Old 05-15-2008   #1 (permalink)
chad1043
Cruising In Fourth Gear
chad1043's Avatar
Default Power Commander on my Mean Streak... Questions...
OK, so you all know I got a Mean Streak. It came with a Power Commander 3 USB. I own a mac... So I don't think I can use the software. Any suggestions?
Also, how do you know it is powered up? I bought the bike from a dealership and they didn't even know there was a PC in the bike. does it light up or something? Any help about this device would be great. I don't know anything about Power Commanders...
If there is a map out there for a Mean Streak with Bubs chambermaids and a Hypercharger please let me know where to download it.
Thanks,
Chad
chad1043 is offline   Reply With Quote
Old 05-15-2008   #2 (permalink)
kc6wfs
Plasma Blue
kc6wfs's Avatar
You can go and google power commander and download maps for your bike.
I have a 900 with a PCIII.
If the bike is running fine with it I'd leave it alone.
But check the 2 lines to the fuel injectors, if they are hooked up it's working.
Also at the power commanders web site they have a list of authorized dyno tune places. Good to check out.
2007 Vulcan 900 Custom Plasma Blue --
www.myspace.com/nitrophotos
kc6wfs is offline   Reply With Quote
Old 05-15-2008   #3 (permalink)
Deeppurple52
Deeppurple52
Deeppurple52's Avatar
You can download a full set of instruction online from Dyno Jet
Enjoy the ride!
Deeppurple
2004 1600 Classic
2006 900 Classic
Deeppurple52 is online now   Reply With Quote
Old 05-15-2008   #4 (permalink)
jaseman
Insane in the membrane
jaseman's Avatar
This was one of the primary reasons I bought the Doebeck TFi over the PC-III. Didn't want to have to borrow someone else's laptop to tune my bike. If the software was Mac compatible, I would have coonsidered the Power Commander.
Since the PC-II is already on the bike, you can go to their website and download custom maps. They may not have one for your exact set-up, but you can probably get pretty close. At least as a good starting point.
Power Commander - 02 Meanie maps
03 MeanStreak
'90 ZX10
'04 Honda 599
Ride it like you stole it!
jaseman is online now   Reply With Quote
Old 05-15-2008   #5 (permalink)
furious70
on cupped tires
furious70's Avatar
pretty the manual described when the lights on the case should be on, can't remember off the top of my head
02 Mean Streak-mine
99 Suzuki Savage-hers
1970 Plymouth Sport Fury
1969 Dodge Coronet
furious70 is offline   Reply With Quote
Old 05-15-2008   #6 (permalink)
Pecos
Swank
Pecos's Avatar
Guess no one ever expected Mac users to be cool enough to be bikers.
You *may* be able to program the PC-III from a Mac if you use some sort of virtualization software that allows you to run a virtual Windows XP on your Mac -- something like VMWare or VirtualPC, possibly.
2004 Silver 800B
2006 Black Mean Streak
2006 2000 Limited
--==> The Bikes <==--
Pecos is offline   Reply With Quote
Old 05-15-2008   #7 (permalink)
furious70
on cupped tires
furious70's Avatar
a newer mac with an intel chip and dual boot perhaps?
02 Mean Streak-mine
1969 Dodge Coronet
Old 05-15-2008   #8 (permalink)
Red2002abca
If the green light is on in the center of the meter on the face plate that means its working. If you want to adjust the settings you turn the ignition on and withen 5 seconds push all 3 buttons (low, mid and high) then push to go richer or push and hold to lean out. The 3 buttons divide the throttle range into thirds.
Red2002abca is offline   Reply With Quote
Old 05-15-2008   #9 (permalink)
jaseman
jaseman's Avatar
I wish. I'm not allowed to buy anymore toys for a while.
03 MeanStreak
'90 ZX10
'04 Honda 599
Old 05-15-2008   #10 (permalink)
chad1043
chad1043's Avatar
Thanks guys. The green light is on the bottom when I turn it on, so I'm gonna move it to the center until I can download a map later this weekend.
Thanks,
Chad
Old 05-15-2008   #11 (permalink)
Kowalski
The green light should be at the bottom when the bike is on. The light will move up and down as you open and close the throttle. Its kinda cool if you ask me. I like to watch it. It remindes of the gas pedal in KIT, the car on Knight Rider!!!!
Kowalski is offline   Reply With Quote
Old 05-15-2008   #12 (permalink)
chad1043
chad1043's Avatar
OK, so I will just have to download a map. I will not adjust it. Thanks for pointing that out.
Chad
Old 05-15-2008   #13 (permalink)
kingofwings
Posting Slacker
kingofwings's Avatar
I was never able to get the USB driver for the PCIII software to work on VirtualPC on my Mac. That being said if it's running well, I wouldn't worry too much. I've got some great maps from several forums posted here. Hope it helps.
I may not have ended up where I intended to go, but I think I ended up where I wanted to be
kingofwings is offline   Reply With Quote
Old 05-15-2008   #14 (permalink)
chad1043
chad1043's Avatar
Can you use those with a 1500?
Old 05-15-2008   #15 (permalink)
kingofwings
Posting Slacker
ooops.... Sorry Chad, didn't realize you had the 1500. I'm not sure HOW much different they are, but Dynajet makes a point of them being separate so I wouldn't do it.
Old 05-16-2008   #16 (permalink)
furious70
on cupped tires
furious70's Avatar
I wouldn't think using a 1600 map on a 1500 would do anything but have you a touch rich. Hard to say if a map on a 1600 with your intake and exhaust vs. a 1500 map that wasn't your exact setup would be better or worse.
02 Mean Streak-mine
1969 Dodge Coronet
Mean Streak 1600 Questions NitroCrushr Kawasaki Cruisers 12 06-27-2007 08:41 PM
Power Commander III Easyrider32 Kawasaki Cruisers 5 05-24-2007 01:54 PM
Power Commander firmware update Nadmeister The Mechanics Corner 5 05-23-2007 09:06 PM
Another Power Commander Map Question wingman01 Kawasaki Cruisers 9 03-06-2006 07:34 PM
Power Commander and Thunder Tornado Intake Installation Help uf-engineer Kawasaki Cruisers 7 12-12-2005 09:53 PM
