Old 05-16-2005   #1 (permalink)
farlz
Finally Got Into First Gear
farlz's Avatar
Default any mean streaks with big bore kit?
Has anyone put a muzzy's big bore kit in their 1500? Just wondering if there are any issues or problems experienced with this setup? I just did mine and am kinda disappointed in the power increase experienced. Anybody else feel this way.
farlz is offline   Reply With Quote
Old 05-16-2005   #2 (permalink)
btuman
What did the kit include? I am guessing pistons, rings, maybe wrist pins. Did you get the cam? I have been curious on the performance increase as well. My guess is that to see a real increase, the heads are going to have to be ported or flowed as they call it now.
btuman is offline   Reply With Quote
Old 05-16-2005   #3 (permalink)
farlz
farlz's Avatar
The kit included high compression pistons, rings, wrist pins. Yes the cams were changed and I had the heads done by Guy Mobbley, formerly from Sherms.
Old 05-16-2005   #4 (permalink)
Sledder
Sledder's Avatar
How much bigger was the bore? Were they the 792 grind cams from web cams?
You may not be getting the correct fuel amounts (need custom pc3 program) to get the most from the porting/cams??
..just curious.
Thunder manufacturing has done a lot of custom work on bb meanies (they did it on their own in house bike),and have some custom fuel curves,etc for the pc 111 and others.
04 MS 1640
Thunder 100 in kit/cams
Race ported heads by "dynoray"
Thunder air
V&H Propipe
PC3
Sledder is offline   Reply With Quote
Old 05-16-2005   #5 (permalink)
tdaugharty
Sit speling cheker
tdaugharty's Avatar
Send a message via MSN to tdaugharty
I wish they offered a kit like this for the 1600. More, More
Thomas Daugharty
Atlanta, GA - http://www.daugharty.com
Seen on a motorcycle’s rearviews:
“Warning: objects seen in mirror are disappearing rapidly”
Quote: "Knowledge produces more knowledge, ignorance often generates overconfidence!!"
tdaugharty is offline   Reply With Quote
Old 05-16-2005   #6 (permalink)
Crue
Ludicrous Speed...GO!
Crue's Avatar
How much was the kit. I think the best way to get the most performance from your Meanie would be with a Mr. Turbo. One of those will get you up and over V2k perfomance and without the extra weight.
Visit Crue's Control
2004 Vulcan 2000 HK 3" Big Straights, TFI, Thunder Teardrop custom
Crue is offline   Reply With Quote
Old 05-17-2005   #7 (permalink)
Phatboy
Rides a lazyboy on wheels
Phatboy's Avatar
Wouldn't NOS be so much easier though
Phatboy
04 1600 Classic Black
02 Dodge Cummins
Phatboy is offline   Reply With Quote
Old 05-18-2005   #8 (permalink)
jnk
Wants better weather!
the kit thunder mfg. or muzzy offer for the 1500 mean streak is 1570cc which is a bit larger than the stock 1600 which is 1553 i think also they are 10:1 pistons instead of the stock9:1 so it is a slight increase thunder has hp and torque curves to look at on their sight
jnk is offline   Reply With Quote
Old 05-18-2005   #9 (permalink)
RED'05 MEANIE
RED'05 MEANIE's Avatar
ok, so if you do all that and the compression goes to 10:1 how does that effect your redline ??
RED'05 MEANIE is offline   Reply With Quote
Old 05-18-2005   #10 (permalink)
tdaugharty
Sit speling cheker
tdaugharty's Avatar
Gearing is gearing so I'd expect it would just redline much faster
Thomas Daugharty
Old 05-18-2005   #11 (permalink)
Crue
Crue's Avatar
Man I would love to get nos on my MS. I have never experienced a shot of nos in any vehicle though and the thought of hitting that button is very exciting/scary. A nice pair of polished bottles would certainly add to the look of the down tubes, or maybe they would look better on the fender struts. Hmmm.
Old 05-19-2005   #12 (permalink)
Phatboy
Phatboy's Avatar
I was in North Carolina asking Lee Sherts of Lee Performance about engine mods for the 1600 and he recommended NOS. This guy does some incredible work on sportbikes including some 200 mph+ ones. I've been thinking about taking him up on it. Once I have my hardbags installed I'll have a great place to mount a bottle =P
Phatboy
02 Dodge Cummins
Old 05-19-2005   #13 (permalink)
jnk
i am not sure but if you call thunder mfg. or muzzy they could answer that i would like to do the mod. but not an option at this point maybe this winter
Old 05-20-2005   #14 (permalink)
ispeed77
RIP Deron Harden :-(
ispeed77's Avatar
Send a message via AIM to ispeed77 Send a message via Yahoo to ispeed77
i saw one for the Nomad on Thunder's site and the kit was about $1000 plus whatever the machine work would cost. for the cost, the power numbers that they were showing were pretty impressive, but i was leary so i didn't do it. if the turbo wasn't so much, that would be the route i would go. the thing with the big bore is you start running into the water jets and reliability becomes an issue. that is the only reason i did not do anything to the Nomad, reliability is too important, especially when i am going on a 5000 mile plus trip.
In loving memory of Deron Harden, forever in our thoughts :-(
ispeed77 is offline   Reply With Quote
Old 05-20-2005   #15 (permalink)
2WheelFun
the "fun old" guy
2WheelFun's Avatar
And therein lies the entire issue! Good decision David!
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 05-22-2005   #16 (permalink)
ispeed77
ispeed77's Avatar
thanks ! my wallet agrees with you !
Old 07-19-2005   #17 (permalink)
aspet
Banned
Question Whats Compression
Hi , can you tell me what compression the Muzzy kit takes the MS-VN1500 engine up to ?? thanks i have heard up to a 12:1 !! im not sure
thanks
aspet is offline   Reply With Quote
