1982 KDX80 Carb issues
+ Reply to Thread
Results 1 to 3 of 3
Thread: 1982 KDX80 Carb issues
  1. #1
    Join Date
    Jul 2009
    Posts
    39
    Default 1982 KDX80 Carb issues
    I bought a KDX 80 off a guy for $100. He put $400 into it. Boared it out, New pistons. I put a new coil, and a new plug in. He told me the crank seals are bad. We get it apart and find out that the key had been sheared for the flywheel for the crankshaft. Fix that. And now It starts every so often. I've still never ridden it.
    The thing is. It starts everytime I take the carb off and clean it, but when I put it back on and kick it, I always forget to turn the fuel on. So it will start, run, and sound great. But then I'll turn the fuel on and it won't kick over once. The fuel is good. Mixed right, 50:1.
    I think it may be being flooded. Any suggestions?
    Could the possibilities be the carb? The Reeds?
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Hey, lemme ride your bike BTK Expert KDXGarage's Avatar
    Join Date
    Dec 2005
    Location
    AL, USA
    Posts
    1,964
    I would definitely check the reeds.
    DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
  4. #3
    Join Date
    Jul 2009
    Posts
    39
    I finally rode it!!
    I figured out that when you put the slide into the top of the carb,
    your not supposed to just be able to see the needle. I was just sticking it in and pushing the hell out of it and screwing it down. Making it full throttle all the time. But also, my friend has a 1980 KDX80 and when I rode that, it seemed like it had alot more balls than mine. I don't know why mine seems like it just doesn't want to move as well. Brand new pistons and rings, boared out.
    New spark plug.
    But when I took the case apart I made new gaskets that go between the case around the cylinder. My dad told me I would lose some compression if it's a little bit thicker than the original. Could this be the issue?
    Also, if anyone has any parts for a 1982 KDX80. Let me know.
    I could use: rear fender, side covers, air box, the screw that holds the casing of the throttle cable in the top of the slide.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 95 Vulcan 700 with carb issues...
    By Blake K in forum The Mechanics Corner
    Last Post: 07-10-2009, 01:06 PM
  2. 1978 KZ1000 LTD carb sync issues
    By elpetay in forum Vintage Motorcyle Info
    Last Post: 06-22-2009, 09:42 AM
  3. carb question for 1982 kz440
    By rrich49132 in forum Vintage Motorcyle Info
    Last Post: 03-03-2009, 09:45 PM
  4. 1983 KZ750 Carb vacuum issues..
    By ryanlong1 in forum Vintage Motorcyle Info
    Last Post: 07-14-2008, 01:48 PM
  5. 03 KX 250 carb issues
    By Ffranzwa in forum Kawasaki Motocross and Offroad
    Last Post: 06-08-2007, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
