Old 10-26-2007   #1 (permalink)
mavulcan900
Default Cobra Tach on 900 Custom - Pic
I did a quick search, and didn't see anyone else who has posted a pic.
Note that this tach is not the same as the Classic/LT, because the handlebars are different. You can see the Classic/LT tach here:
http://www.kawasakimotorcycle.org/fo...an-w-pics.html
BTW, the install for this is quite easy. Tach works great, although compared to a car tach, the action of the needle is definitely dampened (it doesn't react as quickly to changes in engine speed).
mavulcan900 is offline   Reply With Quote
Old 10-26-2007   #2 (permalink)
JacksonW
2005 V2K
JacksonW's Avatar
Looks really sharp! I had a Barons on my Classic. Looks very clean on the Custom!
JacksonW is offline   Reply With Quote
Old 10-26-2007   #3 (permalink)
c_law23
Missy Peregrym's #1 fan!
c_law23's Avatar
Send a message via Yahoo to c_law23
that is sharp! is the delay like annoyingly slow or just a tad? also what all is involved with install?
Chris
VROC #24810
Black 2007 900 Custom
http://s131.photobucket.com/albums/p...0900%20Custom/
c_law23 is offline   Reply With Quote
Old 10-26-2007   #4 (permalink)
crazydave
Hitting 6th at 150 rocks
crazydave's Avatar
Send a message via AIM to crazydave
Exactly how easy was the install?
crazydave is offline   Reply With Quote
Old 10-26-2007   #5 (permalink)
mavulcan900
The lag isn't annoying. Just noticeable when you move the throttle. When you're actually riding, you don't notice (I just use it to check the current RPM - If I watch it while riding, I'm sure I'll significantly shorten my life expectancy).
As for install, directions were excellent, took me about 15-20 minutes:
- Tach clamps to the bars with a couple bolts.
- It has 3 wires, correct length, with quick disconnects already attached.
- 2 wires thread into the back of the headlight assembly through the existing opening. You have to tap the power wires in the headlight - remove 2 screws, one on each side of light, pull out headlight, strip the indicated wires, snap on the supplied wire taps, and connect the connector.
- Last wire needs to be threaded down through the body to the left side where the ignition coils are. Remove the "chrome" cover - one screw - between the cylinders, tap the indicated wire - same procedure as headlights - plug in connector.
- Zip tie (supplied) everything to make it neat.
Done.
BTW, the light in the tach is blue, so it doesn't match the speedo, for those of you who worry about such things...
Old 10-26-2007   #6 (permalink)
perryrl
Can't find time to ride
perryrl's Avatar
Lookin' good.
DRIVE IT LIKE YOU STOLE IT!!!
RL Perry
SSgt USMC
96 VN800 Classic
07 GSXR-750
perryrl is offline   Reply With Quote
Old 10-26-2007   #7 (permalink)
c_law23
c_law23's Avatar
Done.
thanks, very informative
Chris
VROC #24810
Old 10-26-2007   #8 (permalink)
c_law23
c_law23's Avatar
and for the record, that probably would bother me, if i decide to get one it would have to be amber...
Chris
VROC #24810
Old 10-26-2007   #9 (permalink)
Ride4Life
900 LT
Ride4Life's Avatar
looks great can you post some rpm's at different cruising speeds for us?
Ride4Life is offline   Reply With Quote
Old 10-26-2007   #10 (permalink)
TX 900 Custom
Cruising In Fourth Gear
TX 900 Custom's Avatar
Looks fantastic, Yes me too, I'd love to see a camara phone snapshot of the speedo and the tach, high focus, exactly centered at 75 MPH and 100 MPH, At night on a curvy road.
2007 Black Vulcan 900 Custom, Lotsa Mods
TX 900 Custom is offline   Reply With Quote
Old 10-27-2007   #11 (permalink)
Flboy
Forgiven
Flboy's Avatar
That looks nice. How much does that cost?
Flboy
2007 Vulcan 900 Custom
http://s5.photobucket.com/albums/y162/Flboy/Vulcan/
Flboy is offline   Reply With Quote
Old 10-27-2007   #12 (permalink)
Cruz
Ride Hard, Ride Free!
Cruz's Avatar
Looks cool...
A.K.A Chris
Kick it up a gear!
'07 900LT
Cruz is offline   Reply With Quote
Old 04-06-2008   #13 (permalink)
spitfire9
Flying low.
spitfire9's Avatar
Kevin.
'07 Plasma Blue 900 Custom.
Aviation and history fanatic.
spitfire9 is offline   Reply With Quote
Old 04-06-2008   #14 (permalink)
dmsdude
King Dad
dmsdude's Avatar
Seriously, it would be great if you could post what your RPMs are at various speeds. Say 5 MPH intervals from 60 to 80 (give or take). I am asking because I am still thinking the 900 revs pretty high at those speeds - particularly at 70 to 75+. Just want to get a feel for what the actual RPMs are. Thanks.
DMSDUDE
2008 Blue/Silver Vulcan 900 Classic LT
dmsdude is offline   Reply With Quote
Old 04-06-2008   #15 (permalink)
Hawg Fan
V2K KindaGuy
Looks good. Been trying to decide which one to get myself. This one really looks sharp.
Hawg Fan is offline   Reply With Quote
Old 04-15-2008   #16 (permalink)
boott
Finally Got Into First Gear
Really like the straight version of the Cobra tach. You happen to have the part number for it? Got a 900 Custom as well and looking for a tach. thx
boott is offline   Reply With Quote
Old 04-16-2008   #17 (permalink)
mavulcan900
The Cobra part # for the custom is 01-1968. I believe the classic/lt part # is 01-1963, if anyone cares.
You can get all the custom's cobra part #s from this page:
CobraUSA - CruiserProducts - Vulcan 900 Custom (07-0
There definitely are cheaper places to get the parts than direct from Cobra, though.
Old 04-16-2008   #18 (permalink)
mavulcan900
It finally got warm enough here in NE to ride again, so I've collected up some speeds vs. RPM. This is on a stock drivetrain 900C. Unfortunately, I don't have a GPS, so I can't verify actual speed. I'd assume the usual 8-10% error.
MPH RPM
40 2100
50 2800
60 3400
70 4000
80 4500
Old 04-16-2008   #19 (permalink)
psufreak100
Turtle Wax Taster
psufreak100's Avatar
MPH RPM
40 2100
50 2800
60 3400
70 4000
80 4500
Thanks for posting this, good info... does anyone know what the "redline" is for the 900?
psufreak100 is offline   Reply With Quote
Old 04-20-2008   #20 (permalink)
jimmy74
do you know the part number? In the Meancycles website there are two cobras for vulcan900.
jimmy74 is offline   Reply With Quote
07 900 custom vs. 06 1600 classic AdrianVall Kawasaki Cruisers 16 10-05-2007 10:42 AM
Vulcan 900 Custom W/ Cobra Power Pro 2 into 1 JohnnyStang06 Kawasaki Cruisers 3 09-06-2007 07:38 PM
looking at 900 custom....1st cruiser isenegger Kawasaki Cruisers 30 08-17-2007 12:27 PM
Got Pics; Anyone got a Custom World Mini Sissy Bar on a 900 Custom? CootoronScooter Kawasaki Cruisers 0 07-24-2007 11:46 PM
900 Tach Info BikerBeagle Kawasaki Cruisers 2 08-21-2006 11:20 AM
