clutch basket part year interchangeability
+ Reply to Thread
Results 1 to 5 of 5
Thread: clutch basket part year interchangeability
  1. #1
    Join Date
    Jan 2012
    Posts
    3
    Default clutch basket part year interchangeability
    I have a 1992 kx 250 that requires a new clutch basket as there is play between the roller bearing and the basket starter gear. Aftermarket baskets will interchange between '92 thru '05 but you need the starter gear (which is bad on mine) and the larger gear which engages the crank. The factory baskets thru these years all have the same first five part #'s but have different last four part #'s. So clearly the actual basket is the same based on the aftermarket baskets. My question is do the other years have different gears that would prohibit their use in my engine or are they actually the same baskets with different numbers (last four) because of the year??
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Foil Inspector BTK Beginner coupe3234's Avatar
    Join Date
    May 2008
    Location
    East Renfrewshire
    Posts
    110
    Default Re: clutch basket part year interchangeability
    Hi there, the parts viewer I use only shows the assembled basket with both gears fitted, however, it shows that it is the same part number for all those years. This is a genuine Kawasaki parts list I'm talking about.
  4. #3
    Join Date
    Jan 2012
    Posts
    3
    hey coupe3234
    I would be forever gratefull if you could direct me to your list. The ones I have seen only show the first five numbers. The baskets I have seen on E-Bay all have the same first five numbers but the last four numbers are different for all the different years. This was true when I went to the kawi dealer as well. Unfortunatly they could'nt confirm if they were interchangeable. Surely someone out there has the answer!!!
  5. #4
    Forensic Bug Splatter Analyst BTK Expert martin-csr's Avatar
    Join Date
    May 2011
    Posts
    1,594
    Default -
  6. #5
    Join Date
    Jan 2012
    Posts
    3
    hey martin
    Thanks for the site info. Unfortunatly its the same story. Each year has the same first five numbers but different last four numbers. Maybe need a parts person that can physically compare year to year. By the way, please excuse my ignorance but what do the leters BTK mean?
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Clutch basket and hub locked
    By dmstarr in forum Kawasaki Motocross and Offroad
    Last Post: 11-11-2007, 03:11 AM
  2. Clutch cable part?
    By Dare in forum Vintage Motorcyle Info
    Last Post: 05-20-2007, 10:50 PM
  3. need 1992 kdx250 clutch basket
    By sledman99 in forum Accessory Swap Meet
    Last Post: 05-14-2007, 06:06 AM
  4. Rebuild Clutch Basket
    By Phil5712 in forum Kawasaki Cruisers
    Last Post: 06-17-2006, 12:39 PM
  5. Clutch Basket Rivets and spacers
    By Ozmeanie in forum The Mechanics Corner
    Last Post: 07-21-2005, 05:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
