Old 01-01-2008   #1 (permalink)
nedley
Proud Hokie!!
nedley's Avatar
Default 2007 900 Radiator Fan
I read this in my 900 shop manual:
The radiator fan is connected directly to the battery.
The radiator fan may start even if the ignition
switch is off. NEVER TOUCH THE RADIATOR FAN
UNTIL THE RADIATOR FAN CONNECTOR IS DISCONNECTED.
TOUCHING THE FAN BEFORE THE
CONNECTOR IS DISCONNECTED COULD CAUSE
INJURY FROM THE FAN BLADES.
Problem is that on my '07 900, if on, the fan turns off when the ignition is turned off. Turn the ignition back on and the fan comes back on.
Is this another misprint on the normal function of the 900 cooling system?
Is this how the fan on your 900 functions?
Ned B.
2007 Vulcan 900 CLASSIC
Metallic Titanium
PGR
"Standing For Those Who Stood For Us"
nedley is offline   Reply With Quote
Old 01-01-2008   #2 (permalink)
markbrumbaugh
Mark in Houston
markbrumbaugh's Avatar
My fan has always gone off with the ignition key too.
2006 Vulcan 900 Classic
2007 Morphous
PGR
Spring Texas
markbrumbaugh is offline   Reply With Quote
Old 01-01-2008   #3 (permalink)
c_law23
Missy Peregrym's #1 fan!
c_law23's Avatar
Send a message via Yahoo to c_law23
ditto, i try to wait to shut off my bike if i notice its on.
Chris
VROC #24810
Black 2007 900 Custom (sold)
http://s131.photobucket.com/albums/p...0900%20Custom/
c_law23 is offline   Reply With Quote
Old 01-01-2008   #4 (permalink)
Fly_by
All good, some beter!
Fly_by's Avatar
What he said!
If You Can Not Stand Behind Our Troops,
Please Feel Free To Stand In Front Of Them !
Fly_by is offline   Reply With Quote
Old 01-01-2008   #5 (permalink)
Castex1
Still wet behind the gears
I agree, I wait until the fan goes off before I shut her down with the key.
Keep pulling the trigger till the slide locks!!
Castex1 is offline   Reply With Quote
Old 01-01-2008   #6 (permalink)
Sierra Vulcan
Sorry Barbie
Sierra Vulcan's Avatar
Location: Found Ken and Killed him, now I'm heading home.
Yes. My 07 900 shuts off with the key, wife's 02 800 is independent of the key.
Sierra Vulcan is offline   Reply With Quote
Old 01-01-2008   #7 (permalink)
skewterdewd
Team Zissou
skewterdewd's Avatar
+1
01 Nomad FIDid I reset my odo back there?
skewterdewd is offline   Reply With Quote
Old 01-01-2008   #8 (permalink)
Alf
Alf not Elf
Alf's Avatar
Originally Posted by skewterdewd View Post
+1
+10
When arguing with a idiot make sure he isn't...
My bike 900 LT Red/Black.
Alf is offline   Reply With Quote
Old 01-01-2008   #9 (permalink)
REFUGIO
REFUGIO's Avatar
Mine too...Shuts off with the key...The manual is a misprint.
On ny previous vn750...the fan would run without the key being turned on.
2008 VULCAN 1600 NOMAD
REFUGIO is offline   Reply With Quote
Old 01-01-2008   #10 (permalink)
MrClean
Way Too Much Free Time
MrClean's Avatar
If the bikes not running the fan is just cooling the fluid in the radiator, I don't believe there is any flow in the system. So save your battery and just turn the bike off regardless of whether the battery is going or not. It'll cool down all by itself.
Poser and Proud of it.
From Somewhere near Parkville, Mo.
William Crane
aka MrClean
MrClean is offline   Reply With Quote
Old 01-01-2008   #11 (permalink)
Oz Saki
Can't find time to ride
Oz Saki's Avatar
Send a message via MSN to Oz Saki
Yep I just shut her down, it will kuel just fine!
Oz Saki is offline   Reply With Quote
Old 01-01-2008   #12 (permalink)
Sierra Vulcan
Sorry Barbie
+1
There is no flow with out the motor/water pump running. Shut 'er off, your just depleting the battery, that's why Kawasaki put it on the key!
Old 01-01-2008   #13 (permalink)
DHACK666
Back in the saddle
DHACK666's Avatar
On the 1500 and 1600 the Fan +24 VDC is wired direct to the fan Via a fuse. The ground is switched Via the Fan Temp. Switch. (No Relay)
On the 900 they made a change and did not take the disclaimer out. They wire the 0 VDC or -12VDC directly to the fan. They now switch the +12VDC through a single pole relay. The coil of this relay is controlled through the ECU. This unit is powered down when the key is switched off, therefore the fan would be switched off.
2008 Concours 14
http://www.daksplace.com/
DHACK00000000 00000000 00000010 10011010
DHACK666 is offline   Reply With Quote
Old 01-01-2008   #14 (permalink)
David Madden
David Madden's Avatar
Another manual misprint. Hey do you know the manual tells you to keep 28 psi in your tires, and the tire reads 40 or 41. Quess what the correct psi should be?
D
David Madden is offline   Reply With Quote
Old 01-01-2008   #15 (permalink)
Flboy
Forgiven
Flboy's Avatar
My fan rarely comes on.. I've never noticed. The machines are water cooled with additioanl air cooling and as much oil that is in them... the oil is cooling it also.
Flboy
2007 Vulcan 900 Custom
http://s5.photobucket.com/albums/y162/Flboy/Vulcan/
Flboy is offline   Reply With Quote
Old 01-01-2008   #16 (permalink)
900classic
Riding daily
900classic's Avatar
D
You can never trust the manual. I double check just about everything.
Jared
VN 900classic
VROC #26705
http://photobucket.com/900classic
900classic is offline   Reply With Quote
Old 01-01-2008   #17 (permalink)
N3FOLN3FOL
Needs A Real Job
N3FOLN3FOL's Avatar
Post Fan
This time of the year, my fan rarely comes on too. During the warmer months, I can see it run all the time.
'06 Vulcan 900LT (previous ride)
'07 Yamaha Venture (Love this bike)
Keep riding!
N3FOLN3FOL is online now   Reply With Quote
Old 01-01-2008   #18 (permalink)
Oz Saki
Oz Saki's Avatar
Correct tire pressure should be what is on the tires!
Old 01-01-2008   #19 (permalink)
sisooktom
900 Customer
sisooktom's Avatar
So does everyone run 40psi in the rear? I knew 28 was way conservative but I've been running between 34 and 36. I had been wondering if bumping it to 40 would affect the ride too harshly.
Plasma Blue Vulcan 900 Custom
Not riding a Vulcan is illogical!
sisooktom is offline   Reply With Quote
Old 01-01-2008   #20 (permalink)
VulcanRev
PGR - BFC
VulcanRev's Avatar
That's funny, I thought I was the only one a little OCD in that department. If my fan is running, I will wait until it kicks off to shut off the bike!
You say psycho like it's a bad thing...
06 900 LT
94 Black & Emerald 750
VulcanRev is offline   Reply With Quote
2007 900 Custom sandman1 Kawasaki Cruisers 25 05-10-2007 03:27 PM
2007 Vulcan 900 AGS Kawasaki Cruisers 24 04-13-2007 09:05 AM
2007 900 Custom accessories??? UH60_900C Kawasaki Cruisers 6 03-12-2007 09:06 PM
Replacement starter relay/solenoid therealSnafoo The Mechanics Corner 13 04-04-2006 10:02 AM
