LinkBack | Thread Tools |
Guinness Imbiber
My Meanie is broken in, and during the break-in period I was very careful not to use downshifting / engine brake to slow road speed.
I guess my question is two-fold: 1) From an engine longevity perspective, what are your thoughts on the impact of engine braking? 2) From a riding safety perspective, what are your thoughts on pros / cons? Thx! TMac
TMac |
Cruising In Fourth Gear
No expert opinion here, but I remember others say that it's not good to engine brake by downshifting. I remember the message being "use the brake, that's what it's there for" or something like that. I think it was a Bikeaholic comment.
Hmmm...I may be off base here but I have always used down shifting on all of my bikes and as far as I can tell there have been no adverse results of that. Of course if your down shifting at high RPM'S then that may cause some pressure issues and eventual oil leakage and burning. I'm sure an expert can give us all of the details about this?
#4 (permalink) |
Deerslayer &
To quote myself as I say it often, YA GOTTA BE S***TING ME! Engine braking is definitely the way to go and it does not harm the engine, IF you use it within reason. "Within reason" is not overrevving the motor and driveline. I got 26K miles and have engine braked from day one on my 2001 1500 Classic FI and my previous 3 bikes. I also have lots of brake pad left. You have to do it right: which means blip the throttle to match engine rpm with clutch rpm at the selected downshift point. That way you don't wear out the clutch. All you are doing is using the engine as an air pump to slow the bike. The few extra revs won't hurt and the engine will actually be cooled somewhat more uniformly by the extra pumping of oil and water compared to idling with a pulled in clutch. Eventually, Kaw engineers will catch up with automotive engineers and limit fuel input even further than they do now in periods of high manifold vacuum, but still it is inconsequential in these small motors.
T-man VROC #12333 2005 V2K Ltd 2001 1500 Classic FI http://www.geocities.com/tensman_99/mcpics.html |
#5 (permalink) |
V2K Blingaphile
Yes, it's always good advice to not do anything to over-rev your bike when breaking in.
Yes if you're Michael Schumacher and you're already redlining your engine 99% of the time, using engine braking probably isn't such a good idea. I've engine braked on all bikes AND in my TT Quattro. Haven't had any hassles yet. Who are these scaremongers? Must be those who've only ever driven automatic transmission cars and have no idea what engine braking is. Come to think of it, I occassionally use engine braking on my automatic stationwagon as well. Haven't killed it yet. But I'm trying. LOL There is a practical safety side to it. Decelerating with a louder engine dragging rumble helps let cagedrivers know you're coming and not to make sudden lane changes. Hmm.... Wonder if i should take the Power Commander off and restore the popping.
VROC17211 ROG189 UMC38326 V2KBUM#3 www.cruisercustomizing.com/lee_2061 www.flipdrive.com/silkfire
#6 (permalink) | |
RIP Deron Harden :-(
David - Moderator 2002 Suzuki DRZ400 2003 1500 Meanie, scraping pipes and frame :-) In loving memory of Deron Harden, forever in our thoughts :-( |
#9 (permalink) | |
i wonder if i can get a jake brake on the Nomad......
#13 (permalink) |
I was at D.O.D #1!
I drag my feet!
(I can't claim that one...a similar thread popped up once before, and that was one of the funnier responses I remember!)
1998 Vulcan 800 classic "Grit, spit, and a whole lot of duct tape!" My motorcycle pics! |
#16 (permalink) | |
Kawaski Rep 2090
#19 (permalink) |
Turtle Wax Taster
I try to engine brake as much as possible. When I'm on a track I engine brake even more. My bike has a slipper clutch so I don't have to worry about the bike locking up or anything. Don't know if its bad for the engine or not but its made for engine braking so thats what i do.
#20 (permalink) |
![]() Join Date: Jan 2009
I see this issue having a similar component to the other thread running right now "1 Foot vs 2 Feet. Neutral or 1st?" http://www.kawasakimotorcycle.org/fo...etral-1st.html
If when you are stopping you don't use engine braking, what do you do if you need to take evasive action requiring an application of power? If you are simply clicking down through the gears, how are you sure that you are in the right gear for power when you need it? I have been told that our "wet clutches" greatly minimize wear but that routine engine braking should not be done with dry clutches as it is much cheaper to replace brake pads than clutches. And my last comment, I think engine braking sounds really cool on a V-twin. How's that for scientific? -Dwain |
