LinkBack | Thread Tools |
Will I need to extend the wiring when installing 13 inch apes on a 98 800 Classic? If I do have to extend the wiring, what gauge wiring should I use? Also any suggestions on something to cover the wiring? The original grey wiring covers have discolored and I want something that will look cool.
Thanks for any help MaXx |
![]() Join Date: Aug 2007
You may get away without changing your cables if you don't mind them hanging straight down from the bars. It's a matter of taste.
If I were you, I'd order up some 14" stainless cables from scootworks.com You should double check on the length, but that sounds about right for a 13 inch rise. You may also consider ordring some bars that are slotted for the wiring to snake through. That really cleans up and gives you a custom look. Nice bikes the 800s. Enjoy. D |
I have Barnett 6" over stainless cables , clutch and throttle set, Goodrich stainless 6" over brake hose, but my main concern is the electrical wiring for the controls. Id rather not have the wiring hanging straight down from the bars. The bars are not slotted for internal wiring. They are dimpled and knurled though....
I know the cables might be a little long for the 13 inch apes, but I may go higher in the future and didnt want to buy new cables again. I want a clean look but dont mind the bowed out longer cables....just dont want ugly looking electrical wiring |
#6 (permalink) |
Finally Got Into First Gear
When I put 12's on my 800 I was able to keep the throttle cables but the clutch had to be changed. For the wiring I ran them thru the bars...MUCH nicer look. I just simply cut, soldered and put on some heat-shrink tubing and ran it thru the bars. The brake line looks wierd but theres no pinch points and works fine. Good luck with it and I too wanna see pics when your done.
#7 (permalink) |
Since it going be a wash out here tomorrow, Ill get to work on the bar swap.....I'll take some pics when its done and will post them here.....also going to bolt up the forward control plates I picked up on Ebay.......
look for pics tomorrow. Thanks for the suggestions, i may attempt running the wiring through the bars. MaXx |
#8 (permalink) |
http://www.kawasakimotorcycle.org/fo...ring-help.html
Take the extra time to run the wiring internally.
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
| 2005 Classic 800 more pep then 2000 drifter! | Mercury | Kawasaki Cruisers | 33 | 01-01-2008 06:15 PM |
| 2005 800 Classic: V&H Straightshots | GotLime? | Kawasaki Cruisers | 6 | 08-01-2006 09:28 AM |
| Rear Turn Signal Relocation 800 Classic | cboutfit | Kawasaki Cruisers | 3 | 03-26-2006 08:30 PM |
| WANTED Engine Guard for 800 Classic | Chuckster 1 | Accessory Swap Meet | 0 | 03-04-2006 07:21 PM |
| Vulcan 800 Classic Black or Wait for 900? | WalterRC | Kawasaki Cruisers | 29 | 10-28-2005 03:11 PM |
