Kx125 rebuild problem - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 01-07-2017, 07:08 PM Thread Starter
Junior Member
I've recently bought a 98 kx125 for a few hundred dollars under the impression it just needed piston and rings which still seems to be the case, but I wasn't giving the old piston that came out of it and the shops say they don't know where to get a piston bc it's been bored over. So I'll try asking here. The shop measured the cylinder bore at 57.5 so does anyone on here know where I can get piston and rings for that size??
Peeps1389 is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 01-28-2017, 03:26 PM
Junior Member
ItsJuniorJ's Avatar
Garage
What's the OEM piston clearance supposed to be? Off that, we can work out which position size you'll need - but for reference I know you can find <a href="https://www.ebay.co.uk/itm/231872043611 ">Wiseco</a> overbore pistons for the KX125 all over eBay.
Instagram: @ItsJuniorJ - '06 KX250R
ItsJuniorJ is offline
post #3 of 3 (permalink) Old 02-05-2017, 02:35 PM
Junior Member
I'm in the same situation as you are but my cylinder is measuring 55.5mm and can only find either a 54mm or 56mm piston not sure if other pistons from other makes or models would be interchangeable
Zackx125 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
