i have an '03 kx85 and it runs alright but when i ride, oil comes out the pipe and drips down the outside of the pipe. it gets all over the engine and the airbox and makes a mess. i use a 32:1 ratio in the gas and measure it perfectly.WHAT IS WRONG
#3 (permalink) | |
Another old dirt bike guy
WRONG! It is caused by rich jetting, not your pre-mix ratio. Reducing the amount of oil will make the air fuel ratio richer, and only make the problem worse. Try leaning out the jetting a little bit. Most of the KX85's benefit from leaning the needle one positon too.
'05 KX85 w/103cc engine '97 DR407 '83 CR60 '05 TTR230 '07 250XCW |
#5 (permalink) | |
2001-kx250,,,1995-kx80
Thanks! We have a service manual on its way....will it be in there? |
#6 (permalink) |
Move the needle clip up one position, this drops the needle and leans it out.
I have not jetted any of the older KX80's only the KX85's and 100's so I do not really have any good jetting set-ups for you to try. Most of these little KX's like to drool, I don't know why the Yamaha's and Honda's can be jetted pretty clean, but the little KX's always have a little bit of drool. I have leaned our bikes to the point that they were boggy and too lean to ride, and they still drooled even with new packing in the muffler. So I just jet them where they run good and the plug looks good. We have never fouled a plug after several years of running these bikes, but we always have a small amount of drool, nothing bad, but a small amount none the less.
| Shift drum on a 03' KX85 | hairbear65 | Kawasaki Motocross and Offroad | 7 | 08-07-2008 02:06 AM |
| KX85 to 100? | beerbudget | Kawasaki Motocross and Offroad | 16 | 03-07-2008 04:16 PM |
| building a fast KX85 | r-acer | Kawasaki Motocross and Offroad | 16 | 04-04-2006 03:06 PM |
| '04 KX85 and KX65 too rich | 06KX250F | Kawasaki Motocross and Offroad | 1 | 01-23-2006 09:31 PM |
