LinkBack | Thread Tools |
Hello everyone, I am new here, and would like to introduce myself. My name is Amy, and I own a 2006 Vulcan 900 and a 2007 Suzuki C50. I have been riding for 1 year.
On to my question. I want to get just the front pulley for my 900, but am unsure if I need a replacement belt. Could someone who has replaced the front pulley please give me any info you have about this. Thank you! Amy |
Pinson, Alabama
why do you want the pulley? do you do alot of interstate rides? just wondering.
i do mostly secondary highways and training myself to let the rpm's run like the motor was designed to. Also enjoy the quicker response of the stock pulley. some will say there is no difference, however, physics says there has got to be on acceleration. I have two similiar mustangs, one with a 3.27 axle the other 2.73. The latter cruises with less rpm but has less fun factor... use to shift into 5th at 35mph and now cruise 50 in 4th and it feels good.
Van 07 900 Classic Candy Caribbean Blue 91 (Pristine) 5.0 Mustang LX Last edited by vmuth : 02-04-2008 at 08:57 PM. |
#5 (permalink) | |
After a while the high whine of the engine bothers me. I know it was designed that way, but I find myself constantly looking for 6th gear. I shift from 4th into 5th at about 45 MPH. I don't know, my husband has a VN 2000, and it revs much lower. I know it's the difference in bikes, but it just sounds way better. Other than this and my stock pipes being to low I am absolutely happy with my bike. Last edited by Amy71076 : 02-04-2008 at 09:01 PM. |
#7 (permalink) |
Pinson, Alabama
i was going to change until i discovered the redline on this bike was well over 7000 and at 70 mph i had over 3000 rpm left. i started riding and letting it run holding gears longer, i am getting use to it. If i rode lots of interstate riding i would change. however someone mentioned that had the pulley that at about 60 are 65 mph going up a significant grade they had to shift back. That is the speed i ride on the back highways and have alot of rolling hills here is north alabama. With the stock pulley and my wife on board my 900 pulls effortlessly up hills in 5th.
Van 07 900 Classic Candy Caribbean Blue 91 (Pristine) 5.0 Mustang LX |
#8 (permalink) | |
![]() Join Date: May 2006
I find it much more responsive and not winding out so quickly with the Scootworks Pulley...Also gets up to speed very rapidly....and corrects the speedometer. A few have given opinions that do not have one on their 900.
2008 VULCAN 1600 NOMAD |
#9 (permalink) | |
Can't find time to ride
One thing you might want to also consider is adding a Baron's Big Air Kit, it will give you a nice throaty roar as you twist the throttle and I got 6 more HP and 6 more lbs of torque without fooling with the EFI. It put a smile on my face that's for sure |
#10 (permalink) | |
Former foxhole digger
Larry US Army 1989-2005 Desert Shield/Storm/Provide Comfort Vet PGR Member |
#11 (permalink) |
Pinson, Alabama
i am not a drag racer, but in the hands of a pro the stock pulley has to be quicker to sixty than the scootworks pulley. There is no question when you change the drive ratio by 6%.
some of you experts chime in. Same principle on a bicylce if you have any experince on one. Start off with the chain on a taller rear sprocket and you work harder getting started and move out slower. once you get moving it becomes easier but the initial effort to overcome the inertia (sp) is harder. Just my way of thinking, scootworks has no data on this.
#12 (permalink) | |
Where do you get one of these, and for how much? Amy
Mine - 2006 Vn 900 CL & 2007 Royal Star TD Hubby - 2007 Vn 2000 Cl LT & 2008 Royal Star TD |
#13 (permalink) | |
On a bicycle...if the peddler has the strength to out do the resistance of the taller gear...then he is going to take off faster. I hope you get the oppertunity to try a 900 with this pulley on it...I truely believe that you will change your tune. No offense meant...only a discussion here.
#14 (permalink) |
Well, I'm definatly getting the pulley. I just wanted to know if you need to change the belt. Thank you for answering my question.
I have also looked around the internet, and have discovered that almost all who have added the pulley say it is an improvement on an already great bike. I am looking forward to this addition. I'll come back and add my 2 cents after I get it and try it.
#15 (permalink) | |
![]() Join Date: Aug 2007
Now I'm finding it is a lot smoother at 70 to 75, and when I'm cruising behind friends on much bigger bikes, I hear their engines working also. I'm no longer sold on the need for the pulley. I think you have to break this puppy in. D Last edited by David Madden : 02-05-2008 at 09:02 AM. |
#17 (permalink) |
Here is one place to get them, and if you tell them you are a member of the Delphi 900 forum you get another 5% off. Meancycles is good to do business with and they are down your way (Miami). I ordered mine through Beartooth Kawasaki and got the forum discount through them.
MeanCycles - KAWASAKI - VN 900 - CUSTOM AIR FILTERS & ACCES. Here is the link to Barons, be sure to listen to the audio on the page. BIG AIR KIT - SMOOTH - Kawasaki Vulcan 900 by Baron Custom Accessories - Baron Custom Accessories Also if you look at the sticky for dynos I posted mine after adding the BAK http://www.kawasakimotorcycle.org/fo...tml#post800184 |
#18 (permalink) | |
VNOG#067
If you like your freedom thank a Vet! U.S. Navy Vet 2006 VN900LT |
#19 (permalink) |
One of Four
I think the pulley is a matter of riding style and the type of riding. It's been endlessly debated here. IMO either way is fine. I like some of the benefits the pulley brings. Longer shifts and a few less RPMs at highway speeds. Yes the motor is designed to run the RPMs but I think the 900 has plenty of motor to handle dropping 300 RPMs at 70Mph. I plan on getting the pulley when I get ready to change the rear tire. If I don't like it I feel I won't have any problems selling it on Ebay.
Which begs the question, has anyone regretted installing the Scootworks pulley? Also how many are running the pulley with a stock 900? |
#20 (permalink) | |
Ready2Ride
![]() Join Date: Oct 2006
My 900 is stock, except for de-baffled pipes. |
