Old 07-02-2009   #1 (permalink)
philbo
Question HELP ME PLEASE 1993 KX125 problem
Hi to everyone i'm new to the forum but pls dont hold it against me,i've just got my hands on a 93 kx 125 for a bit of fun it was a none runner but i got it going after a bit of messing about, now my problem is that wen i rev the throttle the transmission oil is bubbling i thought it was maybe water getting in but wen i drained the oil out it smelt of petrol so wher is the petrol coming from? and why is it bubbling? PLEASE HELP
philbo is offline   Reply With Quote
Old 07-02-2009   #2 (permalink)
nd4speed
Can't find time to ride
nd4speed's Avatar
I would guess there is a leak between the case halves in the area around the crankcase.
nd4speed is offline   Reply With Quote
Old 07-03-2009   #3 (permalink)
philbo
cheers i'm gunna have to take it apart and have a llok then. thanks for your help
Old 07-03-2009   #4 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
Do a pressure test and a vacuum test.
If your transmission oil is milky white, then the coolant is leaking into it, usually due to a worn seal on the impeller shaft.
DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
KDXGarage is offline   Reply With Quote
Old 07-03-2009   #5 (permalink)
philbo
but i dont think its coolant that has mixed with the oil as i said it smells like petrol but i cant think how it has got into the transmission?
Old 07-04-2009   #6 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
bad seal between crankcase and trans ... time to pull it down and reseal it all....just be happy it went that way and not the other (sucking oil or water getting in)
QKENUF4U is offline   Reply With Quote
Old 07-28-2009   #7 (permalink)
philbo
cheers
Old 07-28-2009   #8 (permalink)
philbo
thanks for the advice, just wondered is there a transmission breather pipe on the 93 kx 125?
cheers
Old 07-29-2009   #9 (permalink)
dangerousdean19
yes there is a breather it should be just underneath the reed block,a little plastic elbow,if this is blocked it will pressure the gearbox blowing oil out of any seal thats weak
dangerousdean19 is offline   Reply With Quote
Old 08-16-2009   #10 (permalink)
philbo
dont suppose any one knows how much money i'd be looking at to get the seals replaced on my kx?
Old 08-16-2009   #11 (permalink)
dangerousdean19
i recently bought a full gasket set and oil seal set for £44 from the uk and that included posting to australia! its easier to get stuff from uk than it is out here!
Old 08-16-2009   #12 (permalink)
dangerousdean19
the seals are cheap just depends on which one you need to replace as to how much work its gonna be to do
WTB : 1993 KX125 bottom end with gears sniper516 Offroad Buy/Sell/Trade 4 09-02-2008 09:20 AM
1987 KX125 clutch problem monsterman21 The Mechanics Corner 2 03-02-2008 04:52 PM
does anyone know if 93 KX125 parts will fit 86 KX125? simka Kawasaki Motocross and Offroad 5 01-15-2008 01:35 PM
1993 Kx125... 2stroke173 Kawasaki Motocross and Offroad 2 06-18-2007 10:01 AM
95 KX125 Silencer problem green17 Kawasaki Motocross and Offroad 4 05-23-2006 05:31 AM
