ahhh Crap
Classic's Avatar
Remember that you have a pretty darn big engine real close to your ears with no insulation so, you're gonna hear everything it does. Open the hood of any car while the engine is running and you hear all kinds of noises. The 1500 engine is noisy but it does have a habit of running reliably for a very long time.
Steve
2003 1500 Classic
VROC 11660
RB 139
Classic is offline   Reply With Quote
Old 10-14-2007   #11 (permalink)
PopJack
PopJack's Avatar
Problem Solved: Observations
I have solved my noise problem in my Nomad- it was the chain tensioner. I have a couple of observations that may be helpful to others looking for noise.
First, I could not identify the noise the engine was making. I was aware of the cam chain tensioner problem, but I didn't hear what sounded like chains on metal. UNTIL I went for a high speed ride with ear plugs. With ear plugs blocking wind noise, and movement carrying away the exhaust and other noises, I determined that what I was hearing was the louder clicks, bangs, or whatever of a continuous grinding chain. With ear plugs the noise was clear and scary.
Second; It easy to check these tensioner for the rear cylinder. This lets you know the work needs done.
Third: I bought a service manual because they normally help you find ways to do things. The service manual for the 1500 Nomad is, however, a bit of a joke. It contained very valuable information- but the way it suggested I do things were ungodly complicated. For example, it recommended I remove the rear exhaust pipe to get to the rear tensioner.
Fourth: The front cylinder is a pain in the butt to install the tensioner extension. After doing the rear I felt pretty cocky- but I got over it. Don't try this unless you have time and patience. The service manual has you removing everything between the heads- including intake manafold. This is not necessary, but expect bloody knuckles.
Thanks for all the input. My bike now sounds about like I expected it to!
PopJack
Old 10-14-2007   #12 (permalink)
PopJack
PopJack's Avatar
Oh yeah- it is true I don't hear well out of one ear and the other is for decoration only.
Seriously Stupid Newbie Question! CheriAnn Main Lobby 50 03-15-2007 05:08 PM
Another Newbie with a question. Calshar Kawasaki Cruisers 15 01-09-2007 12:31 AM
The ulimate newbie question: First bike? TwistedKestrel Main Lobby 16 10-04-2006 09:48 AM
Dumb Question a from Newbie rccnh Kawasaki Cruisers 2 05-21-2006 05:28 PM
'81 LTD550 ignition problems (newbie question) yan The Mechanics Corner 2 05-14-2004 12:41 PM
