Need sprocket help
+ Reply to Thread
Results 1 to 3 of 3
Thread: Need sprocket help
  1. #1
    Join Date
    Jan 2012
    Posts
    6
    Default Need sprocket help
    Hi, I have a 1994 kdx200.. I do a lot of trail riding , I like to go fast but I also like the feeling of having torque when doing a hill climb .. So my question is what size front an rear sprocket would you recommend ??? Thanks for any help
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Honest it wern't me !! ULTIMATE Forum Supporter GREENISBEST's Avatar
    Join Date
    Nov 2006
    Location
    Northants UK
    Posts
    2,432
    Default Re: Need sprocket help
    To be honest it's a bit of trial and error getting the gearing right for what you want.
    But basically.
    For better low down you will loose a proportion of top end when you swap out the sprockets.
    To achieve improved low down for Trail riding you need to either reduce the teeth on the Front sprocket or increase the teeth on the Rear sprocket or a combination of both.
    be warned you will probably be limited to dropping 2 teeth on the Front before the chain is constantly running around the swing arm at it's pivot point, At this point if you still require more then go up on the Rear.
    As a rule of thumb 1 tooth on the Front sprocket is equivelant to 3 teeth on the Rear sprocket.
    END OF KEV's MESSAGE !
  4. #3
    Join Date
    Jan 2012
    Posts
    6
    Thanks very much!! This was helpful!!
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. sprocket kit
    By BLOXSTARZ in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 01-01-2012, 07:45 PM
  2. +1 sprocket sprocket need longer chain?
    By Deathstar13 in forum The Mechanics Corner
    Last Post: 05-14-2011, 10:14 PM
  3. new sprocket
    By cbutler727 in forum Main Lobby
    Last Post: 01-02-2008, 03:14 PM
  4. looking for kz 305 sprocket
    By thermis56 in forum Accessory Swap Meet
    Last Post: 01-05-2007, 06:20 PM
  5. KX65 Front Sprocket/Rear Sprocket Size
    By sd_outkast in forum Kawasaki Motocross and Offroad
    Last Post: 11-09-2005, 01:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
