My Shaft Drive is making noise (?)
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 30
Thread: My Shaft Drive is making noise (?)
  1. #1
    Patriot Guard Rider Extreme Forum Supporter Aifwikir's Avatar
    Join Date
    Jun 2007
    Location
    Magazine, Arkansas
    Posts
    1,694
    Default My Shaft Drive is making noise (?)
    I'm new to this shaft drive on my 1500. I'm wondering how noisey (loud) the whirring/whistling noise is supposed to be. At slow speed (15-30 mph) I can hear it over the engine & road noise. (Even with my pipes being a little louder now)
    I'm sure there isn't a problem with it, just curious about how noisey it should be. I've had it for 2 months and only have 500 miles on it. I hate winter!
    Aif
    Retired US Army & Proud Marine Corps Dad!
    '08 Red/White VN 1500 Classic
    http://www.patriotguard.org
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Needs A Real Job BTK Expert rfb92345's Avatar
    Join Date
    Aug 2007
    Location
    Hesperia, CA
    Posts
    2,344
    Quote Originally Posted by Aifwikir View Post
    Aif
    Mine doesn't make any noise at all.
    '96 Kawasaki Vulcan Classic 1500
    "Happiness is a Colt .45...a cold one and a loaded one"
  4. #3
    Official BTK Forum Pot Stirrer Extreme Forum Supporter Spok's Avatar
    Join Date
    Mar 2004
    Location
    Mount Vernon, Washington
    Posts
    37,377
    um....mine made zero noise as well. I had all the normal engine top end noises on my 1500 but nothing from the drive trane. check to make sure you have oil in your final drive (rear end) and if not, get some in and/or take it to your dealer for a close inspection.
    parts do fail
    AUGUST 2006 MOM
  5. #4
    Join Date
    Aug 2007
    Location
    Hesperia, CA
    Posts
    2,344
    I have had mine apart a few times. The final drive is pretty straight forward if you are mechanically inclined. The only special tool you need is to remove the pinion nut. Unless you are replacing pinion bearings, that is not necessary.
    I would do as Spok suggests. Simple things first. Check the lube...if there is none, put some in. If it continues to make noise, take it apart or take it to the shop.
  6. #5
    '07 ZZR600 Forum Supporter bretsk2500's Avatar
    Join Date
    Jun 2007
    Location
    Wells, Maine
    Posts
    2,363
    a shaft drive should make no noise... if you can hear it over your pipes STOP riding it and find out what's wrong. Hopefully you've not done too much damage (wear) to the bevel gears if it's out of oil.
    '07 ZZR600 Fire Red
    11.957@117
    Jardine RT1
    Factory Pro +4 rotor
    Renthal +2
  7. #6
    Needs A Real Job BTK Expert N3FOLN3FOL's Avatar
    Join Date
    Sep 2006
    Location
    Stewartstown, PA.
    Posts
    2,743
    Your shaft drive may need some greasing on the splines. It could be a case that Kawa did not put enough in there during the build process. With low mileage, you should be covered under factory warranty. My suggestion is to take it back to the dealer and have them check it and get it documented via service receipt.
    '06 Vulcan 900LT (previous ride)
    '07 Yamaha Venture (Love this bike)
    Keep riding!
  8. #7
    Rebel Rider BTK Expert bluestringer's Avatar
    Join Date
    Jul 2004
    Location
    Albany, Georgia
    Posts
    3,644
    Aif
    You sure it's the shaft drive and not just gear whine. The straight cut gears will whine, especially on decel. Check the oil in the pumpkin.
    bluestringer
    2005 Vulcan 1500 Classic FI
    V&H Longshots
    VROC #13910
    GAVROC #159
  9. #8
    Join Date
    Jun 2007
    Location
    Magazine, Arkansas
    Posts
    1,694
    I checked the oil first off. Good-to-go!
    As Blustringer said it may just be the gearbox. I did notice that it does go away when I pull in the clutch. I'm sure it's not anything serious as I don't hear grinding or have any vibration out of it (smooth as silk). It is coming from the left side and I notice it more on decel (2nd & 3rd gears).
    Thanks guys! I'll have the shop check it on the 600 mile check-up.
    Aif
  10. #9
    Sit speling cheker BTK Expert oldodge's Avatar
    Join Date
    Dec 2004
    Location
    Central Pa.
    Posts
    406
    +1 on the gear whine from straight cut gears. I notice mine on decel too.
    2005 Classic 1500
    Memphis Shades, Baron, M/C, CWI, V&H
  11. #10
    Forum Supporter Forum Supporter Ole Yeller's Avatar
    Join Date
    May 2008
    Location
    Space, the final frontier
    Posts
    351
    Like some others have already said, my shaft drive doesn't make any real noticeable noise and, I'm sure that my motor is quieter than yours (I-4).
    My 2 cents would be to take it back to the dealer and tell them about your concerns and have them check it out. That way, if it goes out in the future you will have some documentation. Just because your bike is new doesn't mean that there couldn't be something wrong. Though it is very rare, sometimes brand new bikes have issues. There was a kid last summer on this forum who had a brand new Kaw sport bike and the shifting mechanism failed with less than 100 miles on the bike. Stuff happens.
