Old 12-16-2007   #21 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
OK, so what if I am a tool nut? I want this one:
Pro Model Ultimate Package
The Professional Model ULTIMATE PACKAGE. Comes Complete with everything in the Pro Model package: 3 Xtra Hand clamps, Tire lubes, 4 SpoonBars, ATV breaker T, our patented Mount/Demount bar and extra Tips, concrete floor mounting kit. Lifetime warranty on Non-Marring parts. The best warranty by any tire changer company! PLUS: RimClamp set, Balancer, Medium Cone Set, Large Cone set, and one YellowThing!
$1395
Shawn Lattimer
'06 Silver V2K Classic VROC #22980 ROG #464
http://www.shawnlattimer.com
Lattimer is offline   Reply With Quote
Old 12-17-2007   #22 (permalink)
MrClean
Needs A Real Job
MrClean's Avatar
Those sticky weights are available at most hobby shops. We use them to balance our airplanes. You don't have to wait for the mail to come in, just find a hobby shop and go buy them there.
F5
It's Refreshing!
From Somewhere near Parkville, Mo.
William Crane
aka MrClean
IBA #34301
MrClean is online now   Reply With Quote
Old 12-17-2007   #23 (permalink)
2WheelFun
2WheelFun's Avatar
$1395
I saw that and thought the same thing you did. It sure would be nice to have that level of equipment to get the job done. They are proud of their product but it does look like it would last a very long time.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 12-17-2007   #24 (permalink)
2WheelFun
2WheelFun's Avatar
That's a good tip!
I bought mine when I got the balancer so I didn't mind waiting since I had to wait for all the gear to get here.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-17-2007   #25 (permalink)
Mercury
Mercury's Avatar
Send a message via AIM to Mercury
dont forget to mount the dot of the tire close to the valve stem... My tires barely required any weight after i did that
kenny
2000 drifter 800 - lightly modded
2003 360 4x4 atv
Mercury is offline   Reply With Quote
Old 12-17-2007   #26 (permalink)
2WheelFun
2WheelFun's Avatar
kenny
You got it. I've got a short list of things to check when I finally get to do the work. With the winter weather continuing to bring us snow it won't get done anytime soon.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-17-2007   #27 (permalink)
Lobocop
Last 007 MOM
Lobocop's Avatar
Send a message via AIM to Lobocop
Cary, are you going to bolt that changer to the floor or into some concrete?
If you don't have any concrete ... send that changer to me, I would be happy to mount it in some fresh mud
Don't forget to send the tools too
Build it if you can - Buy it if you must
VROC #11416
07 Red Lodge Survivor - DR# 009
Lobocop is offline   Reply With Quote
Old 12-17-2007   #28 (permalink)
2WheelFun
2WheelFun's Avatar
Dear Ken,
Get your own!!! LOL
Once the VW is fixed and it can be parked outside in the weather I will drill holes in the concrete floor so I can mount it when needed and remove it when it's not needed. I thought about bolting it to plywood but would rather it be fixed to the floor so I don't have to add/remove the plywood as needed.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-18-2007   #29 (permalink)
Drifter800
Not a REAL biker!
We have a local Harbor Freight store and I caught that changer on sale for $29.99. I just wanted to try and change my race tires for my Mustang which it will do but not the most fun I've ever had. It takes some imagination, vise grips, and cardboard isolators but it can be done. I'm talking 315/35/17 Kumho V710 race tires with super stiff sidewalls.
I drilled the floor with a 5/8" masonry bit to insert 3/8"x3" lag anchors. The way it's made the anchors want to pull out of the floor if you tighten the bolts without some sort of spacers. I stacked some large nuts between the floor anchors and the bottom of the base channel on the changer. You will need 4 - 3/8" x 3 1/2" lag bolts if you go this route. The lead anchors may not last more than a couple of mountings. I've had to replace a couple of mine and only used it 3 times but I put some serious stress on it.
Drifter800 is offline   Reply With Quote
Old 12-18-2007   #30 (permalink)
Lobocop
Last 007 MOM
Lobocop's Avatar
Originally Posted by 2WheelFun View Post
Dear Ken,
Get your own!!! LOL
Sheesh ... just trying to help you out and keep you from dancing with that machine
If the space was available ... I would put it straight into the concrete with some really big bolts
VROC #11416
Old 12-18-2007   #31 (permalink)
vn1500
Barrett Motorcycle Repair
vn1500's Avatar
When balancing the tires use some masking tape to temporarily hold the weights on and rechek if everythings kosher then peel the backing and sticker down saves on weights and goo gone to get the sticky mess off your wheels also with custom wheels i'll break one side of the bead down and put the weight inside the tire on the rim but also use duct tape and make sure no matter where you put the weight on the wheel is very very clean , nothing like havin a weight come off when your clippin 80 mph on the freeway
vn1500 is offline   Reply With Quote
Old 12-20-2007   #32 (permalink)
2WheelFun
2WheelFun's Avatar
Thanks for the heads up on the anchors. I need to pick some up and will get extras for the time I get to it.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-20-2007   #33 (permalink)
2WheelFun
2WheelFun's Avatar
That machine can dance...I can't!
