Old 08-26-2009   #1 (permalink)
Dirtballer
Dirtballer's Avatar
Default Air Filter ?
Just was wanting to know when spraying oil on the air filter do you spray it on both filters or just the outer one ?
88 KX250 Boyesen reeds,Pro Style Levers,FMF pipe(wifes)
92 kx250 wifes 99 cr250 mine
Dirtballer is offline   Reply With Quote
Old 08-27-2009   #2 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
Wow. Are you just now getting to cleaning the air filter on these bikes??
Spray it all over. Use too much, then wrap it in paper towels and squeeze out the extra.
DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
KDXGarage is offline   Reply With Quote
Old 08-27-2009   #3 (permalink)
northernman
My hat is made of tinfoil
northernman's Avatar
What he said.
Be sure to use a proper oil for the job.
And clean and reoil regularly.
I do my KX250 airfilter after every ride.
Hug a person that needs one, not some damn tree you fool.
northernman is offline   Reply With Quote
Old 08-27-2009   #4 (permalink)
Revis
My bike doesn't have the airfilter.
So to compensate I took a tuppleware bowl. like one of those little clear bowls with a rubber lid, and heated up a drill bit and poked big holes in the lid, and the opposite side I made a hole the size of the opening for the carb. Cut some foam from a bigger filter I found at autozone and put it in the tuppleware bowl. All I need is to make sure I don't get big globs of mud, dirt, and nastyness in my carb. It works quite well. But would appreciate an airbox for an '82 kawasaki KDX80 if anyone has one, or just an airbox in general that would fit if anyone has one.
Revis is offline   Reply With Quote
Old 08-27-2009   #5 (permalink)
KDXGarage
KDXGarage's Avatar
Are you playing a "will it blow up before I buy an airbox" game??
See if this one is the same, by using the Kawasaki.com parts diagrams.
KAWASAKI KDX 80 AIR BOX ASSEMBLY:eBay Motors (item 270294189017 end time Sep-23-09 07:26:25 PDT)
Old 08-28-2009   #6 (permalink)
Dirtballer
Dirtballer's Avatar
No i have been cleaning the air filters every other ride but i have been spraying both filters and whated to know if this was correct and what the uni filter just goes over the stock one ?
Old 08-29-2009   #7 (permalink)
PlasmaBlue
PlasmaBlue's Avatar
+1
PlasmaBlue is offline   Reply With Quote
Old 08-29-2009   #8 (permalink)
nd4speed
Can't find time to ride
nd4speed's Avatar
You can buy a UNI POD filter that attaches directly to the carb. That's what I use.
nd4speed is offline   Reply With Quote
Washable 900 Custom Air Filter Baitis Kawasaki Cruisers 0 05-14-2009 05:21 PM
'85 900 GPZ Air Filter Carb Disconnect pscheyer Kawasaki Streetbikes/Sportbikes 5 05-04-2009 09:50 PM
Info on VN1600 engine ping avrgreeny Kawasaki Cruisers 22 03-11-2009 11:23 AM
vulcan 900 air filter replacement davidcruiser Kawasaki Cruisers 3 07-26-2008 02:29 AM
Air Filter Cleaning Norseman10 Vintage Motorcyle Info 6 05-04-2007 09:27 AM
