Missy Peregrym's #1 fan!
Any 900 owners replaced their turn signals with these "plug and play" led bulbs?
Motorcycle LED Light Bulbs Was a load equilizer necessary? I'm hoping to find a set that i can just plug in and go, no wiring required.
Chris VROC #24810 Black 2007 900 Custom (sold) |
#4 (permalink) |
Vulcan 800 Classic
from what ive read, anything LED for turnsignals needs a load equalizer.....
2004 Kawasaki Vulcan 800 classic cobra staggered pipes Mustang seat saddle bags windshield tank bib |
#5 (permalink) |
Life Saver
If you want the flash speed to remain stock, you will need some sort of load equalizer. Not hard to put in and you will need 2 if you replace front and rear turns with LED. I have the Radiantz clusters from the same company, and they are very bright. Pics in my signature.
#6 (permalink) | |
Banned
#7 (permalink) | |
Shifted into first gear
tell you what you need.......which may not be a load eq, but, if not, will probably need to change flasher. He'll have the answer....... |
#8 (permalink) |
Life Saver
If you do just the brake, nothing else is needed. If you do the turns, get a load equalizer for front and rear if you do both. If u have self cancelling signals, they will shut your turn signals off pretty quick after making a turn,if you dont add the equalizer. It just makes them work just like stock. If u dont, the signals will blink pretty fast, but wont hurt anything.
#9 (permalink) |
Custom '07 1500 Classic
I picked up the Kuryakyn eq from a local shop here in Jacksonville for about $14... easy install..
Kuryakyn Eq
Z VROC #25736
2007 1500 Classic Work in progress.. |
| Another Ride to PA Grand Canyon (Fall colors are coming!) | dropdfocus | Rides, Events and Rallies! | 49 | 10-23-2007 11:18 AM |
| LED Turn signals on a Vulcan 1600 Classic | mblairmail | The Mechanics Corner | 11 | 03-21-2007 08:17 PM |
| Turn signal timing | Watson69 | What I learned today | 21 | 01-18-2007 10:02 AM |
| EX500 turn signal switch | Daekar | The Mechanics Corner | 1 | 07-16-2004 09:50 PM |
