Old 10-01-2009   #41 (permalink)
04VN1500
Turtle Wax Taster
Originally Posted by cjguru View Post
OK, I was with you until you said "marbling". How do you tell the difference between a carb backfire and an exhaust one? Is there a different sound or do you just watch the exhaust?
Sorry for my ignorance... I just bought the bike in August so am learning as I go.
Exhaust back fire will go all the way out the tail pipe. Carb backfire will be at the carb and typically you might feel a little of the blast on your legs. You have an air injection in your exhaust pipes.
Do a search on Marbling. There are some good detailed threads about it, complete with pictures. But I would check/change your exsiting exhaust gaskets as well.
Also, exhaust backfire will be when you let off the gas, carb will be when you first get on it. Giving it the gas with a back fire means you are lean. Jet up a little. You may only have a stage 1 jet kit. You may need to go to stage 2.
There is always raw unspent gas in the exhaust but it usually will not detonate unless you have an exhaust leak which would suck air into the exhaust allowing enough oxygen to ignite the raw fuel. I personally am not impressed with the marbling thing. If that was the problem, to me it should cause the problem at all times. Both with stock and aftermarket exhaust.
Ok, I am rambling now...........
04VN1500 is offline   Reply With Quote
Old 10-01-2009   #42 (permalink)
04VN1500
Turtle Wax Taster
Oh, and you will not ever average 40 mpg mixed on that bike. I get about 120 miles per tank MAX on straight highway riding before I have to go to reserve. Mine is all stock. Just gutted pipes. I get 28-32 in the city pending how hard I ride. 38-42 on all highway riding just cruising.
Old 10-01-2009   #43 (permalink)
cjguru
Loves to ride.
cjguru's Avatar
Cool!! Thanks! What do you think of the gtank? GMan Industries | Built By Bikers For Bikers | 250+mi Vulcan1500 Classic range with Auxiliary Fuel Tank - GMan Industries
I want to increase my range to 160+ miles, because I live 80 miles from work. (Luckily, I only go in once a week and tele-work other days..)
Putting the pipes on.
cjguru is offline   Reply With Quote
Old 10-01-2009   #44 (permalink)
04VN1500
Turtle Wax Taster
Actually I like the idea of the Gtank. Just as long as it is not too close to the exhaust. It would aid in jacking up the motorcycle as well.
Old 10-01-2009   #45 (permalink)
NCDave
Novice Tank Roller
NCDave's Avatar
Have you seen this?
Aux Tank
I always thought this would be cheaper than the GMan. You could even go cheaper than this with a standard plastic gas can and a little bit of plumbing. The idea of the bag to carry it in seems like a good dress-up for the bike too.
NCDave
Our Lady of Blessed Acceleration, don't fail us now. - Elwood Blues
http://www.bikepics.com/members/ncdave/
NCDave is offline   Reply With Quote
Old 10-01-2009   #46 (permalink)
Cranky CJ
98' 1500 Classic
Cranky CJ's Avatar
something has to be wrong here. i easlily get 44-46 mixed, 48-50+ highway cruising. interstate 75+ it dropps back to low 40s. i hit reserve at about 165 miles. 98 1500, hard krome exhaust and stock intake, metzler tires at about 36-40psi, running on 87 oct at 5000' elevation.
My Toys:
98 1500 Classic
04 HD XL1200C
1986 CJ7
1911A1
Cranky CJ is offline   Reply With Quote
Old 10-01-2009   #47 (permalink)
cjguru
Loves to ride.
cjguru's Avatar
Originally Posted by NCDave View Post
Have you seen this?
Aux Tank
Yeah (I saw those), what I like about the Gman is where it is placed... (doesn't interfere with anything and takes away the "hole" that was created by replacing the exhaust. (looking at the bike from the right side, it looks "skinny" in the mid section now..)
I am not an engine guy though, so I worry a little about the dual fuel pumps and having to turn 1 pump on while you are filling up your tank...
