Old 08-21-2008   #1 (permalink)
Phat_Kaw
Finally Got Into First Gear
Phat_Kaw's Avatar
Default oil on spark plug??
I just took my plugs out to try and clear up this jerking that my VN800 has been doin. The front cylinder plug was good just needed cleaned a bit, the back cylinder plug weeeeellll.....I took it out and it had oil on the part u put the rachet on and on the ceramic part of the plug. The spark end was fine, just like the front just needed cleaned up. So what would cause oil to get up the spark plug hole like that?? What can I do to stop it?? Thanks.
That which doesn't kill you, only makes you stranger.
Phat_Kaw is offline   Reply With Quote
Old 08-21-2008   #2 (permalink)
MFolks
Wants better weather!
A leaking getting ready to fail gasket? How's the compression? any excess oil consumption? First time for this happening? Head bolts tight?
Old 08-21-2008   #3 (permalink)
Firechicken
Firechicken's Avatar
Sounds like the o-ring seals on the spark plug tube are leaking. You have to remove the valve cover to replace them.
Firechicken is offline   Reply With Quote
Old 08-21-2008   #4 (permalink)
Firechicken
Here's a parts diagram. O-rings are #92055 and the tube is #32151. Kinda hard to visualize by the pic, but the tube seals to the valve cover on one end, and to the cylinder head on the other end.
men's rules for women - wouldn't let the wife see Freakinout Off Topic 48 02-26-2008 10:59 AM
98 kx 125 oil plug problem Lynch Kawasaki Motocross and Offroad 7 08-14-2007 05:07 AM
blonde with a flat tire anamosity Off Topic 10 05-29-2007 01:43 PM
Alway remember this when removing/ replacing oil plug hypermike What I learned today 2 09-06-2006 03:44 PM
spark plugs 02MeanStreak Kawasaki Cruisers 11 05-18-2006 06:19 PM
