Old 4 Weeks Ago   #1 (permalink)
chas28
Exclamation 05 Kx 250F trouble starting
I have a 05 Kx250f and I am having trouble starting the bike, there is compression there but i guess not enough to kick it over.
chas28 is offline   Reply With Quote
Old 4 Weeks Ago   #2 (permalink)
case_sense
have u done the normal trouble shooting? check plugs, spark, fuel etc?
case_sense is offline   Reply With Quote
Old 4 Weeks Ago   #3 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
When is the last time you checked and adjusted the valves?
DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
KDXGarage is offline   Reply With Quote
Old 4 Weeks Ago   #4 (permalink)
case_sense
or the jetting
Old 3 Weeks Ago   #5 (permalink)
knoxbrendon
deff check valves my buddies rmz 250 valves are leaking and the only way it will crank is to roll start it
knoxbrendon is offline   Reply With Quote
Old 3 Weeks Ago   #6 (permalink)
kxboblarry
Full Hot
kxboblarry's Avatar
Check the valves! Before its too late.
New timing chain and time it.
Clean the carb and get a new air filter
2006 KX250f
1992 KX500
1967 Chev C10
1982 Yota P/U
kxboblarry is offline   Reply With Quote
Old 2 Weeks Ago   #7 (permalink)
KX450_#122
#386 & #122
KX450_#122's Avatar
Much agreed with checking the valves if they are sticking open you and you happen to get it started then you may be in a world of hurt and could end up with a couple bent valves (sucks). If my memory serves me correctly the 04 and 05 KX 250Fs had weak valve springs and that was a killer in floated valves and such. Before you start tearing down your bike and removing this and that. start by doing a compression test. There is a tool you can buy that will screw down right into the spark plug hole and you will kick the bike over and have your reading. refer this reading to your manual and start trouble shooting and working from there. Always measure twice and cut once ( old carpenters saying)
John Theros
2003 KX 250 #386
2007 KX 450 #122
KX450_#122 is offline   Reply With Quote
98' ZX7R starting trouble, running trouble armyguy832004 The Mechanics Corner 2 06-15-2009 11:08 AM
Trouble starting 82 KZ1000p1 firefighter111 Kawasaki Cruisers 3 06-09-2008 11:06 PM
97 Bayou 220 starting trouble gc19pa80 Kawasaki ATV and Mule 2 08-08-2007 07:57 PM
Trouble Starting KLR 250 chicknstew Kawasaki Motocross and Offroad 0 02-19-2006 01:01 PM
1500 Classic Ignition Trouble hiway_dominator The Mechanics Corner 2 03-19-2004 11:25 PM
