Old 05-11-2005   #1 (permalink)
Green_Streak
Third Gear And Gaining
Default Mean Streak Spark plug replacement
OK, so I am no Rocket Surgeon.
But went to replace spark plugs today. Front right and rear left were a breeze, but rear right and front left I could not get socket into hole. THese two have a allen head shaped sleeve around them. How does one who rides the short bus, such as me, replace theese two??
GS
Green_Streak is offline   Reply With Quote
Old 05-11-2005   #2 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
You have to use just a regular 18mm deep well socket. Most spark plug sockets won't fit down there.
Shawn Lattimer
'06 Silver V2K Classic VROC #22980 ROG #464
http://www.shawnlattimer.com
Lattimer is offline   Reply With Quote
Old 05-11-2005   #3 (permalink)
kingofwings
Posting Slacker
kingofwings's Avatar
I used the "socket" from the tool kit that came with the bike.
R.I.P. Deron
kingofwings is offline   Reply With Quote
Old 05-11-2005   #4 (permalink)
grandpawmoses
!cixelsyD toN m'I
grandpawmoses's Avatar
As kingofwings said, the spark plug wrench that came with the bike will fit. I didn't want to dig out the tool kit each time and I'm a firm believer in using a torque wrench (especially on aluminum engines) so I went to the auto parts store & got a 18 mm deep socket (as Lattimer said). I got it for a 3/8" drive ratchet (not sure but the 1/2" drive size may be too big for the hole). Paid $3.60.
07 HD Fat Boy
If you want a clean drink of water
go to the head of the stream
grandpawmoses is offline   Reply With Quote
Old 05-11-2005   #5 (permalink)
SteveA
I use the spark plug tool the bike came with, along with a plain old ratchet & matching socket that fits over the end of the spark plug tool. Works well.
Steve
'04 Meanie
SteveA is offline   Reply With Quote
Old 05-12-2005   #6 (permalink)
Green_Streak
I ended up buying a deep well 18, but had to grind it down in thickness quite a bit. If I had the original tool kit this would have been a no brainer. I am the second owner.
