Here we go again! Last fall I purchased a used MS with about 12K miles on it. The front tire, in addition to being worn out, had an unusual cupped wear pattern. At that time, I was concerned that this indicated a problem with the bike as it had suffered a fall over in the driveway and had a dented fuel tank, but no other signs of damage.
After inquiring on this forum and talking to the dealer, I concluded it was caused from improper tire inflation pressure by the previous owner. Several people suggested a pressure of 40psi instead of the 36psi reccommended by the book. So I replaced the tire with a Dunlop K510A-120/70R17,the only tire I could find locally that would fit it. In fact, the stock 130/70R17 tire is very hard to find. Since replacing the tire I have only put about 800 miles on it. The other day, I got to looking at the front tire and discovered a repetitive wear pattern that exaclty coincides with the tire tread pattern! BTW, I've watched the tire pressure like a hawk! It's not severe, but enough to be noticeable. I talked to the Kawasaki dealer and asked him if he thought there was a problem with my bike. He said he didn't think so, and said he suspects the radial tires. He said they're a lot of problems on bikes. If this is so, I sure wish I had known this before I bought the thing. Is anyone else having a similar problem on their MS? A friend told me that this particular Dunlop tire was trash. If so, it was one expensive piece of trash. Anyone have any ideas about what's going on? |
***Vintage Rider***
several riders have had the problem, icluding myself. In fact I had the cupping on both tires. I also increased the psi on both tires to 40 psi tires. I also replaced the OEM front tire with a 120. Both replacements were the orig. Dunlops. So far after about 4000 miles both seem to be wearing evenly. I like the narrower 120 front better than the orig. size. You might try increasing the psi a couple of pounds from 40 to see if it helps.
02 Mean Streak, Jardine 2/1 pipe, hiway bars w/pegs, floor boards,ISOgrips w/throttle boss, Kriss head light modulator, Corbin Young Gun ostrich saddle, etc. 660 Yamaha Raptor sport quad for the dirt. |
#4 (permalink) |
R.I.P. Deron Harden
![]() Join Date: Nov 2004
I had the same problem with mine, only got 5000 from the originals. I switched to Metzler Z6s. Stock size 170/60 in rear, with the 120/70 up front. Love 'em so far, but I only have about 300 miles.... will keep you up to date.
I may not have gone where I intended to go, but I think I have ended up where I needed to be. |
#6 (permalink) |
R.I.P. Deron Harden
2500 miles on the Mets Z6's. The front looks brand new, but the rear is starting to cup on the shaft side. I'm running 40lbs in the rear and 38 in the front.
Oh well.... maybe try Avons next time
#7 (permalink) |
UBER CLUB MEMBER #2
![]() Join Date: Jan 2005
it is caused by low air pressure by what I have seen and heard, I run 41 in both on my 1600 and not 1 cup in the front tire and I have 10,000 miles on it and it is not yet 1/2 worn out.
#8 (permalink) |
Bridal Boutique Manager
I'm wondering what information on tire wear patterns you are using to draw your conclusions. Is there a source you could quote as to how the tires should be wearing?
1980 Kawasaki KZ250 LTD 1981 Kawasaki KZ440 LTD 1991 Kawasaki Vulcan 500 |
#9 (permalink) |
I like vintage stuff!
You ought to consider checkng your alignment, too. It takes a little bit of time, but very easy to check and you've got the confidence knowing whether your wheels are in alignment of not. I type "motorcycle wheel alignment" in the Google search engine and got lots of how-to's. This one looks easy to understand:
http://www.motorcyclistonline.com/ho...ringalign0402/
1969 W2TT 650 1969 G3SS 90 1987 KDX200 1980 KZ750G ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
#10 (permalink) |
UBER CLUB MEMBER #2
here you go, hope this helps.
Cupping, which is more accurately described as scalloping, is a natural wear pattern on motorcycle tires and it will always follow the tread pattern. It is not a sign that you have bad suspension parts. It merely shows that your tire is indeed gripping the road when you make turns (thank you for that Mr. Tire!). This scalloping develops within the side wear bands of a leaned motorcycle. The extreme forces that come in to play when the bike is leaned in a turn are what produce the effect and when the wear becomes sufficient, one will experience vibration and noise when one banks into a turn. scalloping follows the tread pattern. The leading edge of the tread grips the road and the rubber is scuffed off the tire in that area causing a depression. As the tire rotates, the pressure moves to the trailing edge of the tread pattern and the tire flexes there which causes less scuffing so less material is ground off the tire. The more complex the tread pattern, the more complex the scalloping pattern will be. The softer the compound of the tire, the sooner this scalloping will develop. Radial tires are more prone to cupping than are bias ply because the compound of radials is softer. Low tire pressure will exacerbate this wear pattern and you will lose many serviceable miles by running low. Improper balance has nothing to do with "cupping" on a motorcycle tire. Improper balance will merely cause your bike to vibrate within certain specific speed ranges. Last edited by 1400pilot : 06-27-2005 at 02:18 AM. |
#12 (permalink) |
Way Too Much Free Time
Would it be possible for someone to take a picture of this effect so that those of us "imagination challenged" people can see what it looks like?
2005 Magma Red Kawasaki Mean Streak 1600 1998 Bright Red Pontiac Trans Am 405.5 RWHP 385.1 RWTQ 2004 Nighthawk Black Honda Accord EX 6-speed |
#13 (permalink) | |
Foil Inspector
It happens on my R6 front tire every other season, but then again, I'm putting a lot more force on that than I will on the Streak.
When you're chewing life's gristle, don't grumble, give a whistle and this'll help things turn out for the best. |
#14 (permalink) |
It's time for me to ride
I had a similar issue with the set of Dunlop 208's I put on. I watched the tire pressure closely and had it set at 36 which seemed to be the right consensus but at about 4000mi cupping become more noticeable. I cranked it up to about 40psi and for the last 1500 mi the tires actaully seem to be wearing better. I swapped front and back this weekend for Michelin Pilot Road's (caught a screw in the rear tire last weekend and didn't want to trust my fix on longer road trips) 120's up front, a 180 in the rear. I questioned a tech and again he recommended 36 up front, 40 out back. I've heard great things about these tires and they were very reasonable over the net. I was able to purchase both tires, ship and install for less than $300 which I was happy with. Time will tell.
2006 Midnight Nomad 2002 Pagan Gold Meanie Honda CR250R |
#15 (permalink) | |
UBER CLUB MEMBER #2
#16 (permalink) | |
#17 (permalink) | |
UBER CLUB MEMBER #2
