Old 08-08-2008   #1 (permalink)
Vulcanrider86
Vulcan 800 Classic
Vulcanrider86's Avatar
Send a message via AIM to Vulcanrider86
Default OK having a brain fart today.....
OK on my 800 classic how do you adjust the rear spring. I do not have the ability to get the rear tire off the ground right now.
Vulcanrider86 is offline   Reply With Quote
Old 08-08-2008   #2 (permalink)
azwiley1
Former foxhole digger
azwiley1's Avatar
Send a message via AIM to azwiley1 Send a message via MSN to azwiley1 Send a message via Yahoo to azwiley1
Take the seat off? Just guessing but that is how I have to do mine.
Larry
US Army 1989-2005
Desert Shield/Storm/Provide Comfort Vet
PGR Member
azwiley1 is offline   Reply With Quote
Old 08-08-2008   #3 (permalink)
PainlessWolf
Wants better weather!
PainlessWolf's Avatar
On my Drifter, you remove the left hand side cover (one without the lock) and you can see the nut for adjusting the shock. Don't know about the Classic but might be similar.
Painless Black Wolf
...Here for the Dawn...
2005 Drifter 800
PainlessWolf is online now   Reply With Quote
Old 08-08-2008   #4 (permalink)
B.O.A.T.
Loud Pipes Save Lives!
B.O.A.T.'s Avatar
Check here (step by step w/ pics)
Tweek's Vulcan
Cruiser
Here is the text only....
Remove the right side cover and peep inside. It's easy to get to the shock preload collar from there. Using a long screwdriver and BIG hammer and tap (read _KNOCK_) the collar around to the desired setting. It is tight, and will turn easier if you get the rear tire up off of the ground, but it can be adjusted either way (bike up or down).
There are 7 possible settings on it. It comes from the factory set to it's softest position. I experimented with my settings, trying everything from #1 to #7. I settled on position #5 when riding by myself, and I couldn't believe the difference! The bike rides like it has a new suspension. When riding 2-up with travel baggage, I set the shock to position #7. The ride with me@200 lbs, Debbie@115 lbs, and about 40 lbs of luggage is great on bumpy roads that used to nearly knock our teeth loose
Another (and I think EASIER) way to access the preload collar on the shock is to lift the rear wheel, remove the cover over the front pulley (or sprocket, if you're still running one of those greasy chains!), insert a long punch or straight blade screwdriver just above the belt (or chain) to the collar. Less stuff to take off, and it's a great way to access the collar on the shock.
If your shock is too soft, or you are still bottoming out on hard bumps with the preload set to it's highest point (#7), click the link below and check out the new Preload Improvement kit at SCOOTWORKS Belt Drives, lowering kits, handlebar risers, motorcycle parts and accessories, chrome bolts. WHen you get there, click on 'Online Catalog' in the LH menu, select Kawasaki, then "Lowering Kits". This will provide 14 additional preload settings to improve soft shocks or heavily loaded bikes.
VULCAN 800A
B.O.A.T. is offline   Reply With Quote
Old 08-08-2008   #5 (permalink)
Vulcanrider86
Vulcan 800 Classic
cool thank you i'm hoping to get a air operated lift soon so Thanks all for the info.
Rode to work today Ryguy Kawasaki Cruisers 22 11-08-2007 12:02 AM
Nice photo opportunity ride today fireman57 Main Lobby 2 07-22-2007 08:02 AM
Brain Transplant BigJohn Off Topic 9 04-06-2006 04:03 PM
Moving sucks, REALLY cold ride today too. zx10tod Off Topic 6 01-23-2006 11:24 AM
Today is "Idiot" Day!!!! NinjaGirl Off Topic 23 02-07-2005 11:12 AM
