Old 11-01-2007   #1 (permalink)
plasma blue
Banned
Default Mods, mods, and more mods. With pictures. Brake/tailight 42 LED,
One of my favorite mods and it's the easiest, 4 minutes.
This is a 42 LED high intensity 100 degree coverage board. It is about 5 times brighter than the stock bulb.
Here are the items I purchased yesterday to put on:
The light cluster is the one on the top left.
I have the clear lens but this will work with any lens.
Remove screw and old bulb. Plug in new cluster base. Route wires on the self adhesive tape like this:
Cut a piece of 3M Foam adhesive and place on wires, sandwiching them:
Now remove liner and stick to reflector. Replace gasket & screw and Ride!
I was truly surprised over the brightness vs. my previous 12 led bulb, this thing GLOWS BRIGHT!
plasma blue is offline   Reply With Quote
Old 11-01-2007   #2 (permalink)
Spok
Whatever
Spok's Avatar
are you single handedly supporting the aftermarket industry?
2005 V2k Pic
Beartooth Kawasaki for all your needs 1-800-556-3098
Spok is offline   Reply With Quote
Old 11-01-2007   #3 (permalink)
plasma blue
Banned
No, I think there are 1 or 2 more somewhere.... LOL
Old 11-01-2007   #4 (permalink)
Spok
Whatever
Spok's Avatar
yeah, but those are your secret identities, i've checked, they all ship to the same address..yours!
busted!
2005 V2k Pic
Old 11-01-2007   #5 (permalink)
brent4a
Life Saver
I have the radiantz LED's all he way around...Brake,front and rear turns. I would be surprised if there is a brighter LED around. I went with cheaper ones the 1st time, wont do that again. I have people ask we why i ride with my brake on because the lights are so bright on the rear, then i hit the brake and they are speechless......and blind.
brent4a is offline   Reply With Quote
Old 11-01-2007   #6 (permalink)
CheriAnn
CheriAnn's Avatar
That is SO COOL!!!!
Honestly, I was just looking at those lights online this morning!!!!!!!
That's it!!!! You've got the EASIEST to follow instructions I ahev ever seen!!!! I'm buying it and installing it on my 900 myself!!!!!
Thank you!!!!!
2006 Vulcan 900LT (Mine)
2007 Vulcan Nomad (Hubby's until I decide to take it!)
CheriAnn is offline   Reply With Quote
Old 11-01-2007   #7 (permalink)
plasma blue
Banned
busted!
How did you catch me?
I thought I was covering my tracks LOL
Old 11-01-2007   #8 (permalink)
plasma blue
Banned
You're right the running lights are much brighter than any brake light and when you hit the brakes... WOW!
Old 11-01-2007   #9 (permalink)
plasma blue
Banned
Originally Posted by CheriAnn View Post
That is SO COOL!!!!
Thank you!!!!!
All you need is $23, 5 minutes and a small piece of 2 way foam tape!
Good luck Chrei You will be suprized how easy it is and how much better you will be seen, day or night.
MAKE SURE you get the dual intensity one....
Old 11-01-2007   #10 (permalink)
Spok
Whatever
Spok's Avatar
alien technology
2005 V2k Pic
Old 11-01-2007   #11 (permalink)
plasma blue
Banned
alien technology
Next time I order something I will wear my aluminum foil cap!
Old 11-01-2007   #12 (permalink)
brent4a
Life Saver
Here are mine...With brake OFF
Old 11-01-2007   #13 (permalink)
Spok
Whatever
Spok's Avatar
won't do no good, we've developed our technologies to break thru that filtering tool...you'll have to go to copper foil to foil us now
2005 V2k Pic
Old 11-01-2007   #14 (permalink)
CycleDude
Giggity Giggity Goo!!!
CycleDude's Avatar
Don't listen to him, John.... It's a trick. The aluminum foil still works. He only wants you to switch to copper so he can get the last 3 security digits off of your credit cards!
Kevin
06 VN900
VROC #27222
My MeanCycles Gallery
CycleDude is offline   Reply With Quote
Old 11-01-2007   #15 (permalink)
CycleDude
CycleDude's Avatar
BTW, Great job on the lights!
Kevin
06 VN900
VROC #27222
Old 11-01-2007   #16 (permalink)
Spok
Whatever
Spok's Avatar
note from Spok to Supreme Commander of the 5th Galactic Expeditionary Force
it has come to our attention that a previous adbuctee and probee is in need of a booster treatment
2005 V2k Pic
Old 11-01-2007   #17 (permalink)
plasma blue
Banned
Darn!!!
I was 1/2 way through epoxying pennies to an old motorcycle helmet!
Old 11-01-2007   #18 (permalink)
plasma blue
Banned
Hey Kevin...CYA !! LOL
Old 11-01-2007   #19 (permalink)
Spok
Whatever
Spok's Avatar
Darn!!!
that won't work, the gaps between will allow for signal transfer. unless you put a penny over each opening....but i wasn't the one who told you if anyalien asks...mkay?
2005 V2k Pic
Old 11-01-2007   #20 (permalink)
CheriAnn
CheriAnn's Avatar
So you only did the tailight, right? I was looking at the web site and they mention turn signal bulbs too!!!
