Old 06-27-2008   #1 (permalink)
jabbott
Foil Inspector
jabbott's Avatar
Default LED Bulbs
Just fitted LED bulbs to front and back turn signals. They are direct replacements for the stock bulbs, same base fitting, but a cluster of LED's. I was not sure how the lighting would be effected, but soon found out. The result was that when the handlebar switch was operated, all four turn signals flashed at the same time, fast, including the instrument panel indicator. I fitted a resistor pack to each bulb on the rear and hid them under the plastic cover under the rear fender where the wiring joins the harness. Now the turn signals work fine, including the instument panel indicator, but they flash a little faster that the stock. The self cancelling feature also continues to work fine. I could fit the resistor packs to the front turn signals which would slow down the flash rate to the standard, but I actually prefer the slightly quicker flash rate as it seems to be more visible. The resistor pack gets slightly warm, but not hot and therefore not a problem. If the same resistor pack were fitted to a bulb which was lit continuously then the resistor pack would get quite hot and care would be needed as to where it was located. Thought I would pass this info on in case anyone was planning to do the same, 1600 Nomad.
jabbott is offline   Reply With Quote
Old 06-27-2008   #2 (permalink)
jateureka
Hi jabbot,
Do you know what the actual resistor value and wattage is used in the 'resistor pack'?
Candy lime green VN900 Custom
jateureka is offline   Reply With Quote
Old 06-27-2008   #3 (permalink)
jabbott
Foil Inspector
jabbott's Avatar
Sorry, the resistor pack was sealed, without any external markings. I think it is an easy value to determine, given watts/amps, for an electrical person that is.
Old 06-27-2008   #4 (permalink)
jateureka
I guess you could measure the resistance of the OEM light bulbs and determine an equivalent resistor value to go with the new LED replacements.
Old 06-27-2008   #5 (permalink)
E-J
Every day is a good ride
E-J's Avatar
Send a message via Yahoo to E-J
How visible are they on a bright day with the sun shining directly on them?
Daytona Biketoberfest 09
E-J is offline   Reply With Quote
LED Right Angle Bulbs thetasigma1186 Kawasaki Cruisers 0 03-29-2008 05:49 PM
Xenon Lights dusty30 Kawasaki Cruisers 40 02-01-2008 04:08 PM
LED turn signal bulbs c_law23 Kawasaki Cruisers 9 01-29-2008 04:25 PM
LED bulbs for 800A? su1kil Kawasaki Cruisers 3 11-19-2007 11:46 AM
LED bulbs bikeaholic Kawasaki Cruisers 7 12-24-2004 03:08 PM
