+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 55
Thread: And the Lord said "Let there be blue LEDs"!!
  1. #1
    The creepy uncle BTK Expert insolentminx's Avatar
    Join Date
    Mar 2008
    Location
    London, England.
    Posts
    18,947
    Default And the Lord said "Let there be blue LEDs"!!
    hahahahahahahahahahahahahahaha!
    Oh yes... it took me about 3 hours, no blood, lots of sweat and nearly a few tears; but my StreetFX electropods LED light kit is fully installed, fully functional and freakin beautiful!!!
    I wanted the cleanest install possible, so first i mocked up where i wanted to place the light pods. Included in the kit were 6x 6LED pods (wired as 3 pairs)and 2x 6LED strips.
    Sadly the housing for the LEDs was a shiny plastic 'chrome' which made for a difficult stealthy installation. Never-the-less, i slipped 4 pods under the tank (2 each side, 2 above the front cylinder and 2 above the rear). The last pairing of pods i wanted under the rear fender. The 2 strips were destined for underneath the bike frame to illuminate the road.
    Actual locations for under the tank was a little restricted as i wanted the units to be as hidden as possible, yet to provide as much light as possible. To aid a tidy wiring structure I unbolted the tank and was able to lift it 4 inches to help shove the wires in amongst the current wiring. I then fed the wires through a hole just under the tank/seat mount which pops out in a nice empty void infront of the battery where i intended to route all the wires for this project. The pods were secured in place with provided double-sided sticky foam pads.
    I originally wanted the switch to be hidden under the tank, but the wires weren't long enough for a tidy installation, so i ended up feeding the wires under the seat from just above the ignition, and that's where the switch ended up fitting best with another foamy sticky pad (small switch visible in pic just above the ignition)
    Locations for under the frame were difficult as the strips were quite bulky and long. I found possibly the only 2 locations were under the seat-end of the frame. I wanted one closer to the front but there just wasn't a spot for it which would render the shiny housing invisible and provide enough light. These were fixed in place with cable-ties and pointed so the rear lights were aimed to the rear and the more forward strip was pointed forward a little... the foam pads i think would have been insufficient, so just opted for 2 cable ties on each unit. Wiring for these 2 units was routed between the pipes and the frame, running up under the right side cover and is concealed perfectly!
    The final 2 pods are located under the rear fender. Wiring for these was fed through the small hole in the fender for the taillight wires. Loose wire was held away from the tyre against the metal fender supports with another cable-tie and the pods were secured with the sticky foam pads again.
    Then moving back to the wires from the pods, i cut them to a reasonable length so that i wouldn't have to deal with loads of excess wiring. I stripped them enough to enable a trouble free connection and with 4 red wires and 4 black wires I linked them into a small plastic connector and then joined them with the switch's red and black.
    I then wired the swtich's wires directly into the battery and suffered a monentary bout of mental breakdown after recurring troubles with dropping one screw into the tightest of spaces and struggling to recover it (15 minutes of my life wasted!!). ... I put my bike back together and basked in the glory of a beautifully neat, tidy and educational installation.
    I was chatting with JC (FL Vulcan Rider) who was considering a professional installation for LEDs... I can safely say that with one of these kits, there's no need to pay extra to have someone fit it. The kit itself was $55 from Eastern Performance on eBay. Compared to £50 for the same kit in the UK it was a bargain. And best of all i got semi-nekkid, oily, dirty, hot and sweaty while fiddling with my bike like a real man should!! (I think Cheri will like that part... sadly no pics of that though!)
    I just can't wait to go out riding at night now!!
    The only annoyance is that the switch isn't hidden. I am a little worried that the battery may be drained if the lights are switched on while the bike is off, and by having the switch visible it might tempt a curious annoying passer-by to flick it... but i hope that won't happen. Otherwise i'm thoroughly impressed with my handiwork and love love LOVE the result!
    Steve
    Honda CBR 600RR
    Kawasaki VN900 Custom - sold
    IBA #40198
  2. #2
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    OOOHHHHHH it's looks good! Congrats on the new lights. And yes, Cheri won't be happy with you!
    It's 2am your time, don't you sleep?
  3. #3
    Join Date
    Mar 2008
    Location
    London, England.
    Posts
    18,947
    Quote Originally Posted by A2rider View Post
    Haha, yeah, i was thinking of taking a pic for her.... but i don't want to start posting semi-naked pictures of me on here until i've got a bit of a tan...
    And yes... 2am. I was out with friends having a quiet drink, got back and finally found time to upload pictures and write about my installation. I don't have to be up early tomorrow. I also took the last 2 pictures of the bike with my tripod now that it's properly dark so no daylight could creep into the garage and spoil the photos.
    Glad you like
    Steve
    Honda CBR 600RR
    IBA #40198
  4. #4
    Bridal Boutique Manager BTK Expert mshumate99's Avatar
    Join Date
    Mar 2008
    Location
    Jackson, Oh
    Posts
    346
    Hell yeah brother. Looks great!
    MITCH
    2008 900 Custom
  5. #5
    Missy Peregrym's #1 fan! Forum Supporter c_law23's Avatar
    Join Date
    Jul 2007
    Location
    Newark, OH
    Posts
    7,647
    nice, they sure are bright!
    Chris
    VROC #24810
    Black 2007 900 Custom (sold)
  6. #6
    Stealth Custom Forum Supporter Trashman900C's Avatar
    Join Date
    Jun 2007
    Location
    Long Island, NY
    Posts
    4,833
    nice.........ive been thinking about some red ones.........i dont ride too much at night tho...........
