Finally Got Into First Gear
hey guys, prolly noob question, but just a bit confused on pressure i should be using. Manual says 40 front, 28-30 in the back. Dealer said 32 and 32... ive read on here 40 and 40.... what would probably be best?
#4 (permalink) |
jerkybear's Vulcan
Hey Rain, I run 38 front and 40 rear, but I ride 2 up frequently. I have a Kenda in the rear and stock Dunlop in the front. Hope this helps. Craig
My God Jim, I think he's a Vulcan Craig Clakley 07 Ebony and Galaxy silver 900 LT Debaffled PGR |
#7 (permalink) |
The VN900C owner manual says:
F = 40psi, R = 28psi up to 97.5kg or R = 32 psi up to 180kg The dunlop website for Kawasaki VN900C OEM D404 tires says: F = 32psi loaded, R = 38 psi loaded see Fitment Guide for Dunlop Motorcycle Tires The Kawasaki dealer adjusted mine at the first service to: F = 32psi, R = 36psi I found this a little wishy-washy around corners so have adjusted them to: F = 36psi, R = 34psi I weigh ~ 75kg in my riding gear and the bike has a sissy bar and rack ~ 5kg I also noted that Dunlop recommends a 1.85 inch rim for the 80/90-21 tire, while Kawasaki is running it on a 2.15 inch rim, which may account for why Kawasaki recommend higher front tire pressures than Dunlop.
Candy lime green VN900 Custom Last edited by jateureka : 06-24-2008 at 04:10 AM. Reason: add rim size |
#9 (permalink) |
![]() Join Date: Dec 2006
Dunlop states: "Rear touring tires must be inflated to a minimum of 36 psi for light to medium loads and 40 psi for dual riding and other loads. Never exceed maximum load indicated on tire sidewall or vehicle capacity load found in owner's manual."
#10 (permalink) |
Riding daily
38 front and 40 back.
Jared 1600 Nomad VROC#26705 KawaNOW#01051 http://www.utahmotorcyclist.blogspot.com/ |
#13 (permalink) |
Turtle Wax Taster
38 Front and 40 Rear.
This combination will give you the best tire longevity and the least amount of abnormal tire wear. The only downside is that the higher pressures make the ride a bit stiffer but in my opinio alot safer. Higher pressure tires resist hydroplaing much better and still have plenty of reserve traction for our cruiser applications. Never exceed the maimum cold pressure but runing your tires near this pressure is the best for a cruiser. R. Todd (On my 1300 I run 40 and 42 but the 900 is lighter. Our Kawi / Honda dealer indicated that they always put 38/40 in all of their cruisers in spite of the manual recomendation)
Cordova, Tn HD Road Glide & VTX 1300 C (mine) VN 900 LT (wife's) Iron Butt Member Since 9-07 |
#14 (permalink) |
Stealth Custom
![]() Join Date: Jul 2007
MOM says 40F and 28R, or for 2up 40F and 32R
MeanCyclesGallery |
#17 (permalink) |
Crazy Old Guy
. . . are you confused yet? . . .
Get a pressure, watch your tire wear, adjust by feel of the bike and tire wear. I'm an old motocross guy and always ran my tires lower than my competition! I started at 32/32 on my 900C and have upped that to 35/35. We'll see how the tire wear goes. I also 'try' to rub off all the little tiddies on the sides of my tires to get 'full advantage' of my lean angle (hehe). Good luck and ride safe!
Bryan (Big B) 07 Vulcan 900 Custom Candy Plasma Blue VROC Member #27075 MRCA Member #90008991 |
#19 (permalink) |
There was a rule of thumb to determine what pressures you sould be running based on the difference in cold and hot pressures. IE you should adjust the pressure until you get a certain difference between hot and cold.
Too bad I can't remember what it was now...
Candy lime green VN900 Custom |
| 900 Custom rear tire | Trashman900C | Kawasaki Cruisers | 27 | 08-29-2008 06:13 PM |
| Dunlop tire pressure info on VN900 and others | davidcruiser | Kawasaki Cruisers | 6 | 08-17-2007 04:50 PM |
| Tire Pressure Indicator Caps | topcatflyer | Kawasaki Cruisers | 19 | 09-23-2006 11:18 PM |
| tire pressure | badassDominican | Kawasaki Streetbikes/Sportbikes | 6 | 07-13-2006 12:02 PM |
| Should your tire PSI be what the tire says max? | Desp | Main Lobby | 4 | 05-10-2004 03:31 AM |