Old 10-01-2009   #48 (permalink)
NCDave
Novice Tank Roller
NCDave's Avatar
You're fortunate. Most will run in the low to mid 40s on a good day, of course, depending on driving style. After adding exhaust, instake, and carb mods, I was only getting mid 30s to low 40s. That seemed to be the reported "norm".
NCDave
Old 10-01-2009   #49 (permalink)
NCDave
Novice Tank Roller
NCDave's Avatar
I had thought this other one was a more cost effective option, and could be easily removed when travel requirements didn't dictate it. I do understand about the "hole" thing though. I never did find a good solution for that.
NCDave
Old 10-01-2009   #50 (permalink)
Cranky CJ
98' 1500 Classic
Cranky CJ's Avatar
I guess so, but I also drive like an old man.
My Toys:
98 1500 Classic
04 HD XL1200C
1986 CJ7
1911A1
Old 10-01-2009   #51 (permalink)
NCDave
Novice Tank Roller
NCDave's Avatar
Hah! That must be it. I NEVER drive slow unless my wife is on the back whacking me in the arm.
NCDave
Old 10-01-2009   #52 (permalink)
04VN1500
Turtle Wax Taster
Carb'd? You either have a freak accident of a bike. (which is a good thing) Or your gas tank is bigger. (or you are bad at math. .........just joking) The mileage you are showing is usually fuel injected.
Old 10-01-2009   #53 (permalink)
Cranky CJ
98' 1500 Classic
Cranky CJ's Avatar
It's carbed being a 98. bigger tank? naw, same one they all have. bad math? i'm right 97% of the time the other 4% its due to bad information.....freak of a bike? who knows.....
My Toys:
98 1500 Classic
04 HD XL1200C
1986 CJ7
1911A1
Old 10-02-2009   #54 (permalink)
pcarrell
Just A Guy
pcarrell's Avatar
I have a 2001 drifter 1500 and I used to get 42-45mpg regularly on 92 octane. Last spring I swapped out my clutch spring for a Meanie spring and two part holder and my mileage bumped to 45-48. Most of my riding is country roads at 55-60mph, but there's a little city and a little hiway thrown in too. Now my last tank of gas only saw 39mph, but that was a problem with my wrist, not the bike!
Pastor Dude
2001 Drifter 1500
pcarrell is offline   Reply With Quote
Old 10-02-2009   #55 (permalink)
vulcancowboy
Love my 1500!
vulcancowboy's Avatar
I average 38-42 mpg with my ’04 carb’ed w/V&H straight shots.
Jim/1500 Classic
When the people fear their government, there is tyranny;
when the government fears the people, there is liberty. Thomas Jefferson
vulcancowboy is online now   Reply With Quote
Old 10-05-2009   #56 (permalink)
skiman762
Made It To Second Gear
From my reading the vulcan speedometers can be of as much as 8-10% that might explain the different mpg's being posted I checked mine and it's off by 7mph at 70 indicated I'm only doing 63 on gps
skiman762 is offline   Reply With Quote
Old 10-07-2009   #57 (permalink)
zuke
Foil Inspector
40-43mpg. k&n 8" filter and VnH drag pipes. on 89octane.
i treat women like i treat bikes. i ride em' till they explode then i ditch em' on the road.
zuke is offline   Reply With Quote
Changing Exhaust From a 1500 Nomad to a 1500 Vulcan Classic fredrvulc Projects and "How To" Write Ups 0 05-04-2008 08:35 PM
Just bought a 2001 Vulcan 1500 Classic FI kveloso Kawasaki Cruisers 11 03-05-2007 02:04 PM
gas mileage mxz600 Kawasaki Cruisers 5 07-17-2006 06:40 PM
Vulcan 1600 gas mileage jiffyjam Kawasaki Cruisers 14 04-10-2006 08:03 AM
For Sale POWER COMMANDER 1500 VULCAN FI Doug Accessory Swap Meet 3 02-17-2005 02:32 PM
