Wants better weather!
I use the Kawasaki oil filter and I realize there are torque specs for it. As I had a oil drain plug overtightening recently because of a faulty Husky torque wrench resulting in stripped threads in the crankcase, I used the same torque wrench on the oil filter and got the oil filter on so tight I almost didn't get it off. My question is this, it is ok or typical to tighten the oil filter only by hand like I do on my car (tighten to contact, 3/4 turn more)? What are your recommendations, thanks, Doc.
Made It To Second Gear
you love overtightening things. lol... this is what i do...put a little oil on the seal, hand tighten and just a little more with the wrench and your done.
1998 kawasaki vulcan classic 1500 http://hometown.aol.com/jamie00tlr/m...age/index.html |
RIP Deron - 1400Pilot
the first time i changed my oil, I had to nearly twist the bike over on its side to break loose the oil filter. I think the mechanic at the 600 mile checkup must've used an impact wrench to put it on. Way too tight, I normally do what Staff suggested and that is oil the seal and hand tighten then a tad more with the wrench....works every time.
AUGUST 2006 MOM In Memory of Deron Harden - 1400 Pilot. You are missed. Official Cup Holder Inspection Officer |
#5 (permalink) | |
#7 (permalink) | |
#9 (permalink) |
Rebel Rider
A little oil on the gasket, tighten by hand, then a 1/4 turn more with a wrench. This is a no grunt, no fart tightening. If you feel a grunt or a fart coming on, stop it's too tight.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
#10 (permalink) | |
#11 (permalink) |
Turtle Wax Taster
Actually, the manual for the ZX6R/RR says that you should not tighten it by hand because you can't get it tight enough! They recommend a high torque for those filters. I was surprised. I'll have to look it up.
'04 Ninja ZX6RR (track bike) '04 ZZR 1200 (touring bike) |
#12 (permalink) | |
RIP Deron Harden :-(
i just tighten by hand and like everyone else, maybe a 1/4 turn more with a wrench. i tighten my diesel's fitler by hand and have not had a problem, i think my little 1500 will be fine as well !
David - Moderator 2002 Suzuki DRZ400 2003 1500 Meanie, scraping pipes and frame :-) In loving memory of Deron Harden, forever in our thoughts :-( |
#13 (permalink) | |
#14 (permalink) | |
#15 (permalink) | |
#16 (permalink) | |
#17 (permalink) |
Deerslayer &
Staff and Bluestringer got it right! Hand tighten and maybe another 1/8 turn. Test by trying to loosen by hand, can't loosen? Tight enuf...can loosen, tighten some more (another 1/8 turn). If you f*rt while tightening, it's too tight...go check your pants!
T-man VROC #12333 2005 V2K Ltd 2001 1500 Classic FI http://www.geocities.com/tensman_99/mcpics.html |
#18 (permalink) |
"Gone"
My original filter was Over torqued.
What the heck were they thinking when they installed it??? I just did mine yesterday, Just snugg it up, and give it a 1/8 or 1/4 more turn and thats just fine. Dave
When In Doubt, Use Sea-Foam it won't let you down. ALWAYS CARRY DUCK TAPE
#19 (permalink) |
Thanks for all the info guys, have ridden to work 66 miles roundtrip last two days, it has been as high as 85 here, hope I'm not making anyone feel bad, lol, Doc.
2006 1600 Classic Ebony Cobra Slashdowns Power Commander III Scorpion |
#20 (permalink) |
Turtle Wax Taster
OK, here it is straight from the Kawasaki service manual for the '03/04 ZX-6R/RR:
Oil filter torque: 23 ft-lb (3.2 kgf-m, 32 N-m) NOTE: - Hand tightening of the oil filter can not be allowed since it does not reach to this tightening torque. (Yes, that is a literal quote of the Engrish)
