Old 2 Weeks Ago   #1 (permalink)
bradley101
bradley101's Avatar
Send a message via MSN to bradley101
Default jetting all jacked up????
ok so every since i bought my 91 kx 250 iv had a harder then hell of a time to get it to run everytime ... it got a new topend maybe 2 hours on it now after the whole summer but befor i bought it it was bored out ... it got stock pipe and stock silencer off a 03. im assuming that the guy that owned it tryed to jet it him self and F*&$^@&^@* it hard!!! ... i got a 155 main jet and a 58 piolt. im thinking it should be a 165 and 48 .... whould this cause no start or very very hard start??? the air/fuel is 2 turns out and my needle clip is on the 3rd slot.. got lots of spark and the engine do get gas but it wont run. it ran last night no problems after a while ... it feels good power wise on the bottom end but gets boggy around the top.
bradley101 is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
northernman
My hat is made of tinfoil
northernman's Avatar
plug readings?
Hug a person that needs one, not some damn tree you fool.
northernman is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
bradley101
bradley101's Avatar
Originally Posted by northernman View Post
plug readings?
when i can get it to run the blug comes out pretty black and oily ... when i cant get it to run it seems to be pretty wet .... would too rich cauz it a hrad start???
Old 2 Weeks Ago   #4 (permalink)
northernman
They generally like to be rich for a cold start, but if the plugs always wet and oily, its rich sounding all the time.
What gas/oil mix are you running?
Old 2 Weeks Ago   #5 (permalink)
bradley101
bradley101's Avatar
i got a can of 32:1 and a can of 40:1 ... i think im running the 40:1 now
Old 2 Weeks Ago   #6 (permalink)
northernman
And its for sure got good compression, and it passed a leak down test, so the crank seals etc are good.
Old 2 Weeks Ago   #7 (permalink)
bradley101
bradley101's Avatar
lots of compression .. i checked it out befor i rode it last and it got 220psi .. got a hi compression piston and bored .010 .... all new gaskets so i dout theirs any leaks anywhere .. the rubber boots look new on the carb ... noo 100% on the crank seals i have new ones here but im not shure if they were replaced when the guy i bought it off had the motor done
Old 2 Weeks Ago   #8 (permalink)
northernman
Was the bottom end done, or just the top end.
Old 2 Weeks Ago   #9 (permalink)
bradley101
bradley101's Avatar
he orgional owner never told me he just said he brought to brians (one of the bust moto engine builders around here) and had the engine "done" so i dont know to what extent .... is thier a step by step online anywhere to changing the crank seal? i dont mind replacing it even if it is good justto have a frese one to narrow stuff down
Old 2 Weeks Ago   #10 (permalink)
northernman
Why not call the shop that did it and ask if they did the crank seals.
Shops keep a record of work done to a bike, or at least should.
Its not just a 5 minute job to change them.
Old 2 Weeks Ago   #11 (permalink)
bradley101
bradley101's Avatar
yeah ill give them a ring ... have to be tomorrow tho .. they closed about 30 mins ago. im not worried about how long or "hard" it could be just havent changed a crank seal on one of these bikes .. didnt know how complicated it is for it
Old 2 Weeks Ago   #12 (permalink)
Polar_Bus
Turtle Wax Taster
Polar_Bus's Avatar
220 psi is a LOT of compression ! If you are running pump fuel, that right there might be your problem (detonation). You should try 100% race fuel like VP C12, or CAM II,
My KX500 with the optional .02 mm thinner head gasket puts out 170 psi.
If your ambient ait temps are in the 40's and 50's F , I would put the jetting back to stock (160 main) for the colder months.
Bikes:
'07 YZ450F
'01 KX500
'84 GPz1100
'82 GS1100E
'06 HD Fatboy
Polar_Bus is offline   Reply With Quote
Old 2 Weeks Ago   #13 (permalink)
bradley101
bradley101's Avatar
i was out in the garage tonight .... and befor trying to start it i warmed the engine up for a short while with a heater (used to have to do that on my thunder cat 900) nad it made a offer to go .. it would idel for a second or 2 and shut off again .. it did it about 6 times only 2 or 3 kicks each time ... double checked my compression and it was 210psi not 220psi .. and as far as race gas im going to have to ask around to find out where to get that stuff at ... i think the closes place is 100kms away
The Donkey Bar! *CAUTION* - Utter Nonsense Inside! Tod Off Topic 29673 2 Weeks Ago 09:22 PM
Spankeys Jetting Guide - Info 2 Stroke riders must have Firestorm Kawasaki Motocross and Offroad 29 2 Weeks Ago 07:00 PM
Donkey Overload Reservior THE Donkey Off Topic 67123 08-25-2009 09:33 PM
carb setting KX125 stevem Kawasaki Motocross and Offroad 6 03-30-2009 05:59 PM
quick jetting help jdager Kawasaki Motocross and Offroad 3 05-17-2008 09:59 AM
