Old 06-12-2006   #1 (permalink)
Paul1965
Default Sticky Clutch KX80
I have a 1989 KX80 motocross bike. The clutch does not release (Stalls even when clutch lever pulled in fully). I pulled clutch housing off and removed springs. I then put a socket on the 15mm(?) nut in the centre of the crank and jammed the gears (Big outer one and small one forward of the clutch)with a piece of copper.
My Question: Should the crank spin freely? It was tight so I put a smal pice of pipe on it and pushed harder. The crank 'cracked' loose. DidI break something? or did I free up sticky clutch plates? The engine was sitting in a box in a shed for approx 4 years before I got it.
Help!!
Paul1965 is offline   Reply With Quote
Old 06-12-2006   #2 (permalink)
Gunjji
I Hate Onions!!!
Gunjji's Avatar
Send a message via ICQ to Gunjji
Hmmmm, when you say spin freely does the piston go up & down?
My KX 250
Gunjji is offline   Reply With Quote
Old 06-12-2006   #3 (permalink)
Paul1965
nope, spins by hand.
Clutch plates wobbling around in clutch basket tho remember...tension springs removed.
Is there some sort of shear pin arrangement?
Was only a small piece of pipe I put on the socket bar...didnt think it would put mych more stress on it than a day on the track..
Old 06-14-2006   #4 (permalink)
Paul1965
Problem solved.
Clutch working fine now. The "cracking" sound was obviously the clutch plates breaking free of where they were stuck to.
1985 KX80 - Clutch Problem xEnDoNx The Mechanics Corner 3 06-12-2006 07:11 PM
KX80 big wheel clutch problems 93 mrnaturals Kawasaki Motocross and Offroad 4 05-05-2006 07:25 AM
Hey hey, I am noticing a lot of new Pac. Northwesters around here. trikebubble Off Topic 33 09-23-2005 05:47 PM
Ninja 250 clutch trouble Dave 96TA The Mechanics Corner 6 10-29-2004 09:12 AM
Whistling Gas Cap and Sticky Clutch Freedom1600 Kawasaki Cruisers 4 05-11-2004 08:46 AM
