Old 10-08-2009   #1 (permalink)
ekoms
ekoms's Avatar
Default bent forks, how do I fix & carb ? (PICS)
well my friend had a very bad crash on his 83 Kawasaki KDX 250. he visibly bent the forks & shattered his leg. he's ok & decided when he's ready to get back on a bike he'd buy a new one, so he sold me the 83 cheap. I barely scraped the cash together for the bike & don't got much cash for replacements. so how do I fix them ? he mentioned straightening with a press. can I do that ? also any1 know exactly what carb this is so I can get a rebuild kit & what/where hooks up to the 3 little nipples ? I know the large nipple is the fuel supply.
forks
carb
thanks
ekoms is offline   Reply With Quote
Old 10-08-2009   #2 (permalink)
nd4speed
Can't find time to ride
nd4speed's Avatar
Carb is Mikuni VM- proabably 38 or 39mm.
I had a 84 KX250 I parted out. I still have the forks. They needed to be rebuilt and the fork caps were all marred up bad by a hack mechanic. The fork tubes are still good along with everything else. If you ever get some money I will gladly sell them cheap, but unfortunately you live in NM and shipping from MI probably won't be cheap.
I could drain them and possibly compress them to cut costs.
nd4speed is offline   Reply With Quote
Old 10-08-2009   #3 (permalink)
nd4speed
nd4speed's Avatar
You can use a press to straighten slightly bent forks but those look too far gone.
Old 10-08-2009   #4 (permalink)
ekoms
ekoms's Avatar
thats what i was afraid of. anything else i can do ?
Old 10-08-2009   #5 (permalink)
nd4speed
nd4speed's Avatar
bent forks 100% fixable? - 3WHeeLeR WoRLD FoRums
Bent Forks 250r. Question. - 3WHeeLeR WoRLD FoRums
Old 10-08-2009   #6 (permalink)
ekoms
ekoms's Avatar
thanks
Old 10-08-2009   #7 (permalink)
ekoms
ekoms's Avatar
any1 else know anything about the carb mainly a # or where to get a set of used forks/upper tubes cheap ?
thanks.
Old 10-08-2009   #8 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
pull carb apart and let it soak in B12 CHEMTOOL (you can get a gallon can at the autoparts store) , replace all rubber gaskets......
as for forks, just replace the fork tubes/seals/oil over the winter..... save some money and get the forks off ND4SPEED...
QKENUF4U is offline   Reply With Quote
Old 10-09-2009   #9 (permalink)
ekoms
ekoms's Avatar
Nd4speed I pm'd you
Old 10-09-2009   #10 (permalink)
Polar_Bus
Turtle Wax Taster
Polar_Bus's Avatar
I believe this guy can straighten forks that are not badly bent. Give them a call:
Frank's Maintenance and Engineering, Inc.
Bikes:
'07 YZ450F
'01 KX500
'84 GPz1100
'82 GS1100E
'06 HD Fatboy
Polar_Bus is offline   Reply With Quote
Old 10-09-2009   #11 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
DO NOT try to straighten those forks. Just save your money up and buy a used set. Opening a box with used forks in it is easier than opening the can of worms you mentioned.
Be careful about just blindly soaking carbs in carb soak. For example, 1989 and newer KDX carbs can NOT be soaked like that due to a non-removeable, non-replaceable o-ring inside.
Look on the kawasaki.com site under Owner Info / Parts Diagrams to see the parts diagrams for your bike. Check your VIN to make sure it is indeed a 1983 model before you go buying parts for a year model that you don't turn out to own.
DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
KDXGarage is offline   Reply With Quote
Old 10-09-2009   #12 (permalink)
ekoms
ekoms's Avatar
YWell I already ran the vin & was told it was an 83 kdx. I'm having a hard time finding used parts for this bike.
Old 10-09-2009   #13 (permalink)
nd4speed
nd4speed's Avatar
I will measure the forks since I know the 83/84 KX250 are the same motorcycle but I do not know if the 83 KDX has the same forks.
Good call KDXgarage.
Old 10-09-2009   #14 (permalink)
ekoms
ekoms's Avatar
ok, thanks ND4Speed. let me know.
Old 10-09-2009   #15 (permalink)
nd4speed
nd4speed's Avatar
Fork tubes 43mm diameter.
From end to cap 41.5 inches unsprung.
Pic soon
Old 10-09-2009   #16 (permalink)
ekoms
ekoms's Avatar
how much ?
Old 10-09-2009   #17 (permalink)
nd4speed
nd4speed's Avatar
guess that depends on if you just want the tubes, but I may not even be able to get these apart without a hassle. They use a very large allen bolt at the bottom which I probably don't have and the caps are stripped some. Getting the oil out should not be a problem.
Wanted to make sure you needed them, what you needed, then I have to weight them, measure/find a box, and calculate shipping still.
Old 10-09-2009   #18 (permalink)
nd4speed
nd4speed's Avatar
The pictures and part numbers do not appear to match. Like the front axle setup.
Old 10-09-2009   #19 (permalink)
ekoms
ekoms's Avatar
ya I was thinking just the tubes, but I can get both complete & swap tubes myself. whats best ?
Old 10-09-2009   #20 (permalink)
nd4speed
nd4speed's Avatar
I'll try to break them down later tonight.
Bayou 300 carb problems antiqucycle Kawasaki ATV and Mule 102 1 Day Ago 10:37 PM
KZ440 carb help babee_huey The Mechanics Corner 7 04-23-2009 11:31 PM
95 kx100 carb setup?...pics 2stroke173 Kawasaki Motocross and Offroad 21 04-12-2007 12:32 PM
HELP: Tried to fix bike and it's worse... carb sync Spinktodo The Mechanics Corner 3 08-25-2006 06:08 PM
89 600r Carb questions (with pic's) Superfly The Mechanics Corner 13 04-28-2006 08:49 AM
