Old 10-10-2008   #21 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
He's been banned, probably for spamming if not its for being stupid!
Jamie
1996 CR250: IT LIVES!! and bloody goes aswell, lol!
After another KX125 to kill the garden!
KickassKX125 is offline   Reply With Quote
Old 12-14-2008   #22 (permalink)
izakaman
Default sweet
nice dude
izakaman is offline   Reply With Quote
Old 02-02-2009   #23 (permalink)
Climaxxdirtbike
Climaxxdirtbike is offline   Reply With Quote
Old 02-09-2009   #24 (permalink)
Joy Rider
thanks for the info
Joy Rider is offline   Reply With Quote
Old 04-04-2009   #25 (permalink)
ryanrichardson
Originally Posted by Firestorm View Post
Spanky's Jetting Guide:
A correctly jetted carb makes a tremendous difference in the torque, midrange pull, top-end pull, and over-rev of your engine. If you have never jetted your bike correctly, you will almost certainly gain some performance at some point in the bike's powerband.
A cleanly jetted pilot circuit can be the difference between having to clutch the bike out of a turn or not. The needle can make all the difference in the world for the power of the machine in most situations, as it controls the throttle range that most riders spend most of their time using.
A correctly sized main jet could mean the difference between being able to rev out high enough to not have to shift one more time at the end of the straight, or the power falling flat on top and requiring you to make that extra shift.
Are you fouling plugs? Many people will tell you all sorts of band-aid fixes, from running less oil, to running a hotter plug. Both are incorrect fixes for plug fouling. It's all in the jetting.
The only way to know what jetting changes you will need is by trial-and-error. No one can give you jetting specs, because every bike is different, every rider has a different style, and jetting is totally weather dependent. Unless the person telling you what jets to use is riding an identical bike, on the exact same track, at the same time, his recommendations are meaningless.
Jetting is fairly simple, and is a useful skill to learn if you ride a two-stroke and want it to perform at it's best.
It's very important that you start with the pilot circuit. The reason is simple. The pilot circuit affects the entire throttle range. When you are at full throttle, the main jet is the primary fuel metering device, but the pilot is still delivering fuel as well, adding to the total amount of fuel that your engine is receiving.
Before you start to rejet your bike, you need a clean air filter, a fresh plug (actually you need several plugs to do plug-chop tests for the main jet), and fresh fuel.
One important detail: Make sure the engine is in good mechanical condition. If your engine has a worn top-end, fix it first. Trying to jet a worn out engine is a waste of time. The same goes for reeds that don't seal properly, and a silencer that needs re-packing. Worn reeds will mimic rich jetting, and worn rings will mimic lean jetting.
Before you start the jet testing, Install a fresh plug. Set the float level to the proper specs, an incorrect float height will affect your jetting all across the throttle range.
Warm the bike completely, and shut it off.
As already stated, start with the pilot circuit. Turn the air screw all the way in, then turn it out 1.5 turns to start. Start the engine, and turn the idle screw in until you get a slightly fast idle, or hold the throttle just barely cracked, to keep the engine idleing. Turn the airscrew slowly in, and then out, until you find the point where the idle is fastest. Stop there. Do not open the screw any farther, or your throttle response will be flat and mushy, and the bike may even bog. This is only the starting point, we will still have to tune the air screw for the best response.
Now is the time to determine if you have the correct pilot installed in your carb. The air screw position determines this for you, making it very simple. If your air screw is less than 1 turn from closed, you need a larger pilot jet. If it is more than 2.5 turns from closed, you need a smaller pilot jet.
Once you have determined (and installed it if it's neccessary to change it) the correct pilot jet size, and tuned the air screw for the fastest idle, it's time to tune the air screw for the best throttle response. Again, make sure the bike is at full operating temperature. Set the idle back down (the bike should still idle, despite what you read in the Moto Tabloids), and ride the bike, using closed-to-1/4 throttle transitions. Turn the air screw slightly in either direction until you find the point that gives you the best response when cracking the throttle open. Most bikes are sensitive to changes as small as 1/8 of a turn.
The air screw is not a set-it-and-leave-it adjustment. You have to constantly re-adjust the air screw to compensate for changing outdoor temps and humidity. An air screw setting that is perfect in the cool morning air will likely be too rich in the heat of the mid-day.