  7. #7
    Riding daily BTK Expert Utah Motorcyclist's Avatar
    Join Date
    Nov 2007
    Location
    Orem, Utah
    Posts
    4,672
    Looks good!
    Jared
    1600 Nomad
    VROC#26705
    KawaNOW#01051
    http://www.utahmotorcyclist.blogspot.com/
  8. #8
    Cruising In Fourth Gear BTK Intermediate eric.hare's Avatar
    Join Date
    Jun 2007
    Location
    Columbia KY
    Posts
    215
    Looks great, I'm looking at finishing my LED's with the under frame and rear fender. Did you install a relay or fuse in line with your switch wiring?
    Thanks for sharing the detailed instructions and great pics.
    2006 900 Classic (formerly)
  9. #9
    Red Rider BTK Beginner
    Join Date
    May 2008
    Location
    casselberry,fl.
    Posts
    46
    looks great going to install clear next weekend myself thnx for showing the bike off. I am afraid i am going to spend more on mods than i did for the bike lol
    peace
  10. #10
    Inactive SoCalMeanie's Avatar
    Join Date
    Jan 2008
    Location
    Corona CA
    Posts
    26
    looks great, I haven't been up till 2 AM working on the bike, or posting pics, but I know the feeling....
    Bring out your MEAN STREAK
    Steve in So Cal
  11. #11
    NXT Wax Inhaler BTK Expert Blooze's Avatar
    Join Date
    Apr 2007
    Location
    Amarillo, TX
    Posts
    808
    What kind of volts/amps does a setup like that pull? I use blue LED's in my amplifier builds occasionally and they definitely take more volts/amps than your typical red ones.
    '07 1500 Classic --Ebony Black
  12. #12
    Clutch Cadet BTK Expert
    Join Date
    Feb 2008
    Location
    Fallon, Nv.
    Posts
    382
    Looks great!! I was wondering about going direct to the battery instead of through the ignition, but led's use very little current so even if you leave them on they shouldn't drain the battery too much.
    2008 VN900 Classic
  13. #13
    Join Date
    Apr 2007
    Location
    Amarillo, TX
    Posts
    808
    I was just curious on the specs as I typically run a single blue LED at between 3.5-5V forward voltage @20-30mA (where a red one will be 1.5V at 3-4mA). They are VERY bright at that level. So bright you can't look at them directly. I have to pad them way down if they are directly visible.
  14. #14
    Join Date
    Mar 2008
    Location
    London, England.
    Posts
    18,947
    I bought a complete kit from StreetFX. Their kits run of anything with a 12v battery.
    It doesn't give any electrical details, you just stick them in place and wire them through the switch and 1 amp fuse directly to the battery. There's no dimming options, it's just on or off.
    I wish it was winter so it could get dark earlier!!! 8:15pm and still very light out!!
    Steve
    Honda CBR 600RR
    IBA #40198
  15. #15
    frequently disturbs class BTK Expert skewterdewd's Avatar
    Join Date
    Sep 2007
    Location
    Portland Oregon
    Posts
    2,183
    Nice writeup on the process, and the end result looks awesome.
    I especially like the lights on the lower frame member.
    That should get you plenty of attention.
    You might need to give the cape a re-think. It could be too much with the LEDs. Unless you were, say, from the future....
    Nice work brotherman. Keep it going!
    They all do that.
  16. #16
    Sit speling cheker BTK Expert Neverdun's Avatar
    Join Date
    Apr 2006
    Posts
    437
    Wicked Sweeeet!!!
    I've been meaning to do this to mine for awhile now.
    Looks like you might have just juiced me up enough to Get er Dun
  17. #17
    Join Date
    Mar 2008
    Location
    London, England.
    Posts
    18,947
    an LED cape, maybe?? ...
    Hmm, you're right, i don't think the cape or speedos will be necessary now that i have the LEDs.
    I should have my pipes by next weekend, so I think the pipes and LEDs should provide enough attention! I noticed a few people checking the bike out today actually. Maybe i was exuding self-confidence... ?
    She's nearly 'finished'!!! Woop Woop!
    Quote Originally Posted by Neverdun View Post
    Wicked Sweeeet!!!
    Gir-r-done!! It was easy, real easy.
    Steve
    Honda CBR 600RR
    IBA #40198
  18. #18
    V2K In Torque We Trust Forum Supporter Van's V2k's Avatar
    Join Date
    Oct 2007
    Location
    Huntington Beach, CA
    Posts
    1,121
    They look real good. I Must see if they have Kawasaki green lights.
    Van's V2k
    In Torque We Trust
    VROC #25501
    ROG#548
    Patriot Guard
    2005 Black V2K
  19. #19
    Join Date
    Mar 2008
    Location
    London, England.
    Posts
    18,947
    Quote Originally Posted by Van's V2k View Post
    pretty sure they do!
    Blue's my favourite colour (along with black and silver...) So i thought it made the best colour combo for my bike. Plus it matches my helmet.
    I was toying with the idea of Kawa Green or red... cos black and red does look awesome... But decided on blue in the end.
    Steve
    Honda CBR 600RR
    IBA #40198
  20. #20
    RIP Mark Forum Supporter wild_deuce03's Avatar
    Join Date
    Mar 2008
    Location
    I lost a brother and a friend. Mark will be sorely missed!
    Posts
    14,883
    Didn't know what to expect but that looks pretty bad a$$! Nice job.
    R.I.P Spike - Nov 97 - 23 Aug 2010
    "Forever our protector!"
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Search Engine Optimization by vBSEO 3.5.0 ©2010, Crawlability, Inc.