    4 cylinders are better than 2
    1985 ZL900 ELIMINATOR
  12. #11
    900 Customer BTK Expert sisooktom's Avatar
    Join Date
    Jun 2007
    Location
    Raleigh, NC
    Posts
    901
    I only read the subject, but I'd say you need to see a doctor!
    Plasma Blue Vulcan 900 Custom
    Not riding a Vulcan is illogical!
  13. #12
    Way Too Much Free Time BTK Expert
    Join Date
    Jan 2006
    Posts
    1,138
    The one on my 01 Nomad makes some noise,they all do. My belt drive on my Electraglide is a lot more quiet. In fact I put 85-140 in my Nomad at 15K to try and quiet it down and it blew the inner seal. I put a used unit with 15K and it was noisy like the original. I have 38K on it now and it's still working fine. If you were that close to siting on the rear end in your car or truck you would hear some gear wine also.
  14. #13
    Vulcan 1600 Classic BTK Expert Cruising's Avatar
    Join Date
    Sep 2006
    Location
    Stuart, FL
    Posts
    472
    Aif.... I suggest you take it back to the dealer! There should not be any noise at all. That's the joy of having the shaft - no noise - no maintanance - nothing... take it back.
    Jim
  15. #14
    Join Date
    Mar 2004
    Location
    Posts
    37,377
    Quote Originally Posted by Cruising View Post
    Jim
    i beg to differ. if you refer to your owners manual, there is a drive shaft maintenace schedule at 15000 miles
    here is a how to
    http://www.kawasakimotorcycle.org/fo...2-22-07-a.html
    AUGUST 2006 MOM
  16. #15
    Patriot Guardian Extreme Forum Supporter RichLockyer's Avatar
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    I will get a whine from mine on decel dropping from about 40/45 down through about 25/30 or so (clutch in or out).
    Just keep an "ear" on it and be wary of any change. A sudden worsening, or a difference in sound with the clutch in vs out could be a sign that the bevel gear drive's outer bearing is about to go to bearing heaven.
    That's NOT good and can damage the housing itself.
    It is true that shaft drives are low-maintenance (especially compared to chain-drive), but they are not no-maintenance. Every 15000 miles the gear oil should be changed (I use Mobil-1 75w90), and the swingarm should be removed and the universal joint checked for smoothness and lack of "notchiness", the slip joints on the shaft lubricated, and the swingarm bearings lubricated.
    Fortunately, that is about the same time frame that you'll be changing rear tires, and removing the tire is half the job.
    Spok has done a very good writeup on performing the maintenance... I think it's a sticky in the Cruiser section.
    - Rich
    2006 1600 Ultra-Classic
    Patriot Guard Rider
  17. #16
    Ahhh Crap BTK Expert Classic's Avatar
    Join Date
    Jul 2006
    Location
    Southwest PA
    Posts
    2,344
    I also get some gear noise especially on deceleration but it's almost always there and always has been. Gears make noise. I change the gear oil in the differential about every third oil change and over the past 52,000 miles it's been done so many times it runs clear when I drain it. I change it that often because it's so easy to do when you're already down there changing the oil. Adds maybe five minutes to the whole job so why not?
    Steve
    Darksider #1223
    2010 Honda GoldWing
    2003 1500 Classic - Gone But Not Forgotten
  18. #17
    Join Date
    Mar 2004
    Location
    Posts
    37,377
    Quote Originally Posted by Classic View Post
    thats what I did as well when riding my 1500, man I miss that gem of a ride. anyway, and not to mention that oil is cheap and gears is expensive
    AUGUST 2006 MOM
  19. #18
    Low Voltage High Current BTK Intermediate 12volts's Avatar
    Join Date
    Dec 2008
    Location
    Missouri
    Posts
    217
    My MS made this same noise and only got worse. It ended up needing the bevel gears and bearing replaced.
  20. #19
    Keeper of Donkey Forum Supporter jeffs99vulcan's Avatar
    Join Date
    Jun 2008
    Location
    Ottawa, ON
    Posts
    13,880
    I just read the subject too... is it a ticking? Like, during decel?!
    Jeff - Ottawa, Ontario
    '99 Vulcan 800 Classic
  21. #20
    Starting over
    Join Date
    Dec 2008
    Location
    Frozen wasteland
    Posts
    14
    Change to synthetic oil in the gear box, and do a swing arm maintenence on the bike, including cleaning and lubing of the drive shaft splines.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Drive Shaft Maintenance
    By Metalman in forum Kawasaki Cruisers
    Last Post: 07-13-2008, 03:48 AM
  2. klf 300 4x4 drive shaft front
    By mr351clevland in forum The Mechanics Corner
    Last Post: 07-11-2008, 08:17 AM
  3. 1500 classic and shaft drive question
    By artz in forum The Mechanics Corner
    Last Post: 05-22-2008, 05:00 PM
  4. chrome drive shaft cover
    By dickwol in forum Kawasaki Cruisers
    Last Post: 09-22-2004, 01:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