Now, it's time to work on the needle. Mark the throttle grip at 1/4 and 3/4 openings. Ride the bike between these two marks. If the bike bogs for a second before responding to throttle, lower the clip (raising the needle) a notch at a time until the engine picks up smoothly. If the bike sputters or sounds rough when giving it throttle, raise the clip (lowering the needle) until it runs cleanly. There isn't really any way to test the needle other than by feel, but it's usually quite obvious when it's right or wrong.
Last is the main jet. The main jet affects from 1/2 to full throttle. The easiest way to test it is to do a throttle-chop test. With the bike fully warmed up, find a long straight, and install a fresh plug. Start the engine, and do a full-throttle run down the straight, through all gears. As soon as the bike tops out, pull the clutch in, and kill the engine, coasting to a stop. Remove the plug, and look deep down inside the threads, at the base of the insulator. If it is white or gray, the main is too lean. If it is dark brown or black, the main is too rich. The correct color is a medium-dark mocha brown or tan.
Once you have a little bit of experience with jetting changes, and you start to learn the difference in feel between "rich" and "lean", you'll begine to learn, just from the sound of the exhaust and the feel of the power, not only if the bike is running rich or lean, but even which one of the carb circuits is the culprit.
The slide is also a tuning variable for jetting, but slides are very expensive, and few bikes need different slides, so we won't go into that here.
Keep in mind, even though this article is intended primarily for two-strokes, four-strokes also need proper jetting to perform right, although they are not quite as fussy as their oil-burning cousins. The only real difference in the two is with the pilot circuit.
Two-strokes have an air screw that you screw in to make the jetting richer, ansd screw out to make the jetting leaner. Four-strokes, on the other hand, have a fuel adjustment screw that you screw in to make the jetting leaner, and out to make it richer.
Great advice M8!!! Jst got a 2001 B11 Kawasaki KMX 125 its great but feeling really rough when the kips kicks in at 6500rpm! its coughing & splutering really bad & loses nearly all power?. Have cleaned the carb, replaced exhsaust gasket (wasn't sealed), new plug and re-tuned. Still nothin. Can any1 Help????.........Thanks Ryan.
ryanrichardson is offline   Reply With Quote
Old 04-04-2009   #26 (permalink)
ryanrichardson
Question Kmx 125 B11 (2001)
Old 04-06-2009   #27 (permalink)
kmx125-200
hi there great advice, but one question, my bike originally used a pump for the 2 stroke and the carb only handled petrol, but i now want to run it premix
what mods should be done to the carb for this to work ok?
kmx125-200 is offline   Reply With Quote
Old 07-19-2009   #28 (permalink)
austen
austen's Avatar
Yeah, thanks. It really tells the details in a simple way for all to understand.
austen is offline   Reply With Quote
Old 4 Weeks Ago   #29 (permalink)
PRICELESSMOTO
great article since i sold my 250r 10 years ago ive been away from 2-strokes mainly street motorcycles (customs).
just to add 4 strokes info whether offroad single cylinders or on road four bangers. they have both a air and fuel mixture screw depending on the carb you have.
If they screw is closest to the engine its a fuel mixture screw adjustment
If the screw is closest to the air filter side its a air mixture screw. common sense will kick in if you think about it. i just know more about old 4-stroke four bangers then 2-strokes.
Great post on jetting i printed it out and added it to my carb tuning catalog.
PRICELESSMOTO is offline   Reply With Quote
Old 2 Weeks Ago   #30 (permalink)
mxboy7
hi do you no the steps to change a gear shaft on a kx85
thanks
mxboy7 is offline   Reply With Quote
New-B chick, and already a question! RagDoll_Kunoichi Main Lobby 45 06-10-2009 08:39 PM
New riders and literbikes Freakinout Kawasaki Streetbikes/Sportbikes 173 06-06-2008 01:40 AM
New dates, Schedule changes, Heartland Park info TrackAddix Kawasaki Streetbikes/Sportbikes 1 07-22-2005 02:23 AM
New dates, Schedule changes, Heartland Park info TrackAddix Rides, Events and Rallies! 0 07-21-2005 09:00 PM
Attn Arizona Riders - I need Info Spok Off Topic 21 06-01-2005 03:59 PM
