LinkBack | Thread Tools |
Forensic Bug Splatter Analyst
I know about the BP1210H4 replacement for the 900 headlight. I would also like to swap out the stock bulbs in the Cobra Light Bar for something more powerful. Any suggestions on a bulb that won't overtax the 900's electrical system? I just want bulbs that "plug'n play" without having to fool with new relays, etc.......
Bagel - another name for a Jewish rabbit dog.... |
![]() Join Date: May 2006
They are H3 bulbs. You can upgrade to 35watt bulbs or even 55watt bulbs.
Do you already have your lightbar on a seperate circuit? If you do...you can use the 55watt bulbs. I used the 55watt bulbs for 2 years on my 900 and had no problems what so ever. I also use the 55watt bulbs on my Nomad that I have now. Just change the bulbs to a higher wattage.
2008 VULCAN 1600 NOMAD |
#4 (permalink) |
Needs A Real Job
+1 on Refugio's tips. I really think that the 25W H3 bulbs are bright enough, assuming that you have them beamed on the right direction. 35W H3's are a lot easy to acquire, but depending on the wiring of bar...this alternative should not pose a problem on your electrical connection. Personally, I think 55W is an overkill especially when you have your high beams on at the same time.
'06 Vulcan 900LT (previous ride) '07 Yamaha Venture (Love this bike) Keep riding! |
#5 (permalink) |
Can't find time to ride
Just go with the 55w H3 lamps. The 25w lamps are almost impossible to find and the 35w are semi-hard to find. I've had zero issues with running the 55w H3's in my cobra light bar. The brighter the lamp the more Cagers are more likely to see you and not kill you. 55W H3 lamps run about 5 bucks or less and you can get them anywhere.
2006 Kawasaki 1600 Vulcan Classic US NAVY 88-92 during the truely justified Iraq war. |
#6 (permalink) |
Foil Inspector
I had to replace mine bulbs a few days ago. wanted the 35 watts but couldn't find any. couldn't find the 25 watt bulb either. even went to the local honda motrcycle dealer, but all they had was 55 watt. I went ahead and bought a couple. later that day saw some h3 55 watt bulbs at advance auto parts. 55 watt bulbs are alot eaiser to find. I run my spots on low beam off on an access. relay. I'm still worry it may be to much on the system, because I used a napa 80-100 watt headlight bulb. low beams will be pulling 190 total watts. can anyone tell me if this is to much? without the relay I wouldn't used the 55 watts bulb. be to much on the fuse.
#7 (permalink) |
Needs A Real Job
The first 25W bulb that I purchased was from my dealer and it came from a Honda parts and accessories package. Their parts representative stated that the Goldwing uses 25W H3 bulbs as an OEM replacement. COBRA sells them for $7.00 + each by this time.
#8 (permalink) | |
The mechanic wired my bar to the accessory wire so that the driving lights come on when the key is turned on (not when the engine is started). Does that sound OK to run those 55 watters?? ![]()
#9 (permalink) |
Ridden like a Ford!
no. you will run very close to the fuse rating. find yourself a pair of 25w bulbs or run a new circuit and then you can run the 55w bulbs (recommended anyway)
2001 Black Mustang GT 2005 Phantom Silver 1500 Classic Royal Purple synthetic oil in both |
#10 (permalink) |
IBA#34418
When I asked Cobra for a replacement part number they told me I could go as high as an H-3 35W. I have been using those. But.... The Cobra light bar really goes thru the bulbs. Not happy with it.
If you like your freedom thank a Vet! U.S. Navy Vet 2006 VN900LT |
#11 (permalink) | |
My lightbar's relay was powered from the running lights so the lights came on as soon as you would turn on the key....No starting issues or fuse issues. I now have the exact same lighting on my Nomad except now the lightbar's relay is powered from the blue wire with yellow tracer out of the headlight bucket....So the lights do not come on till you start the bike..Like the headlight does. Also...I can not use the lightbar by turning off the switch on the lightbar. Hope this helps with anybody's worries on overloading the 900 electrical system.
| Light Bar Question??? | mcneese5 | Kawasaki Cruisers | 5 | 02-25-2008 05:08 PM |
| Xenon Lights | dusty30 | Kawasaki Cruisers | 40 | 02-01-2008 04:08 PM |
| 900 headlight bulb replacement | yourkillinme | Kawasaki Cruisers | 18 | 08-01-2007 10:34 PM |
| Installing Light Bar. Questions about unplugging the turn signals | NomadNorm | Kawasaki Cruisers | 1 | 10-03-2006 07:02 PM |
| Turn signal plugs for the light bar? | NomadNorm | The Mechanics Corner | 0 | 10-03-2006 06:14 PM |
