kdx125 starting probs
+ Reply to Thread
Results 1 to 4 of 4
Thread: kdx125 starting probs
  1. #1
    Join Date
    Jan 2005
    Posts
    26
    Default kdx125 starting probs
    it woundnt start just a fire evry so many kicks so i took plug out, rested it on the head n turned it over, heres the problem : it sparks the 1st time it should do but when the engine still turns over it doesnt, if u kick it again it will spark once then not till you kick it again
    is this the coil? cdi? pick up?
    please help someone
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    May 2005
    Posts
    33
    the spark plug should only spark during the compression stroke or once per 4 revolutions
  4. #3
    Still On The Kickstand cARLCROM's Avatar
    Join Date
    May 2005
    Location
    North Florida
    Posts
    32
    4 piston movements (strokes) = two revolutions. .... normally ..... every other revolution should give you spark just prior to TDC
    How many revolutions are you capable of achieving with just one "kick?" ..ie My old BMW has a 20 pound fly wheel, I jump on it and I swear the engine coasts through 4 revolutions.. with the ignition turned off! VBG
  5. #4
    Join Date
    Jan 2005
    Posts
    26
    rewired evrything n its ok must av bin bad connection
    it used 2 turn ova bout 8 times n spark once
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