It'd be better if it were hard mounted IMHO. I don't have enough area to do that and leave it permanently so have to remove it when it's not needed.
Say Ken...how's the house coming?
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-20-2007   #34 (permalink)
2WheelFun
2WheelFun's Avatar
That's another good tip. I have some tape handy just for that and will be sure to use it as you suggested. Thanks!
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-20-2007   #35 (permalink)
Lobocop
Last 007 MOM
Lobocop's Avatar
We are making progress at getting out of this one. Should be totally moved out on Sunday. The heavy equipment will be here on the 4th of January so it has all got to be gone.
My son is bringing out a chainsaw to cut the deck down into firewood, and that breaks my heart, but there is no way to save it.
Wired phone service into the RV and left the cable on the ground overnight ... the cottontails here in the yard chewed the cable in half overnight ... gonna call Elmer Fudd in to deal with Bugs Bunny real soon.
To much fun
How is the front end work coming on Shirley's Super Beetle?
VROC #11416
Old 12-20-2007   #36 (permalink)
2WheelFun
2WheelFun's Avatar
To much fun
It does sound like progress. That's good to hear. How's Lynn dealing with it all?
As for the deck...that breaks my heart to hear it. You know there's alot of good wood to use there and cutting it up is such a waste. Did you use screws or nails when you built it?
The VW is still sitting in the cozy spot in the garage waiting for the seal kit to arrive. I think they had to dig down into the bowels of the earth to find the materials to make the kit. I'm sure someone could spare some rubber here or there but hey...we just buy the stuff.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-20-2007   #37 (permalink)
Lobocop
Last 007 MOM
Lobocop's Avatar
She is doing good with all this ... she wants the new house. Going to be the death of me though. Its easy to move all the filing cabinets, gun safe, along with everything else that seems to weigh a ton. Have two of my sons coming up this weekend to help with the last of the heavy stuff.
The biggest problem so far has been switching over to this laptop ... drives me nuts
Its probably a good thing the quad is still parked outside if those seals aren't in yet. Don't need your bride swimming in the Beetle
Is it going to be a headache to replace them?
VROC #11416
Old 12-20-2007   #38 (permalink)
2WheelFun
2WheelFun's Avatar
Good for both of you getting the new place built. God knows you both deserve it!!!
Ken...if you have a keyboard and mouse that you can plug into the laptop that can make it more like using your desktop. Just a thought...
I have a cover over the quad so it'll be fine..."IN THE COLD". LOL
I haven't looked at the seals under the hood yet so don't know how hard it will be to replace them. I'll get Shirley going on it and just ease out of there to let her use her expertise if it gets too tuff. LOL
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 12-20-2007   #39 (permalink)
Lobocop
Last 007 MOM
Lobocop's Avatar
I have a mouse hooked up to the laptop, but don't have a spare keyboard ... yet. It is just so different using this thing
Glad you got that beautiful new quad covered ... That thing will last you forever taking care of it like that. You should see my quad, has the flatbed hooked up to it making it easier to move boxes and such. That thing has paid for itself time and again
I have tried messing with those seals before and it takes time to get them positioned properly. If she can do it, she is a better person then I am
VROC #11416
Old 12-21-2007   #40 (permalink)
2WheelFun
2WheelFun's Avatar
I think you and I think alike when it comes to taking care of our toys. While I know it's a 4-wheeler and it's fine under cover...I still want to take it into my room and sit on it in the comfort of our home. LOL
That sounds like a handy way to rig up the quad. I know what you mean about them paying for themselves. They can more then just ride on trails. After I sold our last set it was only a matter of time before I missed them. I hope I never have to part with this one!
Shirley has "ALOT" of patience so if anyone can do it...she can. Of course I'll be there to give moral support.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Changing Rear Tire Size -04 Nomad dfgpilot Kawasaki Cruisers 20 05-03-2009 05:03 PM
TSBA - tire changing Tweek Kawasaki Streetbikes/Sportbikes 6 06-16-2007 07:03 AM
tire changing and balancing Homeguard Kawasaki Streetbikes/Sportbikes 16 04-09-2007 04:24 PM
Changing rear tire stevend135 What I learned today 1 03-03-2007 07:35 AM
Tire Changing Instruction-Illustrated Night Flight Kawasaki Cruisers 8 03-05-2006 10:25 AM
