1999 kx 80 help help help
+ Reply to Thread
Results 1 to 2 of 2
Thread: 1999 kx 80 help help help
  1. #1
    Join Date
    Jan 2012
    Location
    berkley ma
    Posts
    2
    Default 1999 kx 80 help help help
    Hi I'm new here a.d new to this bike . It's a 1999 Kx 80 just bought . The previous owner was going full throttle and the piston broke and messed up the cylinder and port. So he sent out the head and had ignored and the factory sleeve installed with new piston wrist pin and gaskets. So I can get it to file and die out then its like seized up pop it in like 4th gear roll back and forth and frees up. Kick it again fire dies kick it again and like seizes up again. Any ideas what I should check thanks for help Jon.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Jan 2012
    Location
    berkley ma
    Posts
    2
    Default Re: 1999 kx 80 help help help
    Ok never mind found the problem rod bearings are wiped right out .
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Kawasaki prairie 300 1999 mag wheel help
    By reisset in forum Kawasaki ATV and Mule
    Last Post: 11-06-2008, 09:09 AM
  2. 1999 ZX6R Gauge Cluster problems, help?
    By tsidesign in forum The Mechanics Corner
    Last Post: 07-17-2008, 02:01 PM
  3. HELP KX250 1999 in the water
    By Joel Bissing in forum Kawasaki Motocross and Offroad
    Last Post: 06-06-2008, 11:11 AM
  4. 1999 zx6r over filled with oil,,, HELP!
    By krazpeckerwood in forum The Mechanics Corner
    Last Post: 08-18-2007, 09:57 PM
  5. MY KX80 1999 problem HELP
    By KX80man in forum Kawasaki Motocross and Offroad
    Last Post: 03-30-2007, 10:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
